Question about Kenmore Vacuums
Ive changed the filter and checked the hoses but vacuum doesnt pick up ...when its on the dust is being blown out the bottom of the vacuum....i took the canister off to test the suction its fine...also cleaned the filter ...help!
    Problem Solver:
  • 12 Answers
Have you check the roller brush and drive belt? It may be your belt has broke or is slipping and therefore not turning the brush.
Turn on machine and power head see if brush is turning if it is put a small amount of pressure on the roller. If it stops turning replace the belt
Posted on Nov 18, 2009
I have a Hoover nano cyclonic vacuum. I completely lost suction and found the hose was clogged to the max. After removing it and changing the filter I tried to use it and it picked up dust but not much...
If the hose was clogged there's a good chance the head was clogged too. Try to stick a bent coat hanger or other semi-rigid piece down the throat at the top of the head to push the clog out through the mouth. You might have to remove the beater bar to get the clog out.
May 20, 2014 | Vacuums
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
I have a hoover Dust Manager DM6200. actually it is my friend's. She said it wasn't working well, so I took a look. It wasn't picking up, and seemed to be spreading dirt in fact. I emptied...
Hey Julie,
Hopefully we will get this solved together.
To me, this problem sounds like either the filters are choked up and cannot breathe, OR.... the bagless cannister is not quite sitting in the machine properly.
Honestly, I am more leaning towards the cannister not quite in properly, that is assuming that everything is out of the suction hose.
Start with the process of elimination. Remove and clean the filters with a paint brush or other brush. Get as much dirt and debris off of them as you can and replace them into the machine.
Turn on the machine, and using only the hose attachment, feel if the suction is there. If not, try a re-alignment of the cannister and check the hose. a small coin or marble running through the hose will tell you if there is still a blockage in there.
Where the attachment hose connects to the bottom of the machine could also be blocked up as well. This will also give the same effect of the dirt blowing out the bottom of the machine.
Lastly, it is also quite possible that the belt has stretched or worn out. This too will contribute to it not picking up.
Let me know if this helps, and we will go from there.
Good luck,
Mark
Jan 24, 2012 | Kirby Ultimate G Bagged Upright Vacuum
My Bissell bagless vacuum does not seem to work anymore. It will start to with a suction and then instead of picking up the dirt, it appears to blow the dirt out almost in a cloud of dust and debris from...
this is caused by a dirty air filter and/or a blocked vacume hose ( most of the time the blockage is at the bend where the hose enters the floor sweeper area ) ---
remove and tap out and brush the filter ( or use a air compressor to blow out filter ).
then with the vacume on its side - remove the bottom plate ( like you were going to change the belt ) and use a coat hanger and clean out the hose between the floor sweeper and where the suction hoes attaches. this will restore your vacume to full operation.
c...
Jan 23, 2011 | Bissell 6595 Lift Off Bagless Upright...
Hoover Turbopower Wind Tunnel V2 - clogged - cannot find a way to get at the clog - HELP!
i took off the bottom black piece...removed the brushes ..took a coathanger and went down in silver dollar sized hole and got a big clog out...i also removed the black hose on the back at the very bottom...and used a coathanger up in there as well. mine is picking up some..but ive still gotta clog myself...i was hoping to find an answer here...-_-
Jan 13, 2010 | Hoover U5753-900 WindTunnel Bagless...
Why does my miele 700 revelution hoover keep cutting out? The bag is not full just loses power?
  1. i have a miele revolation hoover, it doesnt pick up. it has hardly no sucktion. where and how do i get the filter out to clean it??? it was given to me working. ive changed the bag so thats not the problem. and checked the hose. still no joy. need sucktion.. Thankyou jacqui
Jan 01, 2010 | Miele Revolution 600 Bagged Canister...
Vaccum cleaner not picking up (116.36933/Aspiradora)
Joan,
I had a similar problem with my upright and just resolved it today. Mine was also picking up with the beater bar, but not as good as it should and it had very little suction at the hose.
I did everything it said to do in my owners manual...
I looked into every entry to the dirt cup.
I checked for blockages into the bottom of the vacuum.
I cleaned the HEPA and regular filters and dirt cup - still no success.
I made sure the belt was working properly.
I finally sat and looked at how things should get into the clear dirt cup (bagless model).
I finally realized it had to be a blockage in the hose.
I completely detached the hose from the vacuum - this took some muscle.
Took the hose outside and used my high pressure nozzle on my garden hose to spray out the hose. It took a few seconds before a pretty large & stiff piece of paper (2"x2") and much more very dirty stuff finally blew out...
No wonder the vacuum had no suction!!!
The paper that was blocking the hose reminds me of a piece found under a Reese's Peanut Butter Cup! YIKES, it was probably candy causing yet more problems besides the extra pounds!!!
Hope this helps - I'm not an expert, just a frustrated cleaning fanatic who hates it when mechanical things don't work right!
Good LUCK!
rtwospeed in Henderson, NV
May 27, 2009 | Kenmore Vacuums
Home healthy bissell vacuum
your intake hose is clogged.its the clear hose that comes up from the bottom and up the backside of ther vacuum.take the screws out that hold the hose connector on and then take a coat hanger and bend the tip so it is round then work it down into the intake hose.you might be able to push the clog out the bottom
Dec 19, 2008 | Bissell Healthy Home HEPA Bagless Upright...
Not sucking up dirt in upright position
if there is dust flyin around the vacuum u might try lookin for clogs on the bottom where the beater brush pushes the dirt in and maybe where the dirt goes into bag ive used wire clothes hangers to free em up works..hope this helps
Dec 06, 2008 | Dirt Devil Vacuums
Vacuums Logo
102 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
