Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Won't turn on! Green light one greenlight off!
Won't turn on! When I push the power button the green light goes on and a high pitched sound that sounds as if it is trying to start something up sounds and then the green light goes off. It repeats this three times and then quits.
  • RCA Master
  • 8,617 Answers
Replace the flyback Its the 259296 flyback available from www.tvrepairworld.com the kit contains the flyback, associated capacitors and ful instructions on CD
Posted on Nov 20, 2009
Computer won't turn on
this is only a guess sally yoour PSU need to be replaced.
Apr 09, 2013 | HP Omni Pro 110 XZ822UT AllInOne
TV has video for about 10 seconds after turning on and then about 5 seconds later audio goes and TV goes out - what is the problem?
Possible bad lamp, color wheel, or ballast.
Remove lamp and look to see if glass pillar in middle is straight and not bent from heat.
Color wheel faces the lamp--usually when or before fails you get a fan like or high pitched sound from it. Look to see it is not missing segments or shattered.
May 29, 2012 | Televison & Video
PS3 won't turn on. When I push the power button
Sounds like your system has a failure in it, that needs professional assistance. If you want your data saved you should try a place called www.videogame911.com. They do fast repairs and can save your data.
Jun 11, 2011 | Sony Video Game Consoles & Games
I plugged in my tower and i heard a loud high pitch beeping sound the green led light in the back was on but the power button turns green and the green led light in the back turned off there is no signal...
the green led light is it beside the network cable connector. if it is so, then it is always meant to be like that when you power up your computer. it is not something serious and it is normal.
Aug 18, 2010 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
I replaced the lamp im my vivitek 56 inch dlp tv. But it still wont turn on. The light goes from green to red and it makes a sort of high pitch sound then stops
my vivitek RP56HD22A 56" dlp tv has a new lamp and will not turn on. when i push the on button is whines and wont come on
May 24, 2010 | Vivitek V37655 56" DLP TV
Wont light up
the colorwheel needs replacing. if the colorwheel won't spin, the lamp won't light. if you hear a high-pitched whir, the colorwheel works, which means there is a power supply issue. there is a fix for that, but you have to be good at soldering. if you are give it a try: http://www.infocus.com/service/asc/communications/tech_notes/2006/09/tn495g.pdf
Oct 05, 2009 | InFocus LP70+ Multimedia Projector
I got a free sharp notevision PG-m20x. I plug it
if you don't hear a high-pitched whir, the colorwheel needs replacing. if you do hear it, the lamp may need replacing. if the lamp is new, there is a power supply problem.
Sep 04, 2009 | Sharp Notevision PG-M20X Multimedia...
When tv is turned on green light comes on then goes to standby
had the same problem on mine.
Found loose solder terminals on the main power transformer, resoldered fixed it up about 5 min.
Nov 01, 2008 | Pioneer SD-532HD5 53" Rear Projection...
Won't power on
my d52w19 chassis itc222 as posted most of the time wont turn on and the green light flashes three times every time it makes a small noise. sometimes it does turn on and you hear a little pop and the tv fires up.  latley there is a really high pitch noise that will slightly change pitch if you move the tv or put slight pressure on the top or botttom rear part of the chassis. thanks for the help as I have seen that this has been posted before without mention of the high pitch noise.
Aug 23, 2008 | RCA D52W19 52" Rear Projection Television
Flashing green power light on TV
have the power supply checked out sounds like it went out
Jul 09, 2008 | JVC AV-56WP74 56" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
107 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
