Question about Bosch Nexxt 500 Plus WFMC5301UC
Can a bosch 500 + series be put into just a spin cycle so I can level the feet?
  • Bosch Master
  • 3,463 Answers
Most washers have dedicated Spin only prog.
Refer to your user handbook, if you do not have one, then ring the manufacturers help line, they usually have a dedicated number for customers with problems such as yours.
Please rate my solution.
Thanks.
Posted on Nov 18, 2009
How to stop drum wobbling
The drum needs a certain amount of play, but there is a bearing at the back that can fail. One thing to check is that your machine is level front to back and also left to right. In addition, make sure that all four feet are in equal contact with the floor.
Jan 02, 2016 | Bosch Nexxt 500 Plus WFMC5301UC
Code d:08 bosch nexxt series 500
It is bound to be a blockage or the impeller is stalling due to foriegn objects like coins.
Mar 06, 2014 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch 500 series wfmc3301 bosch washer does not stop running the water during a cycle . even will do it with the spin and drain cycle. Even attempting to turn the washer off it will still run and then once...
You have a bad water supply valve which is struck in the on position-this valve is mounted inside the machine right where you attach the supply hoses-cheers Denny
Oct 24, 2013 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch Nexxt 500 series washer program cycle selector knob just spins and no longer clicks in place to select a cycle. How do I fix this?
This is a failure of the program controller timer unit and it must be replaced as the locking mechanism or the stepper motor link had failed.
Aug 03, 2012 | Bosch Washing Machines
The water won't drain from my Bosch Nexxt 500 Series Washer machine
I solved the problem by using a sump pump to drain most of the water, then I removed the cover plate on the lower front right of the machine to get access to the drain plug. Upon removing that, some water flowed out but not too much, I found a sock jammed in there which wasn't allowing the drain or spin cycle to work properly.
Interestingly, the machine's manual says that the cover plate is only to be removed by a Bosch authorized service repair representative. Saved about $150 by simply doing this myself.
Sep 16, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch NEXXT 500 SERIES washer Makes knocking sound while spinning
during transport there are fittings installed to prevent damage to the machine. The shaft may have got bent but before panic sets in try to check 1. that there is a gap between the mahine and units
2. that the unit is leveled.
Aug 16, 2009 | Bosch Classixx WFC 2465 Front Load Washer
Bosch front loading washer nexxt 500 won't pump out water on the spin cycle
could be drain hose is not high enough. I had the same problem and when I raised the hose it worked fine.
Dec 04, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
My bosch nexxt 500 series washer won't spin
possibly the motor brushes.
take back panel off. disconnect motor. remove bolts holding motor in and take out motor. check condition of brushes
Oct 18, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
New machine, manual says run a spin cycle, can't figure it out
make sure you remove all the shipping bolts per installation instructions then rock washer with hand and screw legs down till it doesn't rock then load an go call me back if any problems
Dec 30, 2007 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch Nexxt 500 Plus WFMC5301UC Logo
173 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
