Question about Olympus Stylus 840 Digital Camera
My daughters zoom lens is stuck open and just makes noise when you turn it on..what should I do?
  • 421 Answers
The lens has probably got something in the retraction mechanism that is stopping it retracting. This can be something as simple as sand or grit or as a result of a drop or knock. In most cases the camera will need to be stripped apart to remove the lens assy before it can be repaired. This is best left to a professional camera repair shop.
Posted on Jan 23, 2010
    Problem Solver:
  • 8 Answers
My 730 wants to close but goes into jerky action instead of closing completely then it just shuts off.
At this time when the opportunity arises I will use a small phillips screwdriver on that side and attempt to take it apart and try to observe why this is happening. Repair is out of the question because for that money one can buy a newer technology. Things were not meant to be repaired anymore...how sad.
Posted on Jun 06, 2010
2 Suggested Answers
SOURCE: IR-300 Olympus
I had what sounds like the same problem. The camera was dropped and the shutter was stuck open. Just kept showing error message.
As I felt I had nothing to lose I began tapping it on a soft book and the shutter started to appear. I then shut it just using the end of my finger. When I then turned the camera on again it opened and shut when turned off. It has worked fine ever since.
Seems a rather poor design.
Hope this helps. Very best regards Peat.
Posted on Oct 20, 2008
Lens making strange clicking noise when turned on or zoomed in.
If the noise wasn't there for 3 days and is there now, it can only get worse. I would return it for a replacement.
Apr 27, 2010 | Canon PowerShot SD780 IS / IXUS 100 IS...
Lens makes grinding noise
yes dust in mechanism or broken gear but ti not easy
Oct 12, 2009 | Panasonic Lumix DMC-FZ5 Digital Camera
My Sony Cyper-shot 7.2 digital camera - the lens will not open all the way, it makes noises when I turn it on like it's stuck and it says Access and then to turn the power off and on again. Nothing is...
Hi, The message "Turn off the power and on again" appears when the lens block assembly start malfunctioning, Therefore you have to replace the lens block assembly. Thanks for using fixya.
Jun 08, 2009 | Sony Cybershot DSCW80 7.2MP Digital Camera...
Zoom error on finepixA400 camera
I had the problem with the lens being stuck out. I ended up pressing gently but with a lot of force and it collapsed while making some load clicking noises, I figured that I’d busted it, but I turned it off and back on and it worked great. I know it’s not a great fix but it might work for some of you.
Oct 19, 2007 | Fuji FinePix A400 Digital Camera
Frozen lens and shutter
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Sep 06, 2007 | Canon PowerShot A510 Digital Camera
Error-C1
Dirt /dust in the lens and lens gear box ( this drives zooming only ) preventing optimum functioning. Lens cannot properly come on line ( shutter and diaphragh mechanism then do not come on line ) and the camera switches off. Solution : is ether replace lens unit or dismantle lens to clean out ( from gear box and the helicoil of the lens ).
Sep 03, 2007 | Kyocera Finecam S4 Digital Camera
Sony Cyber-Shot DSC-S40 Digital Camera- lens is stuck
The lens assy. has gone bad if it is making noise. If it is only stuck and not moving the power supply link is broken and supply is not reaching the lens assy motor. May be the SMD fuse would have blown in power supply circuit. May be you can seek the service manual from me and this calls for highly skilled workmanship and tools.
Dec 16, 2006 | Sony Cyber-Shot DSC-S40 Digital Camera
Olympus Stylus 840 Digital Camera Logo
603 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
