Question about NorStar CallPilot 100
No ethernet light - NorStar CallPilot 100
    Guru:
  • 1,738 Answers
Try a different cable
Posted on Nov 18, 2009
Is the ethernet light supposed to be amber or green for ZyXel p-600
Try it and see? Maybe it's amber because it not being used? Have you looked at this forum: http://forum.pinoypc.net/index.php?topic=36197.0
Dec 14, 2012 | Computers & Internet
How do I get my Ethernet to work again?
Do you have the Ethernet Cable Plugged in? If so look where it plugs in at and see if you see a light. If you see no light then either the ethernet cable you are using is bad or the ethernet card in the computer is bad. I would try changing the cable first since it is the cheapest. Hopefully you have an extra one around the house someplace. If after changing the cable you still get the Ethernet Not Plugged In message again, then your Ethernet Card inside the computer needs to be replaced.
Mar 14, 2012 | HP TouchSmart Computers & Internet
When I connect my modem to my laptop, all the lights come on except the pc link light. I have already unplugged it and reset it and it still doesn't work. What more can I do?
If the ONLY light not illuminated is your PC link light then that generally indicates a physical disconnect between the modem and the laptop. If you can get the PC link light to light up when connecting to any other device (computer, router, anything), then you are most likely looking at the ethernet jack on the laptop being burnt out. Otherwise, try swapping the ethernet cord. If a different ethernet cord does not resolve the issue and the PC link light does not come on no matter what the modem is plugged into, you are looking at a faulty ethernet jack on the modem.
Aug 17, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Ethernet lights not lighting
Make sure your ethernet cable is not damaged in any way. If you have a secondary ethernet cable somewhere around your house then try it with that. Ethernet lights light up only when there is a power signal coming from either side of the cable. Most likely one of the wires inside the cable got damaged and is not letting the router know that it has something plugged into it.
If you dont have a secondary ethernet cable then switch the cable that comes out of your internet modem into the router with the suspect cable and see if you get a internet light on your router. You can further test this by directly plugging into your computer and see if it gives you a connection of some sort. If your computer continues to say that there is no network cable plugged in then you have a bad cable.
Apr 15, 2011 | Linksys WRT160N Wireless Router
I cant install my router. The internet, power, WLAN, and DMZ lights are all on, but none of the Ethernet port lights are on, but when I try to complete the install I get the following error message: Unable...
If the ethernet light is not coming that means your router is not detecting your computer. Try to plug the computer on any other port.
To check if your ethernet ports are fine you can perform a loop back test. You can take a cable which is not connected to anything. Than put one end of the cable to one ethernet port and put other end of that same cable to any other ethernet port. If the light on the ethernet ports led up means your ports are fine and u need to reinsatll the drivers of the ethernet card on your computer. Else your routers ethernet port are not functioning. If that is the case you can try to reset the router.
Let me know your finding.
**If this works please rate else let me know in case of further help.**
Jul 03, 2010 | Linksys Wireless-G WRT54G Router
Ethernet connection appears not to work, though Windows XP device manger says the device is ok
Try to use a known good ethernet cable. Check if lights at the ethernet card is lit up. check also on router if the indicator light will lit up when you connect the ethernet cable.
Mar 23, 2010 | Dell OptiPlex GX260 PC Desktop
Ethernet LAN light goes off after few seconds
when the booting all light are turn on that's normal , after few second ethernet light momently on because ethernet chip internaly loop and check the ethernet chip that why you seen the ethernet light momently on after that ethernet should lit on if you connect router ethernet link to pc or ethernet switch.
pls check the ethernet cable , if you connect to ethernet switch pls try with cross over cable and if you connected to pc pls check duplex to auto or forced to 100 Mbps
Oct 13, 2009 | Cisco 857 Router (CISCO857K9)
Ethernet light went off and won't come back on
I had the same problem. It seemed the modem reset and the address changed. I called my ISP (Verizon) and explained the problem to them and they had me online in no time.
Hank
Aug 21, 2009 | Computers & Internet
Not finding ethernet connection
please make sure that there are 2 lights on your ethernet port,maybe your ethernet port is bad,please chack on your modem if ethernet light is on or blinking,check cables
Jul 05, 2008 | Packard Bell Computers & Internet
NorStar CallPilot 100 Logo
83 people viewed this question
Top NorStar Computers & Internet Experts
Computer Links
 Brian Main
Brian Main
Are you a NorStar Computer and Internet Expert? Answer questions, earn points and help others
