Question about Belkin (F5D72304F5D7000) Router
No Lan/WAN connection
I suddenly lost internet connection on my home network, when I discovered that none of the 5 ports on the back are working. I can still access the router config through a wireless connection, but it appears that all 5 ports have been disabled. The odd thing is that all of the port lights are on even though there aren't any cables connected. Any thoughts on what might have happened and is there anything I can do? I'm assuming I'm going to need to get a new router, but am hoping there may be a way to fix it.
Thanks in advance for your help!
Kevin
  • kwmcnutt Jan 10, 2008
    I spent most of last night doing multiple resets and in different orders hoping for the best, and unfortunately I haven't had any luck. We actually did have a particularly nasty storm come through in the middle of the night. I'm guessing the spike may have come from my WISP antenna on the roof. All power is decently protected, but I made the mistake of not protecting that ethernet line from the roof.
    Should I keep trying to to reset the unit on the chance that it might kick back on LAN/WAN ports? Have you been able to recover from a spike, or should I just go get me another?
    I appreciate the reply. Thanks so much for the help!
  • kwmcnutt Jan 11, 2008
    Thanks again for your help!
    I'll probably get more use out of it by taking it part anyhow!
    Novelist:
  • 101 Answers
Unplug the router, wait 2 min, and plug it back in. If that work, on the back is a small hole, marked RESET. Using a pencil, or straightne out a large paperclip, press that the button inside gently. Hold it for 30 sec. Release and unplug the unit. Shut down the whole network. "Starting from the wall", power up the modem, wait 2 min, power up the router, and power up your machine. Your router should be at default now. Remember to reset you security, change the password, etc.
I have had to do this several times, sometimes unplugging the power, and plugging it back while holding the button. (Got 3 hand?)
Have you had a storm, or lightning issues lately? Sounds like it got a spike. Living the Florida, where lightning is very common, I have finally put my routers on a small UPS.
Posted on Jan 10, 2008
  • Brad Gaston Jan 11, 2008
    Hi kwmcnutt,
    If all the resets tricks didn't work, it don't look good. Any chance the router is still under warrenty?
    After all that I would guess it is time to get a new one. Lot of nice units out there, and you can get a router fairly reasonable.
    Looks like a small but meaninful funeral, and then strip it for parts, :D
    Sorry we couldn't breath new life into it!
How to configure router & switch
You shouldn't have to configure anything except the PC's should have IP and gateway set to auto.
Here is how it works:
A router connects two separate networks and manage the traffic between them.
In most home network applications the router connects your local group of computers and devices known as the LAN with the Internet, commonly called the WAN or Wide Area Network.
The router usually assigns unique Local IP addresses to all of the devices connected to it via a service known as DHCP. The addresses assigned by your router are private addresses http://en.wikipedia.org/wiki/Private_net... and are not routable across the Internet.
Dynamic Host Configuration Protocol (DHCP) is an auto configuration protocol used on IP networks. Computers that are connected to IP networks must be configured before they can communicate with other computers on the network. DHCP allows a computer to be configured automatically, eliminating the need for intervention by a network administrator. It also provides a central database for keeping track of computers that have been connected to the network. This prevents two computers from accidentally being configured with the same IP address. http://en.wikipedia.org/wiki/Dynamic_Hos...
Your cable or DSL modem will get a Public WAN IP address from your ISP's DHCP service. These public IP addresses are leased in blocks by your ISP and are Internet routeble. The modem is connected to the WAN port on your router. The router will manage the traffic between the devices on the LAN and the Internet.
If your 5 port switch is connected to one of the router's LAN ports and router's DHCP is on then it will configure the clients attached to It automatically.
Feb 04, 2013 | Computers & Internet
How to install d link 802.11G wireless access
Connect modem lan cable to Router Wan / Internet port. From Router Lan port you can either connect your system or switch . wireless : Scan for wireless network from your wireless system. If it shows, connect to your wifi network
Thanks
Mar 25, 2011 | D-Link 802.11g Wireless Router WBR-1310...
How do i hook up my router?
There are several ways to do this, depending on how your network is configured.
Generally, if you have only one router - you connect the network jack of your cable modem or DSL modem to the WAN ("wide area network" or "internet") jack of the router with a CAT 5 network cable or jumper. Each computer's network jack would be connected to one of the router's (4) LAN ("local area network" or "home network") jacks labeled 1, 2, 3, & 4.
In the picture above, the left most jack (WAN) of the router connects to the cable or DSL modem. The "LAN" jacks labeled "1, 2, 3 & 4" connect to each computer's network jack in your home.
