Question about RCA G27304DT 27" TV
The coax connector broke off the back of my tv ineed a new part were can i find it
    Scholar:
  • 86 Answers
Hi i will be more than willing to try and solve your problem. this problem can be costly, because you will have to reconnect the copper wire to the circuit board on the inside of the tuner. if you do this it still might not have a good connection. sometimes the set will not show as good and have fuzzy channels. you then will have to resolder the outside of the coaxial to the tuner this has to be done right or it will be easy to break off again. it is best to simply get another tuner. when i have this problem i just simply go to tiptop tv. the whole tuner with shipping and handling is about $31. if you have some soldering experience you can simply desolder one and solder the other without paying anything extra. you must have the number on the side of your tuner or even have the brand and model number of your tv and they will be very helpful. i have used them for years and they have never let me down. i believe that this will solve your problem. please rate me on my solution. thank you and have a nice evening.
Posted on Nov 18, 2009
The coax cable nipple (labeled "RF") on the back
As long as it was a clean break this will be an easy fix. If the tuner got damaged at all, then you will need to replace the whole tuner, which can be a bear if it is a two sided board. You can buy a new connector at just about any electronics store. You will need a soldering iron, solder and wick for the repair. You might be able to just solder the original connector back on if the break is clean enough. You will also need to stick a wire or something like that in the hole to keep the plastic from melting shut from the heat of the iron.
Apr 11, 2011 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
How to fix the antenna anolog cable connector that to coax cable connects to on back of TV.
Cut off the bad connector on the end of the coax cable. Go to Radio Shack, Home Depot, etc. and pick up a new twist-on coax connector, or a crimp on version if you have a crimping tool.
Twist the new coax connector on good and tight and you should be good to go.
Mar 30, 2010 | RCA HD52W59 HDTV Projection Television
Broken cable connector in the back of JVC tv
if the remaining piece was not part
of the PC board , which is light yellow
theres a good chance with a soldering iron
and a new female coax from radio shack
you could do it . or pay a shop 75.00 to
reinstall one for you.
Jun 30, 2009 | Televison & Video
The connector at the back of the tv where the cable would be connected broke off during a move. My step dad took the remaining piece out. How can we fix this? Is it a simple thing we can do ourselves?
The coax connector you describe is fairly low-tech, so it can be fixed. You need to open the back of the TV (careful - high voltage in the capacitors) and locate where it came from.
The best thing would be to take some coax cable and solder the appropriate parts (shield and center conductor) to their exposed matches where the break occurred.
You can then run that through the existing hole, put a screw-on F-terminal end on the piece of coax, and a coax coupler on that.
Home Depot, Lowes, Radio Shack, etc. all have these raw parts.
Jun 30, 2009 | JVC AV-27220 TV
Coax cable broke off my wife tryed to put back in the cable line with coax insert broke off there was connector on the cable line she just jammed the bare cable line into the hole where the coax...
Yes there is a possibility that something shorted... remove the cable wire and unplug for 10 to 30 min and try plugging back in and restarting the set. otherwise the tuner probaly would need replaced. something any tv tech can do. AT the shop we replace these conectors al the time. just depends how bad the tuner is damaged.
Mar 17, 2009 | RCA Televison & Video
Cable/antenna connector
you can try to get just the coax replacement , otherwise you will have to get the whole tuner, and the number for the tuner is right on the tuner , but just soldering in a new coax connector is cheaper
good luck and thanks!
Oct 20, 2008 | RCA TruFlat 27F520T 27" TV
I broke off coax cable on back of 32 inch tv. I can watch dvds with AV cables but not cable TV. How do I connect cable from wall to tv if coax is broken off
This depends on how many available inputs you have on the back of the set. If you have more available you can just hook up the cable box composit (yellow, red, and white cables) if not you will need to replace the rf connector or tuner in the set. let me know if you need more help.
Tim
Sep 11, 2008 | Televison & Video
My TV is fine...problem happen when I was moving today,not sure what its called but its the silver projection located on the back of the TV is which you connect the cable on the wall too...it broke...
Hook the cable up to the VCR or if you don't buy a RF converter from radio shack or electronics store which will have a coax connector on it with component and Svideo to send to the TV. Select the connection (Component or Svideo) in the TV menu. If you only have the coax connector on the back of the TV without any other connection, you will need to get that tuner board replaced.
Aug 18, 2008 | Televison & Video
Coax connector
looks like you have to replace the the tuner part (thats the slim silver box where the coax connector was ) if your handy with this solution and can repair it yourself , then you need to go to a SHARP authorized dealer to purchase the part or leave it there for repair . let me know if this helpful, thanks AJ
Apr 23, 2008 | Sharp 32R-S50 32" TV
Sharp 36R-S450 Coax broke off Help!!
it should be alot to fix all u have to do is buy the coax connector n solder it
Oct 28, 2007 | Sharp 36R-S450 36" TV
Televison & Video Logo
106 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
