Question about RCA D52W19 52" Rear Projection Television
How to replace a convergence fuse in my RCA Projection TV?
I was playing video games one day, and the screen just flashed and then the color was all messed up. This used to happen, but I would go to the menu and push the convergence feature and it would normally fix the problem. If I was to replace the convergence fuse, would this fix the problem? So I am going to buy the replacement fuse for my RCA D52W23 TV. The fuse is a FL231 model that I have found so far. If I was to buy this fuse, how hard is it to replace it? And is it going to blow the fuse again most likely, and does something else need to be fixed? Thanks for the help!
  • 2 more comments
  • calw87 Nov 18, 2009
    Ok so is the deflection board the TV equivalent of a computer motherboard? I took off the back panel of the TV, and now I am not quite sure what to do. I see two motherboard looking pieces of equipment laying flat directly inside of the back panel. Which one of those do I work on? Is there a better way to access them?
    Ok I see what you are talking about. I will try what you said. Thank you for your help!
  • calw87 Nov 23, 2009
    So I have the fuse, and I need to replace it now. What are the steps I need to take to replace the convergence fuse?
    I see the deflection board, but I do not know how to remove it. How do you go about doing this?
    I also see the fuses. How do you safely remove them and put in the new one?
    Thank you for the help.
    President:
  • RCA Master
  • 1,779 Answers
You will have to remove the deflection board on the left and resolder the transformer connections. That is the item with the red lead coming out of it. You will find bad solder joints around it. After that you will see 3 small brown rectangle fuses on the top side to the right of the transformer. I believe it's the middle one that is probably open. You should check them with a continuity tester or ohm meter if you have one. Replace the bad one and you should be ready to go.
Posted on Nov 18, 2009
Testimonial: "Ok so is the deflection board the TV equivalent of a computer motherboard? I took off the back panel of the TV, and now I am not quite sure what to do"
  • Jim Krause Nov 18, 2009
    No it is not equivalent to a mother board. I said the board on the left with the RED High Voltage Lead coming out of the transformer. That is the board. The board on the Right is the Signal processor board- NOT THIS ONE !
3 Suggested Answers
  • 1779 Answers
SOURCE: What blows the fl231 fuse. On the RCA D52w23 TV?
Bad solder joints on the IFT.
Posted on Oct 21, 2009
Testimonial: "Thank you, That was exactly the right thing. I resoldered pins on flyback and now Doesn't blow the fuse."
Slinteriors
  • 8617 Answers
SOURCE: rca d52w19 rear projection changed flyback and
IF the FL231 fuse is good and you still can not adjust the convergence then the Convergence power supply board would be the most likely problem. You can get the replacement boards from www.tvrepairworld.com
Posted on Apr 02, 2011
HDLP50W151 50 in. Rear Projection HDTV Television: have a 48 inch rca projection tv and the picture i...
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 17, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
Help with RCA projection TV P46812BL (chasis ptk195AA)
You have probably blown one of the convergence ICs. Effectively the easiest thing to do is replacing the whole convergence board, so that no soldering is involved.
Here you can buy a replacement convergence board, just select your model.
Let me know if you need further help.
Sep 13, 2008 | RCA P52930BL 52" Rear Projection...
Horizontally the picture is distorted (doubled). Sound is ok. we have a 52 inch RCA big screen tv.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Feb 21, 2010 | RCA P52926 52" Rear Projection Television
Blue convergence bows when watching tv, hdtv looks great
Below are two of the most common problems encountered with projection TV sets.
Problem #1 - CONVERGENCE PROBLEM
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
Sep 14, 2009 | RCA HD52W58 52" TV
Rca 52w59 has a bowed screen and has a rainbow effect in color
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Apr 06, 2009 | RCA HD52W59 HDTV Projection Television
Trouble with rca rear projection tv
  • Screen looks 3D
Feb 16, 2009 | RCA P61950 61" Rear Projection Television
Rca 46 proj
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith2_bing.gif, and others. You can get a convergenece repair kit from the link below.
Jan 10, 2009 | RCA P46924 46" Rear Projection Television
Setting convergence using service mode on the tv.
  • Screen looks 3D
Nov 23, 2008 | RCA P46920BL 46" Rear Projection...
Bowed picture on rca p52955
  • Screen looks 3D
Nov 21, 2008 | RCA P52955 52" Rear Projection Television
Rca r52wh74 projection 52" tv
Convergence in this unit can be one of 3 possible boards. can you adjust any ...do the crosshairs move in customer setup convergence menu
Jan 04, 2008 | RCA HD52W58 52" TV
RCA D52W19 52" Rear Projection Television Logo
1,080 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
