Question about Dryers
Washer will not spin out except when empty or very small loads
  • rexwarehouse May 11, 2010
    Hose or pump can be clogged. Have you lost any socks? Some washers have filter type pumps that need replacing after several years of use. Empty washer and take the back off and remove one side of the hoses to the pump and look inside if you can. A small mirror and strong light are recommended.
    Make sure the washer is empty or you can hurt yourself and ruin the washer if you lean it over to get to the pump. Hope this helps. If you are not handy with maintenance suggest you hire a professional.
  • 95 Answers
On what
Posted on Nov 18, 2009
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
Washer won't agitate
I would start by checking the belt on the motor could be slipping when u put full load in washer. also check that pulleys are not loose.
Apr 19, 2014 | Miele W1903A Front Load Washer
Washer will not drain, spin or agitate
If your washer has suddenly stopped spinning properly, you will notice that your clothes will be sopping wet when the washer is done. Typically, there is a simple reason for this problem that you can fix without calling in a professional.Check the drain hose to see if anything is plugging it. Sometimes small pieces of material go out with the wash water and become lodged in the drain hose.Check the lid switch. You will notice on the lip of the lid there is a small stem that hangs down. This fits into a hole on the top of the washer housing and tells the washer the lid is closed and it is safe to spin the load. If the switch is faulty or has been blocked, the washer will not agitate or spin.http://www.mrsuds.biz/
Jun 10, 2013 | Maytag Washing Machines
Will not spin or pump out water except when empty
If your machine is a FAV6800A or FAV9800A see if this post will help.
Clutch Fix
Jun 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washer will not drain and spin. Have checked the
If you have room and empty 5 gal bucket try to lower your drain hose to see if there is any water coming from. Other should be points on programer or small motor that spins programer.
Dec 29, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Will spin on empty, but not with load in.
  • this is like this we have to get a sattilite worker to put it under it to solve it
Feb 16, 2009 | Zanussi FJD1666W Front Load Washer
GE washer model #wle4000b1ww won't spin
This is joyce
You have a bad belt it wont pull the load.
thanks,
joyce
Feb 04, 2009 | GE WPRB9220D Top Load Washer
Dryers Logo
19 people viewed this question
Top Dryers Experts
