Question about Grilling
Does not go into spin cycle - Grilling
  • rexwarehouse May 11, 2010
    If you manually turn the dial (with power off) until you hear the timer click into the spin cycle and plug the washer back into the wall outlet the washer should start to spin. The lid has to be closed to try this. No spin listen for a motor hum. Dead silence you could have many problems, burnt motor winding, failed lid switch, timer contact defective. One has to assume that you can hear it wash but not spin.
    No wash or spin you need to check for 120V power. Hope this helps.
    Sergeant:
    Champion:
  • 289 Answers
What bran is it.
Posted on Nov 18, 2009
Maytag Neptune MAH-1 front load washer won't spin in some cycles I use often. it spins at the end of the cycle and in cycles I do not use often. it spins in the spin cycle when I run that cycle
sounds like the timer is not advancing is certain cycles? timers have contact points that can burn and seize up sticking close and not allowing the next cycle to move
Mar 16, 2015 | Maytag Washing Machines
Whirlpool ultimate II washer will not spin everytime in the normal spin cycle
Hi, Ginger. We're sorry to hear about the difficulty with your washer. Below are links to our Use & Care guides, Parts Diagrams, Troubleshooting information and the Service are of our website. We hope this helps! http://bit.ly/112Lu7q
Aug 23, 2014 | Washing Machines
Washer skips spin cycle
You have an issue with the controller on your machine. Needs replacement.
Sep 17, 2017 | Maytag Legacy Series Top Load Washer
In the permanent press cycle only the spin cycle isn't spinning enough. Clothes are extremely wet must run another spin to get out the water.
Thts right....the permanent press cycle my only spin at 600rpm because the clothes would be creased otherwise. Hence the PP cycle.
Some machines lock the PP cycle to low spin RPM. Some allow you to over ride this setting. Check your machine and have a play with the controls. Some PP clothing should even be drip dry to retain the premanent press in the garment. If you want PP then low spin is needed. fast spin will not be a PP cycle...
Aug 07, 2010 | Washing Machines
Washer will not spin in wash cycle
I have a Kenmore washer that will not spin or drain.
May 31, 2010 | GE WBSR3140DW Top Load Washer
Kenmore washing machine didn't spin @ end of cycle
If you tried a different cycle and it worked this means that the timer is probably bad on the main cycle that you use. If the machine does not spin on all cycles, then please check out the LID SWITCH.
Nov 12, 2009 | Washing Machines
Doesn't change cycles, first spin and rince cycle doesn't work at all
Sounds like you have a bad timer Does it spin on final cycle? (Spin Cycle)
May 11, 2009 | Washing Machines
Whirlpool top Loading washing machine won't spin on spin cycle
If the washer won't finish a spin cycle, it probably means that your timer went bad or stalled. You can take the control panel off and look at the contacts for scorching or corrosion.
Sep 21, 2008 | Whirlpool LCE4332P 2.1 cu. ft. Top Loading...
Grilling Logo
23 people viewed this question
Top Grilling Experts
paulcarew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
