Question about RCA 36V430T 36" TV
Our rca 36v430t worked fine until this morning. went to turn it on and sparks came out of the front plugs. now every time we turn it on it shuts it self off and then tries to turn back on. and just repeats this. Is there anything I can do?
    Problem Solver:
  • 6 Answers
No something has gone terribly wrong in the mother board of the tv. sparks cmon man, cant fix that
Posted on Nov 18, 2009
TV will not turn on
There is a problem with your power ic..U need to replace it...
Dont forget to rate
Sep 07, 2009 | RCA 36V430T 36" TV
My rca 32" flat panel tv model l32wd22 won"t turn on
i have a l32wd22 rca -----went out -- the plug from the power cord to the power supply [ a two prong jack on the side of power supply was loose]
i bent the pins slightly then plug it back in and also taped it in place---now it works fine
Jun 16, 2009 | RCA L32WD22 32 in. LCD HDTV
Picture went out on my 36'' RCA television, still have sound.
do you have and big sound system if you do the move them away from youur tv. or you sould just bring it to a shop it must be the picture tube
Jan 26, 2009 | RCA 36V430T 36" TV
99 Dodge Ram 2500 4WD turns over, wont fire
I had a similar problem and believe it or not it was the CAT. An easy way to test for this is to remove the O2 sensor right in front of the CAT. Once you removed it, plug it back in while unscrewed from the exhaust pipe and start up the truck. If it runs fine, the CAT is your problem. This is just a guess and it would be an easy and very cheap($0) test. You did not say if the truck was diesel or gas. Mine is gas that was exhibiting the same problem as yours...good luck!
Dec 22, 2008 | 1999 Dodge Ram 2500 4WD
RCA 36V430T will not turn on
Larry,
I had the same problem yesterday. My wife's uncle is a tv repairman for a major electronics chain. He came by last night and had a look at it. It turned out to be a very inexpensive transformer that went bad. The part itself is only a few bucks. Hope this helps and its not too late.
Nov 09, 2008 | Televison & Video
36 inch RCA tv loses picture and sound, but power stays on
Cable Looses signal power after 20m ... Install signal amplifier
https://youtu.be/AkiKf4G4UE0
May 04, 2017 | RCA 36V430T 36" TV
36 inch RCA 36v430t
Mike-It looks like the power supply is going on your tv-it can be replaced. This happens, usually, when little kids are playing wth the remote or power button on the tv. Turn it off and on a whole bunch of times in a row, kids love to do that, and it burns out the power supply part- to make a CRT tv like your RCA36 incher- which is a beautiful machine- I have the RCA/PROSCAN 36 incher-LAST longer...You should always wait 5 min between turning it off and on. Don't ever sell it. This one is worth fixing. It has better color and sound Than the new plasmas and lcds-The Pros know this. Be carefull, they might try and talk you out of it-so they can fix it and have it for themselves. So what if it's not High Deff. It's a great set.
Jul 02, 2008 | RCA F36650 36" TV
URGENT: My RCA D52W26 Big-Screen TV won't turn on...AGAIN!
These TVs are RCA biggest mistake ,all most all of these models are shutting down accoding to information you just sneeze and they shut down, Id say try soldering around flyback transformer solder all pins.also they have trouble with ribbon connectors as well as the ribbions.
Apr 22, 2008 | Televison & Video
Will not turn on
Does the set make any sounds. DOes the front green led light or flash when you try to turn it on.. if not then it could be as simple as a fuse, if it does flash then it can be many problems
Jan 06, 2008 | RCA D52W19 52" Rear Projection Television
RCA 36V430T 36" TV Logo
82 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
