Question about Toshiba 40RV525U 40 in. LCD TV
What are the best color settings for Toshiba 40RV52U 40 in. LCD TV
Color adjusting
Posted on Dec 20, 2011
Toshiba 40RV52U TV has just started cycling off & on. Is this a problem with the power board?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jan 20, 2016 | Toshiba 40RV52U TV
My plasma tv is not working due to the color wheel not spinning. how do i make the color wheel spin is it casued by fan not spinning
A plasma tv does not have a color wheel. Only DLP projection sets have a color wheel.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/rhoyce_17cd0863e86da465
Jan 11, 2013 | Toshiba 40RV525U 40 in. LCD TV
Toshiba 40rv52u remote control
If just using one remote to try have it tested----many digital cameras in a dim light will react with a flash on the display screen when remote is pointed at them and buttons pressed.
Also try putting remote against remote receiver lens on front of set--if it reacts close up---the remote receiver in the set is bad---can be same if no reaction at all.
Either the remote or the receiver---one or the other.
A last thought here is some sets (read owner manual) have a feature to lock out the remote which can be engaged by accident.
May 15, 2012 | Toshiba 40RV52U TV
What are the best color settings for a toshiba 40rv52u
saultoman,
First set your picture setting back to their defaults. Now adjust each setting up and down all the way to learn what they do.
Then try the following:
1) Leave your back light at 50%.
2) Adjust the brightness until blacks look jet black them back some.
3) Set the sharpness up until it looks like too much then back a bit; you can never have too much.
4) Add only a little color as most people like a little more color than what the TV is set to show.
5) Now adjust the contrast up until it no longer looks as if your are watching TV with sunglasses on; don't be afraid to go to 100%.
6) Now work the back light only a a small amount.
It can take some people a few days to tweak the settings. Remember to right down each setting on there value for future reference after getting the picture to what you like.
-Chris
Sep 11, 2010 | Toshiba 40RV525U 40 in. LCD TV
There's 4 horizontal white tiny lines appear on screen to make the picture become 4 equal parts from top to bottom with many horizontal lines. My TV is Toshiba Lcd(40RV52U)
You have failure/weakening in the vertical section , the retrace lines appear due to the change in the freq.
Check out small value capacitors in this section. confirm by shorting parallel with the right polarity. Unless you are familiar with electronics please do not attempt unless with help. the fault is not very serious and could be attended with low expense.
Jun 30, 2010 | Televison & Video
My toshiba problem.
You may have bad T-CON board, try cooling it with small fan blowing on the vents of the TV.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jun 30, 2010 | Toshiba 40RV525U 40 in. LCD TV
Our Son hit a plastic ball into the face of our new Toshiba 40RV52U LCD display. We now have an area that looks like a splat and a hole in the picture. Is it possible to repair or replace the LCD screen?...
unfortunately it can't be repaired the entire panel will need to be replaced, most times the cost of the panel is as much or more then the cost of the tv. My son broke our 42" lcd after had it for only 3 weeks! Not covered under warranty...we had to replace tv. FYI there are companies that sell a clear protective screen for LCDs I bought one and it works great! One such website is www.tvarmor.com but you can google and find alternatives.
Rustym62
Apr 30, 2009 | Toshiba 40RV525U 40 in. LCD TV
Toshiba TV fails to recognize HDMI input
If the tv does all those symptoms but after some seconds the tv works and stays doing the job. THen the tv has a slow microprocessor to recognice the different resolutions or video inputs.
But if the tv cannot do anything and stay aout of signal forever. send the tv to the waranty. (no waranty? you have to use the component input instead to have digital signal reproduced
Apr 24, 2009 | Toshiba 40RV525U 40 in. LCD TV
No sound with HDMI cable and Xbox 360
FROM THE TOSHIBA MENU, (FIRST MAKE SURE YOU ARE SET TO
THE HDMI PORT THAT THE XBOX IS PLUGGED INTO) THEN SELECT
HDMI SETTINGS, UNPLUG HDMI CABLE FROM THE TOSHIBA TV (LCD
FLAT, MINE IS A 42") WAIT FOR THE SETTINGS TO HIGHLIGHT OR NOT
BE GRAYED OUT, THEN TURN OFF THE THREE SETTINGS, FOR COLOR
AND LIP-SYNC., SCROLL DOWN AND PRESS THE RESET BUTTON,
WAIT FOR MESSAGE TO APPEAR. TURN OFF THE TV AND PLUG IN THE XBOX.
TURN EVERY THING BACK ON. SEE IF IT WORKS.
NOT ALL CABLES ARE THE SAME AND NOT ALL TVS ARE THE SAME.
READ THE TV OWNERS MANUAL CAREFULLY, (RTFM), I FOUND A NOTE ABOUT
THESE SETTING ON THE SPECIFICATIONS PAGE.
Mar 26, 2009 | Toshiba 40RV525U 40 in. LCD TV
Best Picture Quality
Check this link out. I think it should give you all the info you need for optimal picture settings.
http://help.cnet.com/samsung_LN_T4061/9602-12576_39-0.html?messageID=2510125&tag=tip-2510125&kw=samsung+LN-T4061
Nov 13, 2007 | Samsung LN-T4061F 40 in. LCD HDTV
Toshiba 40RV525U 40 in. LCD TV Logo
326 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
