Question about Apple iBook G4 Mac Notebook
I shut the ibook off using the power button, now when i turn it back on it stays on the white screen with the apple and does nothing. I can here the hard drive but it does'nt advance. Is there a way to restore it without the disks?
    Problem Solver:
  • 9 Answers
You should never shut it off with the power button unless it is not responding. When you turn the computer on, hold down the option key, and select Macintosh Hard Drive when it gives you a picture of a hard drive.
Posted on Nov 18, 2009
Apple computer is locked up
Your hard drive is 10 years old. It needs to be replaced.
Apr 22, 2014 | Apple 661-3345 IBOOK G4 14-INCH EARLY 2004...
My ibook stays on the white screen but the apple and the spinning thing doesnt show up but i hear the chimes and i am trying to download my new os x software please help me get it to work
You may have a bad hard drive. The "chime" means that the iBook was able to power on, and the white screen means that it foung the efi or firmware, but the fact that it will not go to the apple or the spinning gear means that it cannot detect an operating system on a hard disk.
Do you have the OSX CD? Put the CD in your ibook, power it on, and hold down the "C" key. This will allow you to boot to the CD. if the hard drive is still good, then it will allow you to install, if not then it will tell you there are no hard disks available. Hope this helps.
Mar 14, 2011 | Apple iBook G4 Mac Notebook
Blan White screen
try holding the power and the square at the same time till it shuts downand the apple logo shows up then release
May 12, 2010 | Apple iPhone Smartphone
Describe your cannot start ibook G3Problem it simply does not start, battery is ok and I have tried to take the battery away and back in its place, but nothing what can I do?
Make sure your iBook is plugged in to the wall. Hold down the power button for a few seconds. If that doesn't work, try holding down Command (the Apple key)-Option-P-R (hold all four keys down) and press the power button. Be sure to hold the power button for a few seconds whenever you turn it on.
If that doesn't work, try resetting the Power Management Unit (PMU). This is kind of a "last resort," according to Apple. Don't do this all the time.
  1. Reset the power manager by simultaneously pressing and then releasing Shift-Control-Option-Power on the keyboard. Do not press the fn (Function) key while using this combination of keystrokes.
  2. Wait 5 seconds.
  3. Press the Power button to restart the iBook computer.
If you have a very old iBook, you may have to unplug your iBook, remove the battery, and
  1. Press and release the reset button located above the Audio/Video port on the left side of the iBook (Dual USB) computer by inserting the end of a paper clip into the small hole and gently pressing the switch once.
  2. Wait 5 seconds.
  3. Reconnect the AC power adapter.
  4. Put the battery back in the computer.
  5. Press the Power button to restart the iBook computer.
(If it still doesn't start, do you hear the fans going?)
Good luck! Let us know if these steps solve your issue.
* If you find this information helpful, please rate my solutions and recommend me. Thanks! *
Apr 30, 2010 | Apple iBook G3 Mac Notebook
I cant get my ibook g4 to run it turns on with blinking folder
Blinking ? mark folder means that your OS can't be found. Take out your RAM underneath the keyboard and re-insert and try again. Nothing? Install a different new RAM chip and try again. Nothing? Install your disc 1 install disc, power down, wait a few seconds, now press the power button to turn on, now press and hold the option button, until your disc 1 shows up, select it, and bring your pointer to the right arrow on the screen and press enter. Now your booting from the disc 1. Go to disc utility folder at the top of the screen and select your hard drive and then select repair disc permissions. Then shut down and reboot when finished. Nothing? Your hard drive is fu.k.d-Try re-installing the OS. Nothing? Your hard drive is really fu.k.d-You need a new hard drive. Installing a new hard drive in the iBook is a *****. You may want to pay someone to install a hard drive or you can just get a new laptop.
Mar 09, 2010 | Apple iBook G4 Mac Notebook
When i try to turn on my macbook nothing shows up on the screen and the white light on the bottom right turns on and stays on
Plug the power adapter in. Then hold down the startup button for 15 seconds. The light should go off and then after a few seconds. restart normally. The macbooks have a safety device that will lock up the drive if it detects sudden movements to protect the drive...
Let me know if you're back up and running. KEN
Apr 24, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Apple ibook crashed when on MS Word. Black screen fan running???
Sounds like you have a problem with the logic board. This appears to be a common problem with iBook G4 related to the fit of the logic board (ie motherboard) within the case.If you were to take it to apple store the likely fix would be to replace the entire logic board which is very expensive and probably not fiscally sound on a 5 year old machine. Another option would be to try to fix it yourself. If you are feeling brave you can dissemble the laptop and attempt to shimmy the logic board back into position.
Here's a link that detail the approach. http://www.coreyarnold.org/ibook/. This guy had success on two ibooks that had the same problem and they have been working for 2 years since he did his repair
Also, here is a link to a forum that may offer you a few more approaches to solving your problem. iBook G4 won't boot up - fan running & black screen - AppleNova Forums
Hope this helps, good luck!
Mar 30, 2009 | Apple iBook G4 14-INCH Series M7701LL/A...
Ibook G 4/12.1/1.33/5aptx.....will not start
Some computer react this way when the logic board goes bad or have a defect in it.
First, Try this:
Remove the battery.  Plug back in the power cord, then press and hold down the power button til you hear a loud beep sound. then release it.  If the computer starts back up... Then you should be okay.
If not, it may has something to do with the logic board.
Let me know if the above works... We may can try some other things if not.
~ enov8
Jan 07, 2009 | Apple iBook G4 Mac Notebook
Ibook screen issues
This is nearly impossible to diagnose via the Web. It sounds like the logic board is at fault, but not necessarily.
Nov 23, 2008 | Apple iBook G4 Mac Notebook
Apple iBook G4 Mac Notebook Logo
155 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