The above would change if you are simply adding this router to extend an existing network. You'd likely be using this router as a switch, and leaving the routing duties to the main router. Over simplified, all the CAT 5 network cables would be connected to the 4 LAN jacks. There would be no connection to the router's WAN jack because the output of the first router provides only private IP addresses used in YOUR location. The internet IP address from your ISP is used only at the first router so that your entire home has the single IP address. The WAN jack is for internet addresses only - and the LAN jacks are for local / private addresses in your home only.
Have a look at the LinkSys web site for help configuring your particular model router, or reply with the model and version here.
I hope this helps & good luck. Please rate my reply - thanks!
Jan 28, 2011 | Linksys Wireless-G Broadband Router
The wireless icon is orange. Do you know why??
Hi, 1. Unplug the power from the Modem to the Router 2. Plugin back the power into the Modem and wait 60 sec.. 3. Plugin back the power for the Router wait 60 sec.. 4. Plugin a lan cord from the router to the first wired PC 5. See if you can get on the internet 6. Login to the Router and see if the Connection to the WAN is started? 7. If not started then unplug the wired lan cable and reset the router wait 30 secs to 45 secs before unplug the power then plug the power in again. Then connect the lan cable then connect to the GUI for WEB. Make your See if it connects to the WAN. 8. Test the Network WAN -Internet and LAN - Home Network.
Take care
Jul 17, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
If the wireless internet works, the desktop doesn't
Check that the cable-modem (or the DSL-modem) is connected to the 'WAN' port on the router -- there is only one 'WAN' port.
Check that one of the 4 (or 5?) 'LAN' ports on the router is connected to the network-adapter on your computer.
Turn the router off.
Turn the router on.
Restart your computer, and it should regain Internet access, for both "wired" and "wireless" devices.
Dec 28, 2009 | Belkin F5D8236-4 Router
Trying to hook up router. What is the wan for and the 4 inputs
The WAN port is the physical interface that provides input and output to and from the device that provides Wide Area Networking capability .. i.e. the modem that connects to your Internet Service Provider. The usual choices are a DSL modem, a cable modem or a Wired router or a wired switch.
The 4 other inputs are wired inputs and outputs for wired Local Area Network connections.
The WAN port normally connects to the Internet. It is not necessary to connect anything to the WAN port to have a network. But without one of the usual devices, you will not have access to the Internet.
The LAN ports connect to the network interface port on the individual computers that are part of the local network. One port connects to one computer.
A large system will have routers connected through the LAN ports to the WAN ports on sub routers and so forth.
Nov 25, 2009 | Dynex DX-E402 Router
I had a home network. Now, although the router recognizes an internet signal, the computer doesn't from the router. I still have internet, if I just use the modem. Can you help me get my home network back?...
Plug the ethernet cable from the modem into the Lan port on the router. Your modem and router are trying to use the same gateway ip address. If you know how to do it change the Lan IP address of the router and plug the modem back into the wan port and it should work..
Oct 13, 2009 | Linksys Wireless-G WRT54G Router
I can get a computer on the LAN but not the WAN. All the other computers work fine but I just got a new one and am having this problem.
The WAN (Wide Area Network) port is used for access to the internet through the use of a DSL or Cable modem.
You can't connect a pc to the WAN port it must be connected to one of the LAN ports.
Jul 12, 2009 | Cyberguard SG530 (SG0064US) Firewall
Can I use 2WIRE 2701HG-B router in COX internet connection
No. A router has 2 main interface types WAN (for the internet connection side, and LAN (for the home network side) the 'LAN' side often has up to 4 ports and wireless connectivity for the home network.
The most common routers available at electronics retail use a CAT-5 connection for the WAN ports and the LAN ports. Your DSL modem/router uses a phone line input for it's WAN port, which uses a signal type that is incompatible with the cable modem output.
If COX doesn't offer a router with the cable modem package, you can go and purchase and common brand of home networking router, and attach it to the output of the cable modem.
Feb 28, 2009 | 2wire 2700HG-B Router (2700HGB)
WAN
The wan port is what you hook your modem to. Wan stands for Wide Area Network, which in your case is the internet. Your house with your 2 pc's and networking equipment would be considered a Lan, local area network.
The 4 ports on the router are switch ports, when you hook the modem up to the switch instead of the wan port the modem will only allow traffic from one physical, (MAC) address to pass through, this is why only one of your pc's can access the internet. The wan port on the router has its own MAC address, so the modem will associate with the wan port and trust all traffic that comes from that port.
Finally, after you have connected the modem to the wan port, pull the power cord on the modem then plug it back in to reset it, this will force the modem to orient with the wan port.
Jun 01, 2008 | Computers & Internet
Belkin (F5D72304F5D7000) Router Logo
76 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
