Question about Frigidaire FEF366 Electric Kitchen Range
Oven element burned brighter than usual - turned it off - won't turn on again. what should I check
  • Eric Duda
    Eric Duda May 11, 2010
    Sounds like the element failed. It should be visually evident. If not a VOM (meter), would be a great help in diagnosing.
    Eric
    Sergeant:
    Champion:
  • 289 Answers
Unplug range and remove element.have element checked out.
Posted on Nov 18, 2009
My oven will not heat up to temperature
It may be the bake element that has gone out. The self clean usually uses the broil element to heat the oven. And most oven will either put 120 volts to the broil element while baking or pulse the broil element while baking. This will cause the oven to get warm but not hot. Check the oven bake element it cound be bad or a wire may have burned off.
Feb 14, 2014 | Ovens
Oven does not heat up
That pop could have been the element. Check all around the element for a bubble or a large pit/hole. If you don't find anything then check for a burned wire in the back (please unplug the range). Does your range have fuses? If so then check the 30A fuses, but if one is blown you'll have to find the short that caused it, usually a burned wire fused to the chassis or a burned out element. There are many things that could have caused this but these are the most common. Cheers
Nov 09, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Magic Chef cgr3765adc, oven will not turn off. If the unit is plugged in the oven ignites and would continue heating unless disconnected from electricity.
follow this test and fix it. God bless you
Bake Element
If the oven won't turn on, check the bake element. The bake element is a black tube near the bottom of the oven about as thick as a pencil. When it is operating normally, the bake element will glow red hot. If the oven won't turn on the bake element may have burned out. It is often obvious to see where the bake element has shorted out because there will be a hole or break in the element. If the bake element has burnt out or shorted it should be replaced.
Oven Igniter
Even though the oven igniter may be glowing, it may be too weak to allow the gas valve to open. If the oven won't turn on and the oven igniter glows for more than 90 seconds without igniting the gas flame, the oven igniter should be replaced. This is the most common part that fails when the oven won't turn on.
Broil Element
If the oven won't turn on, check the broil element. The broil element is a black tube near the top of the oven about as thick as a pencil. When it is operating normally, the broil element will glow red hot. If the oven won't turn on the broil element may have burned out and caused something else to short out. It is often obvious to see where the broil element has burned out because there will be a hole in the element or blisters on the outside of the element. Test the broil element using an Ohm meter. If it has continuity it's OK. If not, it should be replaced.
Incoming Power Problem
Although not as common, if the oven won't turn on it is possible that the appliance is not receiving proper voltage. Electric ovens require 220 volts of alternating current. If for some reason the appliance is receiving significantly less, the oven won't turn on. Check for proper voltage using a volt meter at the socket where the appliance plugs in.
Oven Control Board
The oven control board has a set of relays that turn on and off power to the bake and broil circuits according to the customer settings and sensor input. If the oven won't turn on the problem is usually with the heating components. However, if the oven control board is bad, it might not send voltage to the heating components. To determine why the oven won't turn on, first test the simpler components in the circuit. The oven control board usually can't be tested and will have to be replaced if it is defective.
Thermal Fuse
Although not as common, if the oven won't turn on the thermal fuse may have blown. The thermal fuse is designed to protect the appliance and help to prevent a fire. If the oven gets too hot, this fuse trips. The thermal fuse is not resettable and will have to be replaced. It can be checked for continuity. If it has continuity, it's OK. Not all ovens have a thermal fuse.
Relay Board
If the oven won't turn on and the appliance is equipped with an oven relay board, one of the relays on the board may have failed. Normally the oven relays are located on the main clock control board and not on a separate oven relay board. If the oven won't turn on it is more likely that the cause is one of the more common problems listed for the model. If the other, more common problems have been checked and Your oven has a relay board, it may need to be replaced. Oven relay boards are not repairable.
Oven Thermostat
If the oven won't turn on, the oven thermostat might be defective. Although this is not as common as other components, the oven thermostat sometimes fails completely and does not allow current to pass through. After checking other, more common components, consider replacing the oven thermostat.
