Question about HTC G1
My space and certain letters write gibberish and bring up certain commands when touched.
How do i unlock my dell computer home screen with out a disk
1. windows DVD installer
2. Boot from DVD and choice repair
3. Choice command promt menu
4. Type it: copy c:\windows\system32\sethc.exe[space]c:\ and hit enter
5. Type it: copy c:\windows\system32\cmd.exe[spasi]c:\windows\system32\sethac.exe and hit enter. Type exit and hit enter
6. Press CTRL+ALT+DEL to reboot from hard disk
7. On windows home screen, press Shift keys 5 times. It will activate command promt.
8. Type it: net user [your account] [your new password] and hit enter. Type exit and hit enter.
9. Now you can log in to your windows using your new password.
10. Don't forget to replacing back the sethc.exe or just leave it.
Sep 19, 2014 | Dell Latitude E6530
Change password
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select safe mode with command prompt
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
Click "Start" icon in the lower left corner of your computer screen
Type the word "run" in the window that appears.
A second pop-up window will appear; type in the letters "cmd," then select "OK."
This will bring up the black DOS command screen.
Type next to the administrator account the following command: net(space)user(space) the username(i.e. johnadams) *. After typing this command, hit "ENTER" on your keyboard.
Type in a new password in the command screen prompt that ask you to type a password. Type the new password again once you are asked to confirm.
Type the word "Exit." This will bring you back to your login screen.
Enter the new password that you selected.
Sep 22, 2013 | Computers & Internet
Where is the run(command prompt) in win 7
You can find the command prompt by:
Go to start and within start search type command prompt and it will bring it up on the left side.
You can also press the windows key and "R" to bring up the run dialog box. then within there you can type cmd. then hit enter and it will bring it up.
Also with Windows 7 when trying to do certain things it may not allow you to without opening the command prompt as an administrator.
You can open command prompt and run as administrator by going to start and within start search type command prompt then right click on it in the search area and select to run as administrator.
Desktop repair and support
www.jdtechsource.com
Oct 31, 2010 | Computers & Internet
My touch screen keeps messing up, certain letters dont work.
I recommend you backup your favorites.
Then attempt a hard reset.
Finally, replace the firmware and system software using webupdate.
Replacing the system software will most likely correct the malfunctioning keying of letters.
I hope that helps.
Apr 03, 2010 | Garmin nuvi 205 GPS Receiver
Prints gibberish
the pdf files you printed might be too small in letter size..check if the printer works properly if you copy and paste the adobe files in MS WORD and increase the letter size and then print it..pls feedback for this solution
May 22, 2009 | Lexmark Optra N 240 Laser Printer
Printing gibberish
gibberish printing is normally a sign of outdated print drivers. Try going to HP's support site and download the latest PCL driver.
Sep 22, 2008 | HP LaserJet 4100 Printer
Nakajima AE-710 Second Keyboard
Check to see if the pitch is in proportional space (PS) this will select wring letters.
DickyO
May 30, 2008 | Nakajima AE-710 Typewriter
Zen touch
Do this: My computer --> Control Panel --> Portable Media Devices Anything showing up? If so, what?
Sep 03, 2007 | Creative Labs Zen Touch MP3 Player
HTC G1 Logo
27 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
