Question about 2wire (1000-000057-000) Modem
Are there updates or upgrades from 2wire pc portal so that it is compatible w/windows vista?
    Guru:
  • 1,738 Answers
There should be buy now, I would think. I would just do a search.
Posted on Nov 18, 2009
Vga card dell dimension 3100 not identefire for windows 7?
Have you upgraded your OS to Win 7? If so this is a common problem, use the Vista driver found here: http://www.dell.com/support/drivers/us/en/04/Product/dimension-3100 Have you done ALL the Windows updates? Take a look at changing the Compatibility of the driver . Download the driver and Save the file to a folder, Use this procedure to change Compatibility : http://www.howtogeek.com/howto/windows-vista/using-windows-vista-compatibility-mode/ For further assistance respond to this post.
Jan 10, 2013 | Dell Dimension 3100 PC Desktop
Drivers
I will recommend that you download and run the free Windows 7 Upgrade Advisor. It helps find issues with your computer’s hardware, devices that might affect installing Windows 7. Go to the Windows 7 Compatibility Center find direct links to drivers, updates, and downloads.
Apr 04, 2010 | Toshiba Satellite A300-ST6511 Notebook
Using 2wire 1800hg Home Portal. Have successfully connected with PC Port Adaptors using the existing telephone line. No problems. Then purchased a laptop w/ Vista installed. 2wire setup CD causes error...
Listen, you do not need that CD! This is already configured. That cd is for other types of troublesome operating systems that just cannot seem to get is DNS settings right such as windows XP. The cd is for XP only you do not need this with vista.
Thanks
Jul 18, 2009 | 2wire 1800HG Router (RG1800HG00)
2wire homeportal 1000hw cannot find wireless address
Windows 7 (Beta) and Windows Vista 64 Bit. Step 1. Do not allow the autostartup to run the installation application. You must right click on the CD ROM and select the "OPEN" option. Locate the driver on the install CD. Since my DVD ROM drive is my "D:" drive I located the driver at D:\USB_VISTA32364\BACKUP_2WIRE_VISTA_USB_Installer.exe . Before you click on this you want to right click on this and select Properties. In the properties tab click on the middle tab marked "Compatibility". Make sure you select the checkmark box to: Run this program in compatibility mode for: and use the pull down menu to select Windows XP SP2. This is how I was able to get my 2wire utility to work on Windows 7 (beta) 64 Bit.
Feb 07, 2009 | 2wire HomePortal 1000HW DSL Modem and...
I AM RUNNING VISTA CAN I GET UPDATED SOFTWARE FOR MY 2WIRE PORTAL
I UPGRADED TO VISTA AND NOW I CANT GET MY 2WIRE PORTAL SOFTWARE TO INSTALL. IS THERE AN UPGRADE OR NEW SOFTWARE AVAILABLE ? ► there is no need to install the CD if ur trying to connect using an ethernet cable to the 2wire. If ur attempting a wireless connexn, u shud configure the wireless set up.
1000 SW (Model) for 2wire,Connects fine, intermittently the Broadband Link goes ORANGE and keeps me off Internet ► this is a possible line problem. Try plugging ur 2wire's phone cable directly to the phone/wall jack removing the filter or splitter in the process. Then see if the problem reoccurs. If it DOES NOT, replace ur filter with a new one. If it DOES reoccur or if it is already connected to the phone/wall jack directly, contact ur Internet service provider.
keep me posted on these...
Dec 15, 2008 | 2wire (1000-400108-001) Router
Home portal not yet activated
XP is an very good OS which will connect with 2wire without any problem.
If your computer is not able to detect modem, pls follow these steps.
* Check for damage of ethernet cable
* Try to reset the modem by using a paper clip punching into the reset button
* Even if your modem is not detected, force the IP and Default gateway
Take care
Feb 26, 2008 | 2wire HomePortal 100W (1000-400026-000)...
2wire pc adapter
If you go to the 2Wire site you will see that only 3 of the seven adapter products listed there have Vista drivers.
http://www.2wire.com/?p=331
If you have one of the Vista supported products, make sure you have the Vista driver.
If you do not, get one that is.
Oct 14, 2007 | 2wire PC Port Phoneline HomePNA 10Mbps USB...
Can't connect to internet with 2wire PC port
yes U R right. this is most probably a "Driver" problem. You could try installing the software in "Administrator Mode".. with "Compatability Mode" set for XP. If this doesn't work.. then ya may have to try to contact the manufacturer and ask for a compatable driver for Vista.
Aug 31, 2007 | 2wire PC Port Phoneline HomePNA 10Mbps USB...
2wire (1000-000057-000) Modem Logo
119 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Bruce Silvernagle
Bruce Silvernagle
Level 1 Expert
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