Heat Selector Switch
If the oven won't turn on, be sure the heat selector switch is set to the right position. The heat selector switch completes the circuit to either send voltage to the bake or broil circuit. If the oven won't turn on, the heat selector switch might also be defective, although this is not very common. The heat selector switch is not repairable, if it is defective it will need to be replaced.
Oven Safety Valve
The oven safety valve works with the oven igniter to provide gas to the burner. If the oven won't turn on it is possible that the oven safety valve is defective. However, this is very rare. Most often, the oven igniter is too weak to allow the oven safety valve to open. If the oven won't turn on, check the igniter first.
Oven Valve and Pressure Regulator
If the gas oven won't turn on the oven valve and pressure regulator might be at fault. This is not common. Very often people misdiagnose a defective oven valve and pressure regulator when the oven won't turn on However, this is almost never the cause. Look at other, more common components before replacing these.
Nov 04, 2013 | Magic Chef Kitchen Ranges
Burners and oven on Hotpoint free standing electric stove won't heat at all.
Find someone with a good electrical meter and have them test the sockets to see if there is any electricity to the burners.
Also, check each burner and check for continuity through the burner itself.
These elements can all burn out, I've see it happen.
Be blesssed.
Apr 17, 2013 | Kitchen Ranges
No heat when set to broil but the bake turns on the broil element. nothing turns on the bake element. are the wires hooked back correctly?
see the next steps and proceed according with commong sense: God bless you
Usually, when an oven won't broil, it's because the broiler element is burned out. The broiler element in an electric oven is the black, pencil-thick tube at the top of the oven. When the broiler is on, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it. To determine if the heating element is burned out, watch the part testing video at the bottom of thi
Jul 27, 2012 | GE Kitchen Ranges
My stove poped and went off. I tripped the breaker and now the oven will not heat. Neither the top or bottom unit.
First I would look at the heating element in the oven and make sure it is all in one piece. there are usually one on the bottom and one on top. sometimes they will burn apart and short out to stove. if they look ok then do a quick check, I would turn off all knob on the stove top and oven. then try to reset the breaker. hopefully it resets ok. then turn on one at a time and see which burner or oven element has a short. when you find the bad burner or stove element it will trip the breaker again.
hope this helps
Jan 09, 2012 | Kenmore Kitchen Ranges
Electrolux E@30GS65GSD bottom oven won't heat
most likely it is a bad element easy and cheep to replace check element for burn spots on it with a flash light don't touch unless you have the power turned off , get back to me if you need a part but i will need all info on this oven
Dec 06, 2011 | Electrolux Ovens
Main oven causes trip switch to trip out when `I turn the dial to switch on. Top oven is fine.
Likely the element is shorted in the main oven. The Calrod elements short usually at the bends and if the breaker doesn't trip they burn a hole in them and arc. You can USUALLY see a different discoloration at teh failure point. Check both upper and lower elements as preheat probably uses both. Use a dental mirror if necessary to see under and over. Use bright light.
May 04, 2011 | Tecnik TKC8525 Double Oven
Smoke coming from electric oven element
if it is the upper element is smoking when in use then its usuall grease/fatty deposits that have attached itself from previous cooks.. the only way to rid is to open doors & windows then turn to max temp to burn off... 5-10 mins usually suffice dependant on quantity. looks bad initially but soon it will be heating clean again..
Dec 20, 2009 | Smeg SE399X/5 Stainless Steel Electric...
I have a GE Profile Spectra XL44. When I turned my oven on to 375 it read 100 degrees for 10 mins. I open the door and there was no heat. I then tried the broiler to make sure it worked and the the element...
i wouldn't say it is "normal", but yes, the bake element in the bottom could have burned out again. it depends too on how often you use the oven. if you use it every day, chances are it will burn out quicker than say someone who only uses it once a week. you can check the element for a burn hole or a blister break. you can also check it for continuity with an ohm meter if you have one. hope this helps.
Nov 07, 2009 | GE Ovens
Frigidaire FEF366 Electric Kitchen Range Logo
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
