This problem should be removed because:
Problem with Hitachi 50VG825 50 in. HDTV LCD Television
tv is dark. green is very dominant color
I just inherited a used hdtv the screen appears dark. Also noticed green is very dominant color as compared to others. Its not real clear, but we dont have high def input. Very low light in tv room.
Suggested Solution (1)
You will need to replace the lamp. That is the only thing that will cause the picture on a DLP to go dark. Please take a few moments to rate my answer. Thanks....
Hp 42 plasma tv cptoh 0602 specs all the time and...
Two problems. First I'm getting specs on the screen white ones. Mostly notable on dark colors on the screen. Seems to...
my high def component 1 and 2 just blink on and
my samsung spn 4235 42inch plasma high def component 1 and 2 just started off being intermitten problem with the picture cutting in and out....
band of dot's(millions) across screen only...
band of dot's(millions) across screen only whilst watching in hd mode and whilst using any menu option such as volume etc. dot's not...
I bought a Sanyo 26 in lcd hdtv 7 months ago. No
I bought a Sanyo 26 in lcd hdtv 7 months ago. No real problems until I tried to hook up a coaxial cable to see what local channels I could...
Monitor dims when we turn lights off in room.
Tips for Helping obrionusa With Their Issue
- Give detailed step-by-step instructions
- A picture or video is helpful
- Use plain language not industry jargon
- Check spelling & punctuation
Add Your Solution
Hitachi 50VG825 Tv Guide menu stuck on.
Tv Guide menu will not go away, and only power and volume buttons work on console but thats it cant get it to do...
our Hitachi 50vg825 shuts itself off and then
our Hitachi 50vg825 shuts itself off and then turns back on after a minute. What is the problem. The manual does not...
50" inch HDTV LCD Hitachi Digital Projection ...
50" inch HDTV LCD Hitachi Digital Projection the blue dosnt show anymore
My tv will not save its settings after I turn it
My tv will not save its settings after I turn it off, what can I do to fix it?
Related Topics
Fix-O-Meter
56
56 people viewed this problem
- 0 people are following this problem. Be the first!
Top Hitachi Flat Panel Television Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
