Question about Mitsubishi WS-55809 55" Rear Projection Television
I have the 2-2 blinks problem on my ws-55809, can you help?
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
2,2 is short protection in this model--usually it means one of the two fuses that protect the convergence circuit are blown.
You need to replace the two STK-392-570 convergence chips this set uses along with any of the 3.9 ohm protect resistors in front of them that are bad.
The best way to do this is to get the middle board with the chips out of the set---
I have START TO FINISH, STEP BY STEP INSTRUCTIONS FOR THIS REPAIR ON THIS MODEL--they tell you everything you will need and how to do it yourself.
You can buy a pair of the Chips on Ebay for about 12 dollars plus shipping (I can tell you the seller there to look for--I buy the chips I use there).
If you have the original remote after you replace the chips etc--you adjust the convergence with it.
These are very good sets and were not cheap when new.
If you want the instructions let me know--I cannot post My email here, but you..........
If this information helped you, rate this solution as I do this here for FREE.
SD TECH
Posted on Nov 18, 2009
Turns off immediately after turned on
Do the self check it should have: when shuts down and green light goes out: On the front of the set press and hold both input and menu buttons at the same time for at least 5 seconds and then release both.
Power light on set should blink a two digit error code: like 2 blink,2 blink, pause and repeat it at least 5 times total.
Let me know what error code and I will tell you what it means.
If this has helped you, rate this solution as I do this here for free.
SD TECH
Aug 15, 2010 | Mitsubishi WS-55809 55" Rear Projection...
The tv will come on for a split second then click and cut off its a mitsubusi projection ws-55809
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
SD TECH
May 11, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Tv won't power on. WS-55511. Diagnostic is 1 blink then 2 blinks.
The Tv needs to have a system reset that is what the blinking light means. here is how to do.
Use the System Reset button. If this happens frequently, obtain an AC line in power conditioner / surge protector.
Dec 11, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Ws-65611 wont power on
Most likely bad caps on the dm board.
Sep 05, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Flashing green light when i hit power botton.
2 blinks and 2 blinks is the error code for short protection---usually in this set the most common cause is a bad convergence chip that has shorted; it takes out one or two pico fuses in the set's power supply---the set detects no voltage to the convergence chips and shuts down.
Almost any good tech can do this repair in your home in about a hour or less--shops charge 300-400 for this kind of repair--look in your area and find someone who has done this brand before--I do lots of them here for 200-250 depending on model---This is the slow time of year for TV repair shops so look around--if someone says it "has to go to the shop" keep looking.
I have detailed start to finish instructions (verify the model number to me) for doing this repair; If you have the skill to do it yourself--you can buy the chip on Ebay A WS-55809 model uses a single STK-393-110 chip---about 14 dollars on Ebay plus shipping----let me know if you want the instructions and if you have questions reply to this post here.
etower.766@netzero.net
I do this here for free so if it helps you take a moment and give me a vote here.
SD TECH
Sep 03, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi 55859 Blinking Green Light
Video instructions for repairing Mitsubishi WS-55859 HDTV:
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
You can find the parts (capacators) at Radio Shack for appx. $2/each.
Dec 27, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mits WS-55809 Convergance prob?
You are confusing yourself = TMI ! Stick to convergence repair...
IMHO , hire a tech to do this repair for you.......................T.
Nov 07, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
57 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
