Question about Belkin F5D7230-4 Wireless Router
Laptop dissconnects offten and takes a while to connect
I hooked up my wireless g router by myself! wow!
and It's doing this thing where I get dissconnected from the internet on my laptop even in close range? So back to the problem...I shut down both computers and reconect all the router plugins and works for a while......I hope?
I did this without a cd cause we moved and had also comcast wich was not our other internet provider so even though you computer guys thing it's nothing! I proud of myself!
    President:
  • 2,653 Answers
Great job. Now what you need to do is make sure you are running the latest firmware version.
Try upgrading it by downloading the latest from Belkin's support site for your model.
Posted on Nov 29, 2009
I have Hughs net HN7000S hooked up to my desktop I want to use my laptop I have a netgear N600 how do I hook it up? As o WAP or router?
You connect the ISP modem to the main port on the Netgear router. You should now see a wireless network on the laptop.
Passwords / keys / paraphrases are located in the wireless part in the web admin to the router. Same thing for the user / SSID.
Jan 08, 2013 | NetGear Computers & Internet
Can't Connect Laptops Wirelessly to Linksys WRT54G2
1.Log into router (192.168.0.1) user name "admin
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the Desktop/laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
Jun 28, 2010 | Linksys Wireless-G WRT54GS Router...
My laptop connects to the router but the internet doesn't always work. The connection is perfect yet most of the time it won't go anywhere. Sometimes if I move the laptop around a few inches it'll work for...
Greetings,
If the laptop is hooked up by ethernet cable and the problem happens when you move the laptop, you either have a bad ethernet cable or a bad ethernet port in your laptop.
Probably the best thing to do in your situation is since you have a wireless router, enable wireless on your laptop and use that instead and work wirelessly.
Let me know if you need help setting it up.
Aug 31, 2009 | Belkin F5D9231-4 Router
My computer cant find my router
  1. Make sure your network cable from the modem to the router is good and connected to the uplink port
  2. If connecting directly try other port
  3. Check local area connection properties
  4. Double click "local area connection"
  5. On the middle box find and highlight "Internet Protocol ( TCP/IP) and click "Properties" button
  6. Make sure "Obtain an IP Address automatically" and "Obtain DNS server address automatically" are the only ones checked and click "ok" button
  7. Make sure "ethernet card" is NOT disabled
  8. Update ethernet card driver if necessary.
Wireless:
  1. Turn wireless switch on
  2. Check wireless connection properties and that Internet Protocol TCP/IP configuration is similar to the above
  3. On wireless properties select "Wireless Network" tab and Add your SSID (wireless network name) if not there and if there Move "Up"
  4. Update wireless card driver
Router:
  1. Double check to see that "Automatic Configuration" DHCP is selected
  2. Double check to see if "DHCP"server is enabled
  3. Check wireless network mode and select correct mode
  4. Check wireless channels and adjust as necessary
Jan 18, 2009 | Belkin (F5D7230-4) Router (587009)
My wireless-g broadband router WRT54G, is not letting my new computer (laptop) connect to it, it is asking for a network password and there is none...can you help?
wow i had so much trouble with these things... i called the people and the directions really dnt help... i would just call them... good luck
Dec 25, 2008 | Linksys Wireless-G Broadband Router
Want to hook laptop up to home computer via cable modem
You need a router or a wireless router to do that.
If your cable modem is wireless you can set directly via wireless network a connection with your laptop (the laptop also need a wireless card (if dont have any built in))
The connection must be done in this way
ISP ----->> Cable Modem ---->> Wireless Router o Router ----->> Computer ( 1, 2, or more)
Nov 19, 2008 | Computers & Internet
When i try to setup the security on my wireless router it dissconnects and will not let me connect again untill i disable the security settings
that is correct. When setting up wireless security in the router, do a wired or direct connection to the router first.
Nov 07, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I have a Belkin Wireless G Router. It is hooked up to the desktop. My laptop does not recognize to make wireless. I looked under network connections and the router is not listed.What do I do?
Network Connections are just for naming configurations for stuff. Configure your wireless network adapter and have it look for things to make a connections, and it can make you a 'Network Connection' for that Windows folder if you want. Otherwise just connect using the controlpanel for the device and be happy. Your router would not have WiFi turned on by default; that would be stupid and insecure. Read the fine manual and config the router from a wired connection to your laptop or PC so you can set up nice wireless passphrases and stuff.
Aug 02, 2008 | Belkin Computers & Internet
Hooking up to docking station
No, the laptop will have to have a wireless adaptor on it or in it to connect. The docking station is only good when the computer is hooked into it.
Jul 01, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Connection Not Consistent
You shouldn't have to run the setup wizard to reconnect. It sounds like you just haven't configured it to auto-connect to that wireless connection. Right click on My Network Places and select Properties. Right click on your Wireless LAN connection, and tell it to connect. You should be able to go through those settings and tell it to auto-connect to your router as well.
Sep 09, 2007 | Linksys Wireless-N WRT150N Router
Belkin F5D7230-4 Wireless Router Logo
61 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
