Question about Rheem Paloma PTG-74PVN / RTG-74PVN Natural Gas Indoor
Problem for Rheem Paloma PTG-74PVN / RTG-74PVN Natural Gas Indoor... What does C2 11 error code mean on my Paloma
    Sergeant:
  • 399 Answers
Hi pete here ill try and help this could be 2 things check the sensor on the unit the outher one is a qustion has the gas company changed your meter latley and turned off you gas and not come back to light your poilet because this code also means not enough gas or wrong type of gas
Posted on Nov 18, 2009
    Problem Solver:
  • 12 Answers
Rheem, Richmond, Ruud, and Paloma are all the same manufacturer. After about 9 months, my tankless RTG-74PVN started giving me error code 11 and cold water!. I fixed it by cleaning the burner, as shown in this video:
www.howtolou.com/clean-a-burner -Lou
Posted on May 30, 2012
Error code c7 and 12 on an ecosense natural gas water heater
Before calling service technician, copy following link for ecosense tankless troubleshooting resources.
C7 is communication failure with remote, and C12 is flame failure.
Multiple error codes could mean bad circuit board, loose wire, low gas pressure, or simple communication problem with remote control.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Jul 24, 2012 | Rheem Paloma PTG-74PVN / RTG-74PVN...
What does error code C2 11 mean?
code 11 means there is not enough gas
is this a new install?
do you have at least 3/4" gas line to the unit?
Aug 28, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Indoor Paloma water heater showing error message C2 31 - there is no hot water. Any idea? Model #: PTG-74PVN
that is the water inlet temperature sensor fault.. check and clean scale from sensor or have it replace by a qualified technician
Jul 18, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
I have a Paloma tankless water heater with an error code of E12 followed by 80 any ideas?
the code 81is a gas cut off failure..it could be a gas control valve problem...i don't know what the E12 is so you would have to contact rheem
Jul 17, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
What does code c4 and c12 mean
Contact Paloma/Rheem customer (800-432-8373) or refer to your owners manual troubleshooting guide.
Nov 17, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
I am getting error code AO and the temperature
its most likely diplaying a code... is it code 21? that usually will follow ao. first make sure the door is securely on, if not make sure it contacts the switch
Nov 14, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
I have a Paloma PTG-74PVN and I ain't getting any hot water and its showing c2-11 error code. How can i fix this problem
could be overheat stat or fan check the little hose at the fan area for pinhole next choice diaphrapm valve then micro switch best of luck
Oct 23, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Error code LO 76
check control connections and if good contact Rheem at 800-432-8373 for a new control board
Sep 04, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Did anyone ever find out what the C7 76 Error code is? I am having the same problem with my Paloma Tankless Water Heater
76 error code is faulty wireing to the controller or the controller is bad , if that is not it. it means the printed circuit board need to be replaced
Jun 22, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Rheem Paloma PTG-74PVN /  RTG-74PVN Natural Gas Indoor Logo
1,137 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
