Question about Frigidaire PLMV169DC Microwave Oven
Have a frigidaire PLMV169DCA- it will not heat and makes a loud roaring sound. If you enter power level zero it doesnt make the noise. Only 1 yr old.
  • Eric Duda
    Eric Duda May 11, 2010
    Sounds like a shorted Mag or bad Cap/Diode in the High Voltage circuit. Mag may have a warrenty longer than a year, consult your manual.
    Eric
  • 2336 Answers
SOURCE: I have Frigidaire microwave (PLMV169DCA).
You will need to replace the magnetron.
Check this website for more info on the magnetron.
Posted on May 16, 2008
  • 13433 Answers
I suggest you get it repaired - if you have warranty that is.
Might be cheaper to buy a new microwave, not sure on how much the parts would cost.
  • 38 Answers
SOURCE: My Frigidaire over the stove microwave not heating food
Hi,It is most likely the magnetron and diode that has to be replaced. This job should be done by a tech, High voltage. Magnetron's normally have a five year warranty, check your owners manual.
Posted on Mar 20, 2009
  • 670 Answers
SOURCE: My Frigidaire microwave is less than a year old.
The symptoms of loud noise and no heat indicate a short in the magnetron or high voltage diode. Need to take it to a qualified repair, to figure out what the problem. The magnetron replacement can cost as much as a new oven. See what the warranty covers, maybe you might luck out.
Posted on Dec 07, 2010
SOURCE: My Frigidaire microwave model# PLMVZ169GCC
Intermittent load noise (usual intermittent pulse noise is exaggerated) and the food is not heating though everything else seems to opperate normally: The Triac or Diode is capute.
You need to replace this part (@$30), but first need to discharge the capacitor, which is dangerous. I am going to give it a "shot", and not a "shock", all the punn intended. I will use an long insulated screw driver to touch both of the 2/3 tines of the adjacent capacitor, which will give a load "POP!" 2-3x to insure the stored energy is diffused.
Then, hopefully, simply replace the longe wire diode.
TaDa!
Posted on Feb 26, 2011
My Whirlpool microwave over-the-range oven makes a loud roaring sound when it turns on and won't heat.
Sounds like it could be a bad magnetron. The roaring could be a shorted mag or possibly a mag arcing in the wave guide If it is arcing in the wave guide, better to replace the unit.
Nov 01, 2017 | Microwave Ovens
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
Frigidare plmb186cc
Good Afternoon Friend,
I understand that you are noticing less noise, after about a second of starting your Frigidaire microwave, model# PLMB186CC. I suggest checking to see if the power level was changed. The blower sound will be different at levels other than "HIGH". As long as it is still heating, there is no cause for alarm. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 24, 2014 | Frigidaire Microwave Ovens
Frigidaire FMT118EPB microwave - is about 13 years old - makes loud venting noise and won't heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 22, 2011 | Frigidaire FMT118EPB Microwave Oven
My 3 year old frigidaire microwave made a loud pop and stopped heating. Everything else works. It also now makes a loud humming sound while running.
heatman101 ][
\=-0-]
Apr 02, 2011 | Frigidaire GLMV169D Microwave Oven
My Frigidaire microwave is less than a year old. It is making a loud noise while running. So it runs loudly but does not heat up food. Is there a simple fix or did I get a dud?
Dec 07, 2010 | Frigidaire FGMV174K Microwave Oven
Microwave makes loud noise and does not heat. Smell of light burning
Chances are you have a bad magnetron.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 24, 2008 | Microwave Ovens
Frigidaire PLMV169DC Microwave Oven Logo
187 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
