Question about Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range
How hard is it to replace an oven temp sensor? Is it worth trying to do it ourselves or should we call in a repair tech?
  • neumanva Nov 19, 2009
    Thanks for the info. Our oven is not under warranty. It was installed in 11/04. I think we may have had a lemon from the beginning as we had multiple gas leaks that took repeat repairs to fix. I was using the broiler (which may have been the 1st time I ever used the broiler)about a month ago and after about 40 min it stopped heating altogether. We found the reset button which helped and it started heating again but now it doesn't keep the temp. I found the temp sensor on line to purchase but am debating whether to call repair tech out or try it ourselves. Question: What is a resistance tester? Is it something we need to purchase? Thanks for any additional assistance you can offer!
  • wire12me May 11, 2010
    The temp sensors usually plug right in. Your model's sensor should be
    on the right side panel,midway between the rack guides. Trouble shooting is different than diagnosing.
    Temperature regulation might be unrelated to the sensor. Your oven has
    the ability to adjust temp settings If
    you
    have a resistance tester, check the sensor unit first. Do not cover the
    bottom of the oven with foil or inserts to keep it clean. If your oven
    is still under warranty, don't work on your oven unless you make sure
    that you will not void the warranty. Give me more
    history by leaving comments and I might be able to give you answers
    that are more precise.
  • 5,911 Answers
This is usually a very simple repair that anyone can do without the assistance of a repairman. The following link explains step-by-step how to replace one:
http://www.fixya.com/support/r393313-checking_replacing_oven_probe
These instructions will work for nearly all gas and electric free standing ranges. If this is a drop in range, it becomes more difficult as you will have to uninstall the range in order to access the rear panel.
Read through the link I provided and let me know if you have any questions. Make sure you follow all safety advice. I hope this helps you.
Posted on Nov 18, 2009
  • Jeff Rockwell
    Jeff Rockwell Nov 19, 2009
    A resistance tester is a simple multimeter that you can purchase at any hardware store. Many are not very expensive at all. If you've never used a multimeter before, refer to the owner's manual that will come with it to learn all the features.
    Resistance is the opposition to current flow and will be the "R"scale readings on the selector dial. They are measured in units called "ohms". The measurements of the oven sensor I have listed in the link I provided for you. An oven probe measured on the Rx1000 scale, should read approximately 1100 ohms if good. This reading vary, however, depending on its temperature.
    This is a very simple repair, that you can easily perform yourself. A repairman will charge the additional cost of labor which can run over $100 in some cases.
The top latch on the door that activates the microwave broke off. Can we replace this ourselves, or do we need to call a technician to come dismantle the door & replace the latch?
Nancy,
Can you see the inside portion of the latch? If so, you might try getting some quick set plastic epoxy. This will require some patients and a steady hand. Mix epoxy, apply to both ends, reattach and hold for a long time! Min 5 min's. Understand, if you cant do this with out getting epoxy on the surrounding parts of the door you shouldn't attempt this. You will end up gluing the latch in place- still wont work. Otherwise call a tech. But unless it is a built in over the stove microwave, it may be cheaper to get a new one than call for service! My charge to come do such a repair would be about $100 plus part. Is it worth it?
Oct 12, 2013 | GE SCA2001FSS Advantium Electric Single...
Dacor Oven Thermostate problem
The replacement temp sensor could be defective.
Mar 03, 2017 | Dacor Ovens
I have a whirlpool gas range sf357pekq the fault code is F2E1 key-tail. ??? when I try to light oven it will click 3 or 4 times gas then will come on and go out same with the broiler . Will this be an easy...
Hi
F2-E1 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jul 26, 2011 | Whirlpool SF380LEPS Gas Kitchen Range
My built in oven AKZ 110 is showing F 03 and nothing happens when I try to tune it in to work just stays on F 03 no fan no light either
This should help any further assistance please feel free to contact me.
