Question about Panasonic Lumix DMC-FX50 Digital Camera
Zoom stuck on?
Hi! From one second it was working great to the next it just stopped. It goes on fine but zooms out to full capacity straight away and then won't do anything. Won't take a photo. The last photo appears on the screen in play mode but won't scroll thru, won't delete, nothing. I somehow think the zoom is stuck on? It was playing up before it broke and in scene mode just scrolls thru them all non-stop!? Pls help, I miss my camera!
Thanx, Carol
  • 6 Answers
SOURCE: Can't take pictures-all buttuns don't work
hi, look for my answer in another fx8 topic! there is a soft reset combination. just switch to record mode, press the shooter button, hold it down, and switch the camera on. it is a some kind of reset. it worked me.
Posted on Jul 12, 2007
SOURCE: Lense stuck out ? DMC-FX01
I had a similar problem with mine. When I turned it on, the camera would zoom out all the way and the other buttons wouldn't respond. If I switched it to review, it would just cycle through all the pictures, so I figured somewhere the zoom lever was stuck inside. I don't know a lot about cameras, so I sent it in to Panasonic (it was still under parts warranty), but was informed that due to "grit substance" my warranty was voided and it would cost $179 to repair. Since I could buy the same camera used at www.keh.com for that price I told them to send mine back and I'd take a shot at fixing it (since I was pretty sure it was a mechanical problem). Here's what I did with a $1.79 glass repair screwdriver and tweezers. Remove the battery and take out all the visible screws on the outside (2 on the right, 1 on the left, 3 on the bottom). Lift the back panel at the bottom edge, and it should pivot along the top edge until you can remove the back. Then unplug the two ribbon cables (the small one has a latch on top and the larger one has a black latch on the side that you need to lift). BOTH have hinges, not just the smaller one like other posts have said. Next you need to remove the front panel. There are three silver screws placed around the lens unit (look down inside, and you'll see them attaching it to the front panel). Remove these, and you should be able to remove the front (lift at the bottom and it pivots along the top edge). Now you should be able to pop off the top cover (with the zoom, power, etc). Now if you look at the bottom, there are two screws holding the board to the cover, remove these and you've got it apart. On the top right side of the board, you'll see where the external zoom switch pushes a very small black lever. This was where the problem with mine was, the black lever was stuck over. You can use the tip of the screwdriver to pop it back to the center position. Now make sure that if you push it one way or the other that it will recenter on its own. Mine didn't, so I had to pop the small silver cover off where the lever is with the flathead tip of the screwdriver. Be careful here. The lever just sits on a peg, and has very small gears that move a slide bar. If either of these fall, you may never find them again. I took both the lever and the slider off, cleaned them, and got it so it would recenter easily again. Then I put them both back in, popped the cover on (you may have to pry out one of the sides slightly to get it back on), and the lever works fine now. I wouldn't be surprised if your camera has this same problem. If it's something else, it's still probably a problem with this mechanism that you could fix. Anyways, reattach the board to the top cover, and pop it back onto the camera. Now insert the battery, and turn it on to see how it works. Even without the screen, you can try the zoom. If it all works, then all you need to do is put it back together in the opposite order you took it apart. When reattaching the LCD ribbon cables, make sure the hinges are open, insert the cable, and snap down its latch. Hopefully that works. I don't know much about cameras, but it wasn't too hard. Just work slowly and carefully.
Posted on Aug 19, 2007
  • 3600 Answers
SOURCE: My Dell touchpad on my Vostro 1520 wont zoom or
best thing to do is buy a wireless usb mouse and hook it up otherwise will be a 100 fix at least. Try opening the touch pad screen on the tool bar and adjust it to work again.
Posted on Nov 24, 2009
parrotheadpc
  • 2600 Answers
SOURCE: zoomed into my screen and cannot zoom out
If you are referring to a web page, holding down the control key while pressing the + key will zoom in, pressing the - key will zoom out.
Posted on Jan 11, 2010
  • 23 Answers
SOURCE: zoom and scroll not working on touchpad
try re installing the touchpad driver with the use of cd/dvd given at the time of purchase.
there must've been some prob with the mousepad/ external mouse driver.go to control menu->double click mouse->choose hardware tab->properties->driver->update driver... do this with ya motherboard/laptop cd/dvd in the cd/dvd rom. choose search software driver automatically. once ya done. restart and start using mouse as before.
Posted on Jan 12, 2010
Is not working properly
A good possibility is the zoom head is causing the clicking sound. As we zoom the flash, the inside of the head moves to the back and forward. Gently tap it a few times see if that helps. My guess is it needs servicing.
Apr 18, 2014 | Canon SPEEDLITE 580EX TTL Flash
Hi, I have a DMC-FX30. When i turn the zoom
mera Digital Camera Hi, I have a DMC-FX30. When i turn the zoom Answer Failed: retry Hi, I have a DMC-FX30. When i turn the zoom swithc it is stiff and goes to full zoom and cannot be... (More) (More) Hi, I have a DMC-FX30. When i turn the zoom swithc it is stiff and goes to full zoom and cannot be stopped - only when i switch the camera off. Can you help?
Feb 11, 2010 | Panasonic Lumix DMC-FZ28 Digital Camera
Exact same troubles.
i think you've got a stuck zoom in [+] button. was this camera left inside a cabinet ...or some damp place for some time?
Jul 15, 2009 | Nikon Coolpix 2200 Digital Camera
Unable to use zoom capacity properly - don't get full zoom range
Hi
This problem is NOT generic for all model camera's depend of the zoom problem in your camera
Apr 15, 2009 | Cameras
Over exposure when zooming
If you want to be able to use optical zoom try getting a more advanced camera because cameras like Nikon Coolpix 4300 does`nt have quality zoom its very poor and you can see it yourself the images gets blurry when maximize your zoom.
Jun 22, 2008 | Nikon Coolpix 4300 Digital Camera
Nikon coolpix 2200 zoom
Based on your description, it certainly sounds like the zoom button is stuck or shorted. If you're comfortable with taking it apart, I'd try getting to the zoom electronics and see if there's any noticeable damage. Whenever I try something like this, I like to see how much damage I could cause first. eBay has sold this item for less than $50 with shipping (just in case you break something). You can also look there for parts cameras -- one listed for $10 with free shipping that might give you what you need.
Aug 21, 2007 | Nikon Coolpix 2200 Digital Camera
Zoom Won't Work
The motor has failed I guess Check the Olympus site for advice re repair or replacement.
Aug 12, 2007 | Olympus Camedia C-725 Digital Camera
Screen automatocally switches between zoom settings
Go into the menu and set the 4:3 default either on or off i think it should be off
Feb 24, 2007 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Nikon coolpix 2200 zoom mechanism
If the lens assy is not responding to zoom buttons then the camera is in confusion mode due to a sensor being blocked or defective. Normally it would go thru a startup cycle to initialise position of various parts in the lens assy and give back control to you but in your case it is not getting that signal and in your case I would bet on the end sensor.
Nov 08, 2006 | Nikon Coolpix 2200 Digital Camera
Panasonic Lumix  DMC-FX50 Digital Camera Logo
27 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
