Question about Samsung SyncMaster 152N 15" LCD Monitor
My monitor is almost black, i can faintly see what is on the screen it doesn't help if I try and change the brightness of the monitor
  • 115 Answers
There are a problem with VGA (Graphics port) in CPU .Pls check your CPU on another Monitor or vice versa.Pls call vendor for repair the Motherboard if Graphics card inbuint on the Mother otherwise get it replaced the Graphics Card.
Posted on Nov 18, 2009
My moitor is powered up but the screen is showing black. I can see very very faint words.what is the problem
chect your bright and contrast controls if they are ok
replace the cold cathode tube power inverter circuit board; it's under the center bottom of your monitor screen
Nov 18, 2013 | HP Pavilion F1503 15" LCD Flat Panel...
I have lenovo g550...my screen flickers in every 5minutes...
Failing Inverter An inverter, typically found inside a laptop computer, consists of a small board, which has impregnated electronic circuits stamped on it. Inverters look like thin boards about the of two sticks of chewing gum. The inverter and its bulb control the intensity of the liquid crystal display, which lights the screen monitor. The computer can control the output voltage of the inverter and either lighten or darken the screen. A special type of inverter can adjust the brightness of the screen by using an internal sensor to judge the room brightness, and then adjust the screen accordingly. Failing inverters give off some specific warning signs, which can be recognized by observing different screen characteristics.
Short Intermittent Display Upon turning on the laptop, the screen flashes on in the normal mode for a short period and then blinks to black. A very faint image appears in a dark background, which will be very hard to see almost invisible. After shutting off the laptop and restarting, the same mode occurs, where the screen appears normal for a few seconds then fades to black. This condition points to a failed inverter. To confirm this, plug in an operational external monitor; if the external monitor functions, the inverter has failed. b> Total Blackout with Ghost image b> The laptop turns on, as indicated by the power supply button, but the screen comes up black. The screen comes up black after restart. You might be able to detect a very dim or ghost-like image on the monitor. When you plug in a known functioning external monitor, the external monitor operates normally. This mode of display indicates a failed inverter. b> Long Term Periodic Operation b> With this failure mode, the laptop screen illuminates normally upon start-up and remains that way after several minutes, hours or even days, until it goes very dark again. Brightness controls or restoration attempts do not work. Most often, the screen will function normally with a computer restart, but will eventually return to black. Faint ghost images might appear, as seen in the total blackout mode. b> Dark With Color Variation b> Upon computer start-up, the monitor shows black or dark gray, accompanied by very faint images. The screen might have an intermittent color change, or remain on with a non-standard color variation, like pink or red. b> Auto Control Switch b> If the screen appears black, with no faint or ghost images, look for the lid switch near the back hinge. The switch, when depressed with a closed lid, shuts off the computer and monitor functions. Sometimes the switch becomes stuck in the closed position, disallowing the computer and monitor to turn on when opened. Pushing the switch manually several times can often free it up. If the switch tab has broken or jammed inside the case, it needs replacing. b> Loose Connection In this mode, the display looks normal upon start-up, but tapping the side case of the computer turns the screen black. More tapping results in the screen functioning normally then cutting out again. This condition points to a loose wire connection from the inverter to the LCD backlight lamp, or the video cable. The connectors can be accessed by removing the monitor bezel screws and pulling the plastic retainer off. Both connectors can be cleaned and refitted.
Feb 10, 2013 | Lenovo G550 PC Notebook
Screen went black faint images
If the screen went black and you can still see faint images of what your computer is currently showing, the typical issue would be a burnt out backlight. For the repair cost, I'd say just invest in a new monitor.
Just to cover the bases, make sure your brightness and contrast settings on the LCD are not set to zero.
Regards, Chris
Jul 01, 2011 | X2Gen Computers & Internet
My screen is extremely bright/white , difficult to
try to use the auto adjust button. if it doesn't work you have to go to the nearest service center in your place
Jul 18, 2010 | HP L1720 17 in. Flat Panel LCD Monitor
Display Shows on External Monitor, but very faint
one of two causes : inverter board damage ( Replace it) or backlight lamp damager (also replace it).
May 09, 2010 | Toshiba Satellite A135-S4527 Notebook
Screen is black and light is blinking. I tried
Can you see a faint image on the screen, if so your back light is failing. If you cant even see a faint image and is flickering then the inverter board is faulty and needs to be changed. You can search the internet by doing a google search for the make and model of your monitor and find spares, there should be some good videos on youtube on how to change the inverter.
Feb 09, 2010 | Computers & Internet
The on off button on front doesn?t turn the unit off and on
Same here, your light went out if you put a VERY bright light on you'll be able to see something on the screen if you plug it up to your computer, if you are getting a new one go dell its worth it becase they last and are durable.
Jul 03, 2009 | Gateway FPD2275W LCD Monitor
Emachines model 780 monitor comes on for one second then goes blank
CANNOT COMPUTE!!!! NEED MORE DATA! Is your monitor the problem or the computer? Try connecting the monitor to another computer. You can also try connecting a laptop with an external video adaptor to the monitor to test it.
Oct 12, 2008 | E-Machines eMachines Desktop PC
Sony SDM-HS74P/S 17 - Monitor won't stay on the right picture
When the screen turns black again take a flashlight and shine it in the bottom left hand corner where the Windows Start button is located. If you can see a faint image then your back light is failing. If that?s not the case the next step would be to attach another monitor to your computer to see if the problem disappears. If it does that points to the monitor, if it doesn?t then we need to take a look at the computer itself. Let us know what you find out and please don?t forget to rate this posting.
Mar 16, 2007 | Sony SDM-HS74P/S 17" LCD Monitor
Samsung SyncMaster 152N 15" LCD Monitor Logo
147 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