WHIRLPOOL
Range/Stove/Oven Fault Codes Non Y-Line
NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
Failure
Code
Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock (ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse F4 Shorted oven temperature sensor Replace oven temperature sensor F6 Problem in time keeping circuit 1. Reset time and/or cooking operation
2. Check for proper ground F7 Stuck function switch or button on Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F9 Door lock circuit Check wiring and test operation of door lock switch bkg-faultcodedivider.jpg txt-gototop.jpg WHIRLPOOL
Range/Stove Oven Fault Codes, Common
Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective 4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Jul 16, 2011 | Whirlpool Ovens
Im trying to set my oven on bake its beeping and reads f4 on the screen??
F4 usually relates to a temperature sensor fault. Meaure the temp sensor at ambient temp and it should measure approx. 1K . If it doesn't, then replace. However, and a big however, I've seen frequent faults such as these where the control board is at fault. The proper procedure is to verify the sensor though first before replacing control board.
Rich
Western Appliance Repair
Appliance Repair Meridian
Oct 09, 2010 | Kenmore Ovens
I have a KitchenAid double oven with convection on the top and conventional on the bottom (model #KEBC207KBL0). When I set the temperature and preheat the top oven, the display shows the temperature rising...
it will either be the sensor or the board,hopefully it's not the board,the part number for the sensor is 4455636 and subs to w10131825,the sensor is around 100 bucks,there should be a tech sheet on the machine most likely behind the touch pad on the top,it will tell you how to check the sensor with a meter,just unplug the sensor and read it out i think it's around 1100 ohms but check that on the tech sheet,if it's not the sensor most likely it will be the board part number 4453661 and that's around 300 buckseverything runs through this computer board but the sensor tells it how hot it is in the oven hopefully you have a bad sensor.let me know what you find,you'll most likely have to pull the oven to repair it but maybe just enough to get the top open,good luck
Sep 04, 2010 | KitchenAid KEBC207 Electric Double Oven
I have a double oven top one stopped heating up sooo i just switched the elements from the bottom to the top as to order the parts but that isnt the problem the top still won heat up
This could be a faulty circuit or sensor that will need to be replaced before the oven safety feature will disengage. If the Temp sensor is not registering as working or the load sensor it will not allow the element to heat up. This is a safety feature. You will need a repair tech to diagnose this and do the repair.
Oct 17, 2009 | Frigidaire FEB27S5A Electric Single Oven
I have a frigidaire PLES389ECE oven with runaway temp. when I set oven temp.,the oven will exceed set temp to 450' ++
Check oven sensor-- 10-11K ohms at room temp. Check wiring to sensor.
If ok - replace electronic control.
Affordable Appliance Repair
Orange County, CA
Aug 22, 2009 | Kitchen Ranges
Error code 065 jjj jjjj jjj 065 (frigidair Model feb398ceb)
2 Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace F2 Oven too hot Check Bake function F3 Oven temperature sensor open Check oven temperature sensor, 1100 ohms F4 Oven temperature sensor shorted Replace component F5, 6, 7 EOC (Electronic Oven Control) failure Replace component F8 Lock switches Check or Replace component Version 3 Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control) F2 Oven too hot Likely a bad oven temperature sensor (should read 1100 ohms) Possible bad EOC (Electronic Oven Control) F3 Oven temperature sensor open Replace oven temperature sensor F4 Oven temperature sensor shorted Replace oven temperature sensor F5 or F6 or F7 EOC (Electronic Oven Control) failure Replace EOC(Electronic Oven Control) Version 4 Failure
Code
Condition Check/Repair F1 Circuit board defective Replace control board F2 1. The oven temp has risen above 665F and the door is not locked or
2. The temp has risen above 965F with the door locked 1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
2. Check 8-pin connector. Check and replace oven temperature sensor if necessary F3 Oven temperature sensor is open (above 3000 ohms) Check resistance of oven temperature sensor, check for open wiring between oven temperature sensor and control F4 Oven temperature sensor is shorted (below 500 ohms) Check resistance of oven temperature sensor, check for shorted wiring between oven temperature sensor and control F5 Internal watchdog circuit has detected a failure Defective EOC (Electronic Oven Control) F6 Shorted buttons Check push buttons and dome switches on control F8 Logic interrupted (lock motor switch sequence) Check door lock switches and wiring
Nov 18, 2008 | Frigidaire Kitchen Ranges
Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range Logo
182 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
