Question about RIM Holster For BlackBerry Curve 8520
My battery is not charging ..I have had the unit for just a week and it has charged until now.
    Problem Solver:
  • 6 Answers
You have a defective battery. they should give you another one this soon a fter getting it. however if its a sprint phone youll just have to buy one
Posted on Nov 18, 2009
I have a euralab robot vacuum and it is only lasting about 5 minutes before it runs out of power. I have had it for about 2 weeks and it worked well at first
I can't guarantee that this will solve the problem, but try deep cycling the battery.
Run the robot until it stops completely and uses all of the battery charge.
Charge the battery until fully charged. Let the battery cool for 6 hours.
Repeat and see if the battery life improves.
Repeat this charge/cool/discharge cycle 3 to 4 times.
Gary
Jul 15, 2011 | Vacuums
Hi, My Kipor 6700TA wont start. Battery died or fuel issue?
It sounds like your unit may not be charging the battery properly.
Try charging the battery and see if it responds properly. If it does, then check the charging circuit. This OFTEN involves a rectifier module which is usually about 1 inch square with four leads. OFTEN there is a fuse, sometimes within the generator housing (stupid place) which protects the low voltage winding.
Here is a hint: Most of these engines have a compression release on the top that one can press then crank up to speed and release. This takes much less effort on the battery. Some have a panel held by bolts. I put hinges on mine for easy access.
REMEMBER the battery is being drained WHILE the unit is running to hold the fuel solenoid open... so if charging isn't working the battery will die.
Test: You should see about 13.75 to 14 volts across the battery when properly being charged while running.
Apr 06, 2010 | Electrical Supplies
Stopped working a few weeks ago - bought and installed new battery seemed to be working OK - now after about a week, it goes for about 15 minutes then stops...
It may need a longer charging period to bring the battery up to full charge. If you have a voltmeter, measure the battery voltage while it is being charged--it should read several volts above the rated battery voltage. If nearly equal, the charge unit may need repair or replacement. Good luck!
Jan 04, 2010 | iRobot 4150 Roomba Vacuum
Does leaving handset in charger shorten battery life
I used to repair pagers for Motorola and back then the biggest problem we had was from bad batteries. Firemen would go on vacation and leave there pagers in the chargers while gone. They would return in a week or two and find that there pagers would not work. The chargers heat the battery while charging and this continued heating after charging would ruin the batteries. New chargers aren't as bad but it is best to cycle your battery. Run it until it needs charging, charge until charged then use until it again needs to be charged. Refrain from unnecessary charging. If you properly cycle a battery it can last for 2 or 3 years before replacing
Oct 07, 2009 | Avanti Microwave Refrigerator
My Garmin street pilot C330 was purchased about 2 years ago. Lately, it has begun giving a message, Low battery. I have had to charged it up on my computer 2 times in the last 2 weeks. What is the problem?...
2 years is generally about it for the battery on the C330.
You most likely need a new battery.
Charging it on or off does not matter.
Run it with the back light on a dimmer mode to increase battery life for now.
Sep 06, 2009 | Garmin StreetPilot C330 GPS Receiver
Re - Lumix Panasonic DE- 994 battery charger ??
Hi Cyril,
In theory this charger is fully automatic and stops the charging process once it detects that the battery has been fully charged (it will not restart charging until the battery has been taken out + put back in).
Of course, as with any electrical item, it's probably safest to unplug it if you're not planning to use it for a long time (e.g. weeks.)
Hope this helps.
Raf
Jun 11, 2009 | Panasonic Lumix DMC-FZ20 Digital Camera
The battery doesn't stay charged in Guardian 10K
I think that is the problem as well. Temporarily, you could just buy a tricke charger from the parts house and hook that up until your other one is changed. Rick
Apr 11, 2009 | Guardian Electrical Supplies
Zire72's on the fritz!
Plug the ac wall adapter to charge the PDA and leave it there.
When the PDA exhausted the battery charge, it needs minimum 30 minutes to charge to the minimum level to have the PDA powering on.
Once it powers on, leave it charging the battery until is fully charged (3-4 hours).
Best regards,
Sep 02, 2008 | Palm Zire 72 Special Edition Handheld
RIM Holster For BlackBerry Curve 8520 Logo
964 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
