Question about HP OfficeJet 7130 All-In-One Printer
HP 7130 Random grinding noise resulting in a stall
My 7130 has started to occassionaly make a gears grinding sort of noise when attempting to print. It does this when the print/ink cradle is in the far right position (also the noise is coming from that side of the printer). When this happens the printing never takes place. The message in the display states it is printing page 1 but it will hang there forever. I can either just cycle the printer off and on to clear the problem sometimes. Other times it seems I need to unplug and replug it to get it free up.
  • clinchmtnman Sep 30, 2008
    I have the same randomly-occuring problem as "Filka" describes. This sounds like a loud "racheting" sound. I've cleaned the gold strip (as described at http://www.fatrcat.com/7100ss.html. Waiting to see if this fixes it. If not, I'll have to try disassembling the case and cleaning the service station area. If there's any other (simpler) fixes, I'd love to hear of them.
    Problem Solver:
  • 9 Answers
Filka, You are most likely beginning to experience issues with service station function usually created by the buildup of ink which becomes gelled and gooey, resulting in sticking parts. Two primary points of trouble can be involved; one very easy to see and reach- the other requires a fair amount of disassembly but once inside the job is not hard.
First, right on the edge of the service station (the black box beneath the carriage when it's parked on the right) you will see a narrow white wedge-shaped piece. This is a retracting "wiper" which is supposed to slide forward when the carriage is parked, and to the back when the carriage is preparing to move. It has a small rubber tab at the front edge which wipes ink from a gold contact surface right in front of the wiper. I've yet to see one truly do well at keeping the surface free of ink, but it does keep it from building up. It is quite easy for this wiper to become "glued in place" by all of this ink. Start by raising the maintenance door, causing the carriage to move out to the center and the wiper to retract(if they will). You can then use a dampened paper towel or cotton swabs to clean the contact in front of the wiper, then gently pull forward on the top of the wiper to slide it forward over the cleaned surface. This will remove some of the ink on the rubber tab and begin letting you clean the wiper itself.
The second area of trouble is the service station itself. The sleds and tray are likely to be heavily coated and the only real way to clear them is to disassemble the case for access. You can use the following link to go to a step-by-step photo/instruction guide that will show you exactly what's involved-
Posted on Mar 12, 2008
Hp 1018 printer making really load grinding noise and not printing
ok first try restarting your printer, then try uninstalling the driver for your printer off your computer, restart your computer and printer and then reinstall your drive for the printer, see if you get a replacement for your printer or a refund
Dec 01, 2014 | HP LaserJet 1018 Printer
I went over some substantial speed-bumps where the bottom struck and scratched. I had to go about 2 kms/hr. so it would not happen (seriously!). Everything was fine (stopped at a store for about 10...
Hi, it seems you have faulty clutch from the description you made concerning the grinding noise when you tried 2nd and 3rd gear which i thinks is as a result of the stuck and scratch you had on the speed bump. And if you try riding it in its present state, you will end up damaging the gear box...
Now if your engine stalls when you drop into 1st gear, with the clutch disengaged, then the clutch plates are stuck together. Normally in this case, before starting the engine, try putting the transmission in 2nd or 3rd gear (But you already have a problem doing that which is also as a result of the faulty clutch), pull the clutch in and roll the bike forward and backward a few times to free the stuck plates. Meanwhile fresh gasoline maybe all you need..
In summary, a clutch problem....
Sep 04, 2010 | 2005 Honda VT 750 Shadow Aero
My HP LaserJet 4L printer just makes a grinding sound when I attempt to get it to print. It makes the sound for several seconds and then the Paper light starts to flash without printing
Common issue with these older 4L printers. The problem is a small plastic gear on the main drive motor has cracked. This is what causes the noise and since the machine is not "running" there is no paper feed and thus the paper jam light. Basically there is no drive to any of the printers components. May be hard to find a replacement motor these days but that is what you would need to fix the printer.
wheatlandsvcs
Aug 18, 2010 | HP LaserJet 4L Printer
While driving and shifting into 5th gear the engine suddenly stalled. Now it will not start When I depress the clutch and turn the key it wants to to turn over but the result is just a grind like noise....
driving along in 5th gear but then after about 30 seconds it pops out of gear and i have to put it back into 4th coz it wont go back into 5th.
Oct 23, 2009 | 1998 Kia Sportage
Hp laserjet 3330 gears on right side grinding after print
The most common problem with grinding is from compacted toner. Try changing the toner cartridge.
Aug 26, 2009 | Office Equipment & Supplies
HP Color Laserjet 2840 now makes ear-splitting whine every time
Did the noise start right after you replaced a toner? If so it must be a bad toner which is causing the gears to grind. If this noise happened out of the blue then it might be a bad fuser drive gear which is the gears that connect the fuser to the machine.
Jun 25, 2009 | HP LaserJet 2840 All-In-One Printer
Color Laserjet 2550 Loud Noise when starting up and printing
Remove toner cartirdge and check gears on cart as well as all of the gears you can see inside the unit for any signs of wear. You may also need to remove the fuser assembly and perform the same task with the gears back there. MAKE SURE THE POWER HAS BEEN TURNED OFF AND THE PRINTER UNPLUGGED FOR AT LEAST 30 MINUTES BEFORE ATTEMPTING TO TOUCH THE FUSER. IT WILL BE HOT!!! Most frequently these kinds of noises from the printer are due to gears slipping. Sometimes simply reseating the fuser assembly or toner cartridge will fix it. If there appears to be excessive wear on any of the gears, you will need to replace them.
May 29, 2009 | HP Color LaserJet 2550n printer + HP Color...
HP Deskjet 1320 printer makes grinding noise and stalls before it prints
I think the noise is normal for hp deskjet. When starting up, the printer read the head existence, and do cleaning. is it the first replacement cartridge? Disable ink status monitor.
May 29, 2009 | HP Office Equipment & Supplies
Canon PIXMA 530 grinds away
I had a persistant grinding noise about 30 seconds after the printer finished printing. It's been going on about 2 months. I did one thing which seemed to work. So try opening the cover on the back of the machine by lifting upward on the gray lever in the middle of the back of the machine. Leave this cover open during and after printing. The grinding noise went away.
Jan 11, 2009 | Canon PIXMA MP530 All-In-One InkJet...
238 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
