Question about EliteGroup K7VMM Motherboard
Compatability My old computer with the K7VMM installed runs with 80gb hard drive, can I inrease this to 160gb with new hard drive using the same motherboard ?? thank you
  • vincent roberts Jan 11, 2008
    Hi Wiz , it would seem that my previous thanks for your solution was a little premature- or I'm given to understand..! The same question I posed i:e' motherboard compatibility' was given another 'answer' in that, if I intend to replace an 80gb hard disk with a 160 gb hard disk; then I'm told "I should update the BIOS and changelog"( whatever that last word means ) Note the REPLACE not' add' hard drive.. If I gave the wrong impression ,Then I apologise Any further comments from you would still be greatly appreciated. Many thanks
  • vincent roberts Jan 12, 2008
    Thanks Wiz; that about settles it for me and once again my thanks for your 'much appreciated' help. Best wishes to you and all at FixYa : Phoenix42
    Scholar:
  • 134 Answers
Sure, without any problem, you can even connect both as you have 2 IDE port, I'd recommend to connect each of them on its own port as master and your cd rom as slave.
A.J.
Posted on Jan 10, 2008
Hi, My previous computer died and I have tried to
you need then to "boot" in the second HD to TRY to look at those files.At start up press F12 and chhose the HD.
Oct 12, 2010 | Western Digital Caviar SE WD2500JS...
Hi i m hems i m upgrading hard disk on my ( acer aspire 1641nwlmi ) laptop hard disk is 160 gb but it's not detecting my new hard disk , my new hard is ok but i have quistion 160 gb is supporting my laptop...
The Aspire 1641 is supplied with a 80Gb hard drive. If the new 160Gb hard drive is not detected in the BIOS then the BIOS cannot support this size hard drive.
Check your manual/specification to see the maximum size hard drive it can support.
You can install the 160Gb hard drive in an USB hard drive adapter case and use it as an external USB hard drive.
Aug 24, 2010 | Acer Aspire 1641WLMi Notebook
Can i make my 80GB hard drive to 100GB? 80GB 7200rpm SATA SAMSUNG
This is not possible, 80Gb is 80Gb and 100gb is 100gb, but I am afraid, even if you like to replace, you'll not be able to get 100gb since it's no a standard Hard disk capacity. If you are trying to upgrade, then you can find 120gb, 160gb, 250gb, 320gb etc... Good luck. Thanks for using FixYa.
Jun 06, 2010 | Samsung 80GB INTERNAL 3.5- IN SATA HDD...
Where do I go to get a 160gb hard drive to replace my 80gb?
My favorite place is newegg.com I have ordered hard drives and memory from them and have been pleased with all of my transactions with them. They have good prices too. And No I do not work for them. I repair computers and use them.
Feb 23, 2010 | Acer Aspire 5315 Notebook
I have Intel 810e PIII 1 GHz 512 Mb Ram 20 GB HDD. OS Win ME I want to add secondary HDD. Which one should I preferr 80GB / 120GB / 160GB. and will install new OS say Win XP or linux in Secondary Hdd....
160gb - but ensure the bios is up to date and check the motherboard manual as that will or should explain about maximum capacity of hard drives but am sure it should be fine.
If it is not and does not detect all of it you can partition the partitions into smaller amounts ie 80 gb partitions each ?
May 19, 2009 | ASUS Intel 810E Chipset CUWE-RM...
Hard drive problem
It's possible that your computer's motherboard is "old", and it only supports a maximum of 32GB per disk-drive.
Buy a new 80GB or 160GB disk-drive, and copy all your files from the "old" disk to the "new" disk.
Apr 06, 2009 | HP HRD DRV-SEAGATE SAS 72GB 15K 2.5 SINGLE...
Having trouble turning on my laptop
Installing a new hard drive has nothing to do with the power switch. It may have become dirty or worn, but I would recommend that you hold it in just a little while when turning it on. That should work.
If, as you say, everything works once it's on, then your hard drive installation is not at fault.
If the problem gets worse and the computer finally doesn't start at all, then perhaps you have a problem with the switch and you'll have to deal with that--many times this means a new motherboard (unfortunately).
Jan 27, 2009 | Dell Latitude D610 Notebook
Replace existing 40GB internal HDD in laptop with 160GB internal
Drag and drop the files from one drive to the other.
  1. Plug your new drive in
  2. Right click 'my computer'
  3. than open 'C drive'
  4. repeat steps one and two
  5. than drag the files from C' drive to new drive'
Jan 05, 2009 | Computers & Internet
New hard drive
you got a problem there.
may be you can return it and get a 80GB harddrive. e-mail me fo rinstruction how to install update BIOS.
Sep 30, 2008 | Fujitsu LifeBook B2131 Notebook
Hard drive compatibility
This motherboard is compatible with PATA/IDE Hd's running at 133/66/33Mbs. & ATA/SATA 1.5Mbs drives. The SATA's run faster. This board will not handle a SATA II's speed but it will still run on the P5P800-VM board. The links below show good buy's on both PATA/IDE & SATA I & II. Seagates for their 5yr. warranty.
Seagate ST3160215AS 160GB ATA/SATA
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=117012
Seagate ST3160215A 160GB Ultra ATA/100
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=117010
As far a size, that is up too you. Windows can handle 5 time these sizes.
Please don't forget to vote.....
Dec 22, 2007 | ASUS P5P800-VM Motherboard
EliteGroup K7VMM Motherboard Logo
55 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
