Question about Kenmore 659 Electric Dryer
Kenmore dryer heating coils stay on when dryer is off
When the dryer stops the coils stay on w/ door open or closed.
    Sniper:
  • 88 Answers
That's no good....hopefully your house is still standing. Your coil is shorted to ground, so there is constantly 120v being applied to the heating element. It won't get as hot as when running, but because there is no airflow it poses a serious fire hazard.
Posted on Jan 17, 2008
Light stays on even with door shut, kenmore he2 dryer
The door switch would be the first suspect... make sure the wires are in the proper sequence... does the light go off when you open the door? the tech sheet should tell you what color wires go to which terminals
Apr 27, 2016 | Kenmore Dryers
Kenmore Dryer stop heating, is not warming up.
It sounds like the heater coil is defective. You can purchase replacements at Sears. They are not teriibly hard to replace but if you don't feel comfortable, Sears can install them.
Lou
Sep 24, 2008 | Dryers
How to replace a heating element on a Kenmore Elite Oasis ST dryer
Sounds like you need to replace the timer one the dryer not the element but to make sure I would do a little trouble shooting to rule out the element or heating coil turn on dryer cycle like normal for about 30 seconds then open the door to feel for heat if you do feel heat its your cycle/timer knob if you don't feel heat then it's the coil or element witch are the same also first always check your lint trap and ducts going outside the dryer make sure you have proper airflow through ducts vents. clogged vents ducts ect. Cause over heating of element coil causing a safety fuse to shut down heating coil/element but will not stop cycle also moisture censors detect moisture causing cycle to continue on hope this helps.
Sep 04, 2014 | Kenmore Elite Oasis 6808 Electric Dryer
The dryer door always pops open stopping the dryer... how do I make it stay shut so the clothes will get dry without having to close the door every other minute?
Try putting less of a load in dryer. The weight of the clothes riding against the door, may be the reason why it pops open.
Apr 05, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
9 yr old Kenmore 90 series dryer wont heat
is it gas ? next time open dryer door and send full model number if it heats for a while you have bad gas coils,when you change them out watch out for the coil with three prongs on it,there is a metal piece that sometime gets stuck in old coil when you remove it,if it happens just poke it out of old coil and slide it back on post where new coil will be installed
Nov 07, 2009 | Kenmore 63942 Dryer
Kenmore electric dryer heat stays on when door open
Sounds like your thermistor/thermostats could be your problem.
They control the heat coming from the heating coil.
Unplug the dryer.
If you remove the back of the dryer, look for the air tube coming from the blower to the drum, normally inside the air tube you will find the heating coil and the thermistor/thermostats. Replace as needed.
Good luck,
Hope this helps
Oct 05, 2009 | Kenmore Dryers
Heating coils are not broken and will not turn of
check the capacitor next to the motor it will have 2 wires coming off it this can stop the drum turning
shaun
Feb 02, 2009 | Kenmore 98702 Stacked Washer/Dryer
Must hold start button to run. no heat
disconnect power and remove lid. Test the door switch w a volt meter do so opening and closing the door not pushing switch if circuit stays open try pushing switch with finger. If pushing closes circuit then adjust switch.If circuit stays open replace switch. If switch operates with no problems then it is the motor. Check all connections and vacuum lint from motor
How old is this dryer?
Dec 30, 2008 | Kenmore Dryers
Intermitten Heat up
make sure that your vent is not plug up can you go outside your house and feel good air coming out the vent when the dryer is turn on if so the only other things it could be is the coils that sit on the ignotor assmebly or the high limit termistat is not working properly the coils are little black circle coils that sit in the ignitor assmly should have a metal braket across the top of them holding them in you can check resistance on these coils if you have an meter
Mar 22, 2008 | Kenmore 72802 Gas Dryer
Kenmore 659 Electric Dryer Logo
74 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
