Question about Car Audio & Video
WHAT FUES CONTROL RUNNING LIGHT FROM TRUCK TO TRAILOR ON 2008 JEEP LIBERTY I CANT GET POWER FROM TRUCK TO TRAILOR
  • 6,826 Answers
It should be under the hood,in the fuse box,and the cover should say witch one it is,purchase a test light,and ground it,turn the key to the on position,and the lights on,touch each fuse on each side of the fuse on the top,the test light will light up.If one fuse only lights on one side of the fuse,and not the other,then that fuse is blown.
Posted on Nov 18, 2009
Manual stolen. 2008 jeep liberty heater and power/lighter unit not working.fuse? Where to look and which one?
m6 fuse - power outlet and cigar lighter
using jeep terminology !
The Totally Integrated Power Module TIPM is located in the engine bay near the battery .
page 436 of
http://cdn.dealereprocess.com/cdn/servicemanuals/jeep/2008-liberty.pdf
you may find a 12v voltage probe that lights up when 12V touched would be helpful in checking the fuses are all ok .
Jan 05, 2017 | 2008 Jeep Liberty
No power at 3rd brake light on 2008 Jeep Liberty
on all cars, it goes in to harness,and then usually the left light on body and if that lamp works that means the wire is broken
from 3rd to left light (2 wires there)
the factory service manual covers the details. of all harnesses in cars.
this is the KK jeep. the book matches that. USA
Jul 16, 2016 | 2008 Jeep Liberty
Traction control light stays on and truck want go
join a liberty forum and post there find by googleing jeep liberty forums
Feb 01, 2013 | 2008 Jeep Patriot
I have a 2008 Jeep Liberty. The heater/air blower just quit working, I checked the fuse and that was good. What's the problem?
most likely its the blower motor unless it has a relay that you cant check you just have to replace it. sometimes you will have a few relays that are the same and you can use one just to see if thats the problem,but make sure its not one that controls anything major.
Dec 10, 2012 | 2008 Jeep Liberty
Where is the fuel pump relay on a 2008 jeep Liberty
Left side dashboard facing the door. Remove the oblong panel.
The fuse panel diagram is in your owners manual, if you don't have one, go to Jeep.com and download it for free.
Fuse Panel Description
Cavity Fuse Description
  • 1 15 Amp Blue Horn Relay, Power Sunroof Relay, Power Window Relay
  • 2 10 Amp Red Rear Fog Lights (Export Only)
  • 3 20 Amp Yellow Cigar Lighter
  • 4 10 Amp Red Headlight Low Beam Right
  • 5 10 Amp Red Headlight Low Beam Left
  • 6 20 Amp Yellow Body Control Module/Power Door Locks
  • 7 10 Amp Red Left Park Light/Left Tail Lamp/License Plate Lamp
  • 8 Spare
  • 9 10 Amp Red Right Park Light/RightTail Lamp/License Plate Lamp/ Cluster
  • 10 Spare
  • 11 15 Amp Blue Flasher
  • 12 15 Amp Blue Stop Lights
  • 13 10 Amp Red Body Control Module/ CMTC/Cluster/Pass. Airbag On,Off Indicator, Auto Daylight Mirror/Light Bar Switch (Renegade Only)
  • 14 10 Amp Red PDC Fuel Pump/AC Clutch, Starter Relay/Engine Controller/Transmission Controller (Diesel Only)
  • 15 Spare
  • 16 20 Amp Yellow Power Outlet (Rear)
  • 17 15 Amp Blue Rear Wiper
Sep 02, 2012 | 2008 Jeep Liberty
My 2008 jeep liberty has an issue. While driving back from TCU game (and TCU won !! my daughters in the band), it made a warning noise and lights on dash came on. ABS, ESP, ESP BAS, serv 4wd and cruise...
I had this same problem with my Jeep Liberty 2008 and it need a new computer
module...it was very expense thank the Lord that I was still under warranty.
Sep 19, 2010 | 2008 Jeep Liberty
I have a 2008 Jeep Liberty sport it has 39600 back-up lights not
If you have tested fuses and bulbs with test light,and they check out,
the next step is to put you jeep in reverse with the key on,and use your test light to probe the wires before they enter the bulb sockets for power,if you have power replace sockets,if not check to make sure wires are still connected to back up light switch on trans,if you find no problem there,replace the switch
Dec 03, 2009 | 2006 Jeep Liberty
2008 jeep liberty navigation safety disable question
Can't be done. All the safety items are controlled by the ECM.
If the ECM senses the car moving via the speed sensor, it will disable the nav. To disable the safety would be to disable the computer and the car will not run.
Feb 15, 2009 | 2008 Jeep Liberty
2002 jeep liberty - limited - electrical problem
If yor liberty is a 2002 to 2004 it is very likley that the wiring harness is pinched under either the drivers or passengers seat. you need to remove the seats (its only 4 bolts) and lift up the carpet and look at the harness that runs under the seats. I have seen this many times before.By the way i am a Jeep master technicain and have been for 15 years.
May 18, 2008 | 2002 Jeep Liberty
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
