Question about Sony Computers & Internet
My laptop cant use in noraml mode and it turns to white
Why does my laptop monitor turn to white everytime after loading and i cannot use it in normal mode, but it runs ok in safe mode? what's the problem and the solution that i could apply for it.thnx alot.
  • monalizalanu Nov 18, 2009
    Blue Screen of Death appears after I opened the normal mode and i deleted all the recent software I installed in it using safe mode.Also tried to restore the system in safe mode but still it keeps restarting after appearing the Blue Screen...please help and thnx in advance.
  • Clayton Molle May 11, 2010
    If the laptop runs fine in safe mode, the problem is typically either a bad driver that is loading OR a newly installed program / hardware that is interfering with the Operating System. More info is needed: - what OS is on your laptop - what, if any, error messages are appearing - are you getting the Blue Screen of Death (BSOD) with normal booting - have you installed any new hardware or software on this laptop (USB, PCMCIA cards, modems, etc) It is good news that your system runs in safe mode - and this typically can be fixed without too much trouble.
    Novelist:
  • 138 Answers
Resetart the laptop and choose "Debugging mode". This will show the list of files that loads during the initial boot up and OS starting. Reply with the last file listed before the BSOD.
If the BSOD occurs after the logging, list where it occurs (during the "Starting Windows XP window" or "after the desktop appears but no desktop icons".
Also, provide what OS is on the laptop.
Posted on Nov 18, 2009
  • Sony Master
  • 497 Answers
1. Try booting the Computer to the "Last Known Good Configuration" and check.
2. Try removing any unwanted Application from the Startup in the Safe Mode.
In the Safe Mode, click on Start, select the option Run, type "msconfig" in the Run command and then press the Enter key (for XP Operating System).
For Vista or Windows 7 Operating System, click on Start, type "msconfig" in the Search area and press the Enter key.
In the MS Configuration Utility, un-check any unwanted or un-known items under the Startup Tab, click on Apply then OK and restart the Computer in the Normal mode.
3. If the issue persists, try performing the System Restore operation in the Safe Mode from Start -> All Programs -> Accessories -> System Tools -> System Restore.
NOTE: The System Restore procedure will restore the Registry and other settings back to the date and time selected. No data will be lost. Saved documents and e-mail will not be affected by performing a System Restore. Any Hardware or Software that has been installed after the date of the restore point will need to be reinstalled.
4. Ensure that the Computer is not infected with Virus. Scan and clean the Computer using any Anti-virus Application in the Safe Mode.
This should resolve the issue.
Good Luck!!!!!!!!!!!!!
Everytime i turn on my computer. the monitor is going on and off and so on.
Seem that your screen resolution changed. Turn off the notebook and again switch it back press F8 until it shows a list of option and then select SAFE MODE. Select it and enter into safe mode.
After welcome screen Right click on Desktop and select properties.
You will get Display Properties window.
Then select the Settings TAB in Display Properties. There select the screen resolution as low as you can 640by480 or 800by 600 then select apply and restart the Laptop.
The notebool should work normally as previously it work.
Hope this will be usefull
Thanks & regards
Nanda Kishore.
Dec 29, 2009 | Fujitsu Siemens Siemens Basic Line B17-1...
Help
just once replace the RAM module
Nov 19, 2009 | Computers & Internet
White screen appears, Screen turns fuzzy intermittently
To determine if the video card is faulty or the LCD screen, connect an external monitor to the laptop. Power up the monitor first and then the laptop. The video will automatically switch to the monitor. If you see a normal Windows image the the video card os OK.
The next thing is to reseat the video cable and if this doesn't fix the problem then the fault is the LCD screen.
May 23, 2009 | Acer Aspire 2930-4661 Notebook
My monitor is not connected to the computer but everytime i turn it on the whole screen turns blue, then yellow then white etc.. how do i fix it
That could be normal operation if it is not connected. Does it do the same when connected? If so, try another monitor. Does the computer power on normally otherwise?
Dec 13, 2008 | Computers & Internet
Digital Power Saving Mode
Go to your monitor power settings and turn off Hibernation and other monitor power schemes.
If this problem persist, request for more technical assistance from the manufacturers website
Nov 30, 2008 | LG W2252TQ Monitor
Acer Aspire 5585 Laptop LCD Problem
You need to replace the inverter of your lcd screen.
Oct 02, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Have you tried booting into "Enable VGA" mode via the "Windows Advance Option" screen? By press F8 before Windows XP loading screen comes up. In this mode the Video Card drivers are disabled. So if your screen appears normal and not white in this Mode then it is your video card drivers which are causing the issue.
Aug 19, 2008 | Acer Aspire 5610-4648 Notebook
Yahoo touble
do one thing goto safe mode with networking and then install yahoo messenger not the beta version the normal version come to noraml mode and use it it will work
Apr 24, 2008 | Computers & Internet
PC or monitor, signal problems
your monitor is telling you it's on it's last legs..either that or your compaq has a bad video section. either is more vital than a video cable being loose.
Mar 10, 2008 | Computers & Internet
Computers & Internet Logo
160 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
