Question about Samsung L200 Digital Camera
Which end of the usb goes in the camera to charge it
My camera ES90 will not charge, when i plug it in it seems dead
There can be more than one reason:
The battery can't be charged anymore, because it is defect.
The cable you use is defect
The charger you use is defect
One or more contacts are dirty or oxidised
Carefully check all contacts on the battery, in the camera the battery compartment but also the USB slot, where the charge cable goes in. The contacts should be clean and shiny. No contact should be bent. Cleaning with a dry cloth or cotton swab.
If the cable to charge is defect it is more difficult to detect. Only when you have another apparatus that can be connecter with the same cable, you could check if your cable is still in working order.
The charging source can be defect.
If it is a charger, you plug in a wall socket, check if you can use it to charge something else. If you put it in a PC, also check if that USB port can deliver 5 volt with enough current.
I do have a little gadget, from the beginning of USB and LED lights. An USB plug with a small cord and a LED light on the end of it.
You could use it as a reading light on a laptop. But it showed very helpful to show if a charger or a USB plug on a computer still is delivering 5 Volts.
I hope you find the culprit.
Success
May 26, 2014 | Samsung ES90 Digital Camera
I need to know what the charger looks like. does it take batterys? where do they go? how do I charge the camara?
You can purchase a charger for this camera at http://www.amazon.com/Wall-Charger-Adapter-Vivitar-Vivicam/dp/B003M6BXBO/ref=pd_sim_e_1
Feb 28, 2011 | Vivitar ViviCam 8025 Digital Camera
I have just bourght a vivitar vivicam 8025 digital camera it cam with 2 plugs i put the battery in and memery card and it works i know one end is the usb i know it either plugs in the computor but the...
The USB socket is toward the bottom on the left end of the camera (as you view it from the rear). Take a look at the illustrations on page 5 of the manual.
You can charge the battery either outside the camera using the supplied charger or inside the camera by connecting the camera via USB to a powered port. Be aware that not all computer USB ports put out enough current to charge batteries.
Nov 05, 2010 | Vivitar ViviCam 8025 Digital Camera
How do i import pictures from my samsung memoir camera? is there a difference between the charging cable and a usb flash cable that connects from cell phone to computer?
The charging cable is different from USB flash cable. You can go through the booklet provided with the phone and it will show the diagrams of the cable and their part no. The charging cable has the two pin plug on one end whereas the USB flash drive cable will have USB heads on both ends, one which goes in the phone and the other which goes in computerMake sure that you down load the software which comes in the CD (which came with your phone) on your computer.
Sep 06, 2010 | Cameras
The manual says "your camera comes with a compatible charger, your only required to put the battery into the charger and charge the lithium battery directly from the outlet" The camera came with an AC...
You put the battery into the camera. Put the USB end from your computer cord into the end of the AC adapter hook it up to your camera. Ta-da! Everything should be working smoothly in the battery/charger department. :)
Dec 26, 2009 | Vivitar ViviCam 8025 Digital Camera
Panasonic vx37
My old Panasonic Palmcorder IQ shows a red light in both switch positions-camera and VCR. Maybe yours has red for camera and green for VCR so you could tell them apart. I found that the Panasonic battery that came with the camera was the cheapest kind with the least charging time. I bought other batteries, they were good for a while, but now, many years later, they won' t hold a charge. Since I am only recording inside of my house, I have resorted to using the AC wall socket for power. I have to take the battery out of the camera. I found a power plug-in hole (like ones on cell phones) in the battery compartment. I also found one of these holes on my battery charger. My camera came with a double ended power plug. I plug one end into my camera and the other end into the battery charger. I plug the charger power cord into the wall outlet, and I have power to my older camera. Maybe you can find this double ended power cord at a store or on line.
Did you know that there are 2 kinds of batteries? Some have memories and others do not rely on a memory. The ones with memories have to be fully discharged or they will only charge a little, and keep charging less and less each time they are charged. The ones without the memory can be charged fully without being discharged fully. Check into battery information on line to get more information. Maybe you can get the non-memory kind.
May 18, 2009 | Panasonic NV-VX37 Mini DV Digital...
Sony DSC-W170
Your Sony Cyber-Shot DSC-W170 came with a cord that had a little flat plug on one end and three separate plugs on the other end.  The single plug goes into the bottom of your camera.  The end that has three plugs has
(1) USB
(2) video output
(3) audio output
(2 and 3 are for hooking up to your TV)
If you connect the USB end to your PC and the single, flat plug into your camera, this acts as the USB cable.  There is no USB plug on the camera (for just a USB cord).
Feb 23, 2009 | Sony Cyber-shot DSC-W170 Digital Camera
Charging
It should have come new with some charge on it. There is a 12V to small USB cord that comes with it. The USB port on the device is small and on the back, plug one end of the cable there and insert the other end in a cigarette lighter in auto or truck. As an option you can charge from any USB port on a computer, but you need an optional cable that goes from standard USB to small USB. This is the same cable used on a lot of digital cameras, so you may have one. Just plug it in for a few hours.
May 25, 2008 | Garmin nuvi 200W GPS Receiver
Jazz dv179
The Charger has a standard two pronged plug to go into the wall. The other end goes into the camera at the back bottom. You will see the female received for the male plug.
Dec 18, 2007 | Jazz DV-179 Digital Camera
Samsung L200 Digital Camera Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
