Question about Whirlpool GHW9400SU Front Load Stacked Washer / Dryer
Getting F22 code on Whirlpool Cabrio Dryer - what does this mean?
Getting an f22 on washer- what does this mean?
Posted on Dec 30, 2009
Whirlpool Cabrio Dryer flashing f22 after about 1 min of drying I have changed the exhaust Thermistor what else could be the problem?
Clogged lint filter and/or venting. Make sure the latter is squeaky clean all the way through even if it goes up to roof like mine did.
Sep 06, 2017 | Whirlpool Dryers
My cabrio dryer is overheating. I have replaced thermistor, thermostat, replaced control board but get f22 error code,
Dryers overheat because of reduced airflow. You need to fix that first. Remove the rear vent completely and check the hose for lint and birds nests. Check the flaps on the wall vent that they move freely. Then strip the machine down and clean all the ducting and the fan.
F22 Error Code
http://www.shopyourway.com/questions/1146749
Jan 24, 2017 | Dryers
What does code f24 mean on whirlpool cabrio dryer
Inlet Thermistor Open F-24 flashes if the inlet thermistor is open. This fault code will ONLY appear when in the diagnostic test mode. See TEST #4a.
http://dryernotheating.net/whirlpool-cabrio-dryer-error-codes/#F-24
Feb 14, 2016 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
How do I fix an f22 error code?
On the back of the blower housing(fan that makes air move through the dryer), there is a thermal fuse called a thermistor. The F22 error code you're getting means that this safety fuse has opened and must be replaced. The part# is 8577274 and is designated #40 on the exploded parts diagram. This is an INVOLVED repair. Most of the thermal fuses can be reached by removing the rear cover of the dryer and are located on the heater box. This one, however, is accessed by removing the entire front of the dryer, including the front bulkhead assembly to expose the blower housing. Here is the exploded parts view from Parts Select, their part# is PS993287 and costs 20 bucks and change, http://www.partselect.com/MultiModels.aspx?ModelNum=wed6600&searchTerm=&RefineSearch=0. If you aren't comfortable with this level of disassembly, DEFINITELY call for a service tech to do the repair!
Aug 18, 2015 | Whirlpool Cabrio 7.0 cu. ft. Electric...
What does F1 mean on a whirlpool cabrio dryer
You can google whirlpool cabrio dryer codes and find the code that you are looking for. I just looked it means your dryer is not heating.
http://dryernotheating.net/whirlpool-cabrio-dryer-f1-error-code/
Aug 02, 2014 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
F1 code on my Cabrio dryer
According to the manufacturer the "F1" error code means a primary control failure. The correction is to replace themachine control assembly. Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 12, 2012 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
What does the code F2 mean in the time window of the Whirlpool Cabrio gas dryer and how do I reset the machine?
Whirlpool Cabrio & Kenmore Oasis Dryer Error Codes
  • PF--Power failure
  • AF--Restricted air flow
  • F01--Primary control failure
  • F02--Keypad/User Interface failure
  • F22--Exhaust thermistor open
  • F23--Exhaust thermistor shorted
  • F24--Inlet thermistor open
  • F25--Inlet thermistor shorted
  • F26--Motor drive system failure
  • F28--Moisture sensor open
  • F29--Moisture sensor shorted
  • F30--Restricted air flow
looks like you have a problem with the touch pad,abutton could be stuck or not responding,you can try unplugging it,get to the computer board and unplug the ribbon from the touch pad,reconnect it and try it,this sometimes resets the touch pad,if it doesn't you'll need to replace the touch pad.
Sep 07, 2012 | Whirlpool Dryers
My dryer says f 22 what does that mean ?
F22 flashes if exhaust thermistor is open. The sensor is located on the blower housing.themobilian_12.png SEE PAGE 76
Jan 21, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
We have had our Whirlpool Duet Electric Dryer (front loading) for about 2 months. It is showing an error code of F22. I have no idea what this code means nor how to fix it.
the f22 code is a failed thermistor. you can try to change this yourself but if the unit is less then a year old then it will be covered by warranty.
the part is only about 30 bucks so if you can get one and find it behind the lint screen duct then you could change it and fix the problem.
Jan 06, 2009 | Dryers
Whirlpool GHW9400SU Front Load Stacked Washer / Dryer Logo
945 people viewed this question
Dan Webster
Dan Webster
Sal De
