Question about Electronics - Others
Looking for the instruction booklet for the PEAK PERFORMANCE PKCOAX 2000 WATT POWER INVERTER anyone know where I can get one
  • 244 Answers
Check at vectormfg.com for owners.
Posted on Nov 18, 2009
Instruction manuel for pkcoaw
turn off the things u have pluged into it before turning on inverter
Jun 03, 2012 | Peak Performance Peak PKC0AW 3000 Watt...
My inverter keeps going to falt even though i only use it for a few seconds its only a few months old and has not been used mush its a 1000 2000 max
What are you trying to power with the inverter? Do you know how many watts your appliance need to run? Your 1000 watt inverter needs 83 amps from your battery to drive a 1000 Watt appliance. The minimum size wire you need to hook up the battery to the inverter is a size 6 as short as possible but no more than 25 ft.
Jul 28, 2011 | Inverter 1000-2000w Peak Surge Power
Does peak 100 watt inverter have a fuse inside? It is brand new & i can't make it active.
yes it does have a fuse inside where you plug it in the lighter should have a metel tip on the end will be spring and fuse inside behind metal tip
Jul 04, 2011 | Peak Performance Peak PKC0AM 100 Watt...
Have a coleman 2000 watt 24v dc power inverter. When using it for a short period the temperature light and alarm sounds. The can just be a tv. The watt meter on the panel don't event light up. What the...
If you are only tring to run a TV off this inverter, it appears you may have a defective unit. If you have had this inverter for only a short time, contact the dealer/store where you bought it and seek their advice. If you have had it for 90 days or more you can still contact the dealer, but maybe it would be best to contact the coleman company. You can go to their website nad find out how to contact the division that deals with this particular type of product.
Mar 23, 2011 | Coleman Cable Coleman 1000 Watt Power...
What size fuse goes in this item
The fuse you wilkl need to p-0rotect this unit is rated at 50amps
Please rate my help++++Thanks for using FIXYA
May 27, 2010 | Peak Performance Peak PKC0AM 100 Watt...
My inverter is in alarm and won't produce 110 power. Checked input voltage and it is correct.
I have had this happen a few times.
Sadly replacement is the Best option.
Repairs can be %75 the cost of a new one.
The best invert we have been using is a Pure Sine 1500 watt inverter.
Sad news but hope this tip helps.
R/
David
Jan 26, 2010 | Coleman Cable Coleman 1000 Watt Power...
I just bought a RoadPro 2500 and i want to buy like a dorm fridge how many watts or volts size would work??
If you are referring to the RoadPro RPPI-250
  • 2000 Watts Continuous Power
  • 2500 Watts Power Output @ 10 Minutes
  • 5000 Watts Peak Power Output.
  • A small fridge will use about 500 -700 watts, with startup wattage at around 2000watts.
  • So, a dorm fridge will work fine.
  • the RoadPro converts DC to AC voltage, so a regular 120 volt dorm fridge will work.
  • Jul 05, 2009 | RoadPro RPPI-2500W Inverter
    Need small microwave for inverter on houseboat
    Look at the rating sticker on the oven and use the AC power rating as your guide. The cooking power of the oven is not important, but the power it needs from the AC supply is. Voltage times current is the supply power needed (watts), and you want an oven that will draw less than the inverter's continuous rating, less any power being used by other appliances.
    For instance, a microwave rated for 120 volts AC at 10 amps needs 1200 watts. Your inverter would be OK with this as long as other devices aren't using more than another 1000 watts. You can't use the inverter's peak rating. That's only for brief bursts, like when the microwave first kicks on and draws some extra current.
    Any mid-power (600 watts or so) oven should be OK.
    Apr 16, 2009 | Emerson MW8627W Microwave Oven
    Low voltage output from inverter
    I am thinking this a high impediance device problem and this is normal operation - the user manual of my inverter warns about use with high impediance devices - if not I am interested also...
    Jan 23, 2009 | Electronics - Others
    Electronics - Others Logo
    284 people viewed this question
    Top Electronics - Others Experts
    Are you an Electronics - Other Expert? Answer questions, earn points and help others
