Question about Hunter Dryers
We have a Hunter remote control system for our Hunter celling fan. The remote goes thru a new battery every three weeks. The remote Part Number is 86603-01. It's a 12 volt battery A23. Why does it use up batteries so quickly????
3 Suggested Answers
  • 3640 Answers
SOURCE: I have a hunter cieling fan controlled by a
you can call hunter technical support and they should be able to tell you why battery will not last. a bad remote etc. here is the number-- 1-888-830-1326, have a good day !!
Posted on Jun 07, 2011
  • 3 Answers
SOURCE: I have a 52
u have a short in that socket. don't put other bulb in there because you might blow the whole circuit if u keep doing that.
Posted on Mar 10, 2009
I have a Hunter Ceiling fan, with light, and remote control; the light has been failing for a few weeks, but not doesn't light up. It will flash, and you can hear a relay in the body of the unit clicking,...
You probably need a new receiver. Call 1-888-830-1326 with the model # of the FAN and order a new one. Also, If the light is rated for 40 watts don't put in 60 watts.
Sep 24, 2013 | Hunter Ceiling Fan Light Remote Control
Hunter fan 27185 has lost speed
Remote controlled ceiling fans can suffer a lapse of memory when there is a power outage. You eliminated the possibility of a dead battery in the remote by installing a new battery, but just to be sure remove the new battery and press all the buttons on the remote to eliminate the possibility of a stuck button then reinstall the battery. Next disconnect power to the fan at the breaker box, not a wall switch or by tugging on a chain. Turn the fan power on again. Using only the remote, check operation.
Apr 20, 2013 | Hunter Dryers
Hunter fan remote control 99600 not working
This must be a common problem, since I Googled the part number and it popped up before I completed the number. I am going to have to order a new remote, since I don't have a solder pen. Wish me luck.
Jun 22, 2012 | Hunter Dryers
Romote control is not working.there is a battery in it ,red light comes up but fan is not reponding.is there any way i can manually control the fan ,any button hided some where? or i can make sure remote...
normally in Hunter fans its not the controller but the receiver goes out, if your controller has a new battery and the receiver doesn't get the signal,, the fan isn't going to work, I've never been able to Locate Hunter receivers, tons of the remotes, you can contact them on line at this link
http://www.huntershoponline.com/cc_contactus.asp
Aug 26, 2011 | Hunter (25417) Ceiling Fan
Remote missing on a Hunter Ergonomic fan. do not know how to take the base cover or light cover to see serial number. light cover has screws with no slots. base cover has no sign of srew holding it up. How...
Purchase the remote control, install batteries, and try it before taking anything apart. If the new remote control does not work, the internal receiver may have failed.
Dec 07, 2017 | Hunter 21871 56'' Ergonomic Brushed Nickel...
FAN WONT WORK WITH REMOTE
Check the battery of the remote control, if it's week, change the battery. If still not working, bring it to a qualified electronic technician if they could still fix the remote control, if can't be fix buy a new remote control.
Jun 12, 2011 | Hunter 52" Ceiling Fan With Light And...
I have a hunter cieling fan controlled by a remote, part number 85094-01, FCCID IN2TX13. A replacement battery lasts about a week before needing replacing. I use the standard 12 volt eveready 23A cells. ...
Jun 07, 2011 | Hunter Dryers
Need diagram for hunter fan with light kit. Three
Black to black. from fan
Blue to Black and white. from fan
White to white. from fan
The input is from ceiling supply
the black wire from fan is for motor.
the black and white is for the light.
Jan 02, 2010 | Hunter 52" Ceiling Fan With Light And...
Fan and light suddenly wont work.
May be the receiver Call Hampton Bay @ 18005533199 have your UPC number ready
Oct 27, 2009 | Hunter Dryers
Our Hunter fan speed controller is not working. When we press high, it goes on high speed. When we press medium, it goes off. When we press low, it goes on high speed. When we press off, it goes off. Can...
Hunter's remote systems are notorious for failures. We replaced ours before the fan was one year old, and then it did it again within a year after that. The warranty, of course was on the ORIGINAL part, not the new part, so Hunter will never help you out, even though their remote receivers (the part in the fan) are junk!
Jun 30, 2009 | Hunter Ceiling Fan Remote Receiver...
Dryers Logo
547 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
