Question about Maytag PYE2300AY Electric Dryer
Wont get hot
My maytag dryer will run but will not heat
  • 986 Answers
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Posted on Nov 18, 2009
Wont get hot and dry clothes
If the dryer runs the same as before except it will not get hot then check your heating element that is more than likely your problem.
Sep 04, 2012 | Maytag MDG6400 Atlantis Gas Dryer
Dryer not venting hot air out side
disconnect vent tube, and clean it out with a vacuum or blower.
Run dryer while vent is disconnected to ensure it is not the dryer if it is the dryer, check these things:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Nov 27, 2010 | Maytag Dryers
Dryer not heating
There is a heating element or thermal coupler that go out on Electric dryers.
May 29, 2010 | Maytag MDE2400A Electric Dryer
Dryer wont get hot
check thermal fuse
Jan 21, 2010 | Maytag Dryers
My maytag dryer heating element gets hot but motor will not run
Sounds like you have something shorted out.
The element issue could be a contact fused shut.
With both problems I would be looking for wires melted together, or a relay/sequencer welded shut melted etc.
You do have a potential fire hazzard here. If after removing the panel you cannot locate the problem, do not run the unit.
Oct 20, 2009 | Maytag PYE2300AY Electric Dryer
Maytag neptune running very hot, even on lowest heat setting
your cycling switch or hi-limit switch is defective they are near the heating element inside the dryer
Sep 01, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag gas dryer wont heat
Since your hot surface ignitor is glowing, that means it is trying to heat, or that all the temp. switches are good and the timer is sending the signal. First check that there is actually gas pressure to the dryer. But the common problem is the coils on the gas valve. There are two, called the booster/holding coil, and the secondary coil. They are purchased as a set (part #279834 / $20.00) if it is the same as my mdg8600aww model. If that doesn't work, then likely the gas valve itself.
Sometimes those coils will open circuit when they warm up, and close when they cool down, giving you an erratic operation symptom.
Mar 28, 2009 | Maytag MDG2706A Gas Dryer
My Maytag Dryer Wont Heat, Im an amateur repairman
Inside the dryer on the bottom right corner.
Mar 10, 2009 | Maytag MDG6657BW Gas Dryer
Maytag dryer no hot air
check power supply and make sure you have correct power. It will run with only 110 volts but wont heat. If good check heating element, thermal fuse.
Jan 05, 2008 | Dryers
Maytag PYE2300AY Electric Dryer Logo
372 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
