Question about Mitsubishi CS-40509 40" TV
Mitsubishi CS40509 This is a 40" old fashioned tv. ( NON HDTV) THe picture keeps getting wider. Does anyone know how to adjust? I dont have a manual. Thanks Becky
  • 2,427 Answers
Opeen the back panel of the tv,
near the coil you would see 6 potentometeres, (small turnng things) one is written vhold and and the other horizontal scroll, adjust these to set the picture,, Be careful nt to eletricute your self..
IF THAT FAILS THE PICTURE GETTING WIDER AND SMALLER CAN BE CAUSED BY EIGHTER THE COIL, HORISONTAL CIRCUIT OR VERTICAL CERCUIT.. most often its just a capicator.
Posted on Jan 10, 2008
Making pcture wider
Find the Aspect ratio button on the TV remote. Press it a number of times to cycle through the options. Stop when the picture is the shape you want.
Have a read of your TV manual. Stuff like this is detailed in there.
Sep 02, 2014 | RCA L22HD31 22 in. LCD HDTV
Would my 1 and a half year old samsung 40" smart tv model (# UN40D6000SF ) be covered under the class action lawsuit ? and where can i get a manual for this set ? thanks
you can open the back cover of the tv using with a phillip screw driver. to check weather their are bulging electrolytic capacitors at the power supply board.
Jan 03, 2013 | Samsung LN40B530 40 in. LCD HDTV
We dont have the tv remote and can not adjust the colors very well?
It may be a pain in the rear to do, but if there are buttons on the tv itself, you may be able to manually program./adjust the colors from the tv buttons. there should be one that will get you to menu and then select appropriate one to adjust contrast. other than that you will have to contact the mfg to request another remote, or refer to owners manual to see if it can be done. outside of this, if you know anyone else with the same tv, borrow their to adjust YOUR tv...
Oct 17, 2010 | Mitsubishi WS-48315 48" Rear Projection...
I have a sony Vega 55" kdf-e55a20, It is 3 years old, and now the picture and sound fade away for 10-15 sec every hour or so and comes back! Anyone knows what the problem is?
Lamp is getting weak and TV shuts off and turns on itself because of weak lamp in TV that you see picture and sound fades away for some time until TV reboots.
Replace lamp in TV to solve this issue. Lamp replacement procedure is written in user manual and its an easy work.
Please buy Sony original lamp for your Tv safety.
Thanks.
Dec 23, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
SHARP aquos 1080p HDTV: VCR image flickers when playback
Well I do not know either machine but suspect if the video is old either your video's output is too rough for the TV because:-
It has some age related problem of wear.
The output signal is not quite correct in quality.
There may be a security signal applied on its recording material.
These are some of the issues, videos are very sloppy (by todays standard) but could get away with it with analogue TV's because of wider design variables inherent in that system.
Modern TV,s are less hardware more software driven and as such are critical about errors going to a blank screen as a way of escape an issue they can't resolve (mummy mummy!).
The video may need checking for mechanical or electronic issues, a favourite being power supplies which can generate noise from defective components that disturbe other equipment, or mechanical alignment which changes through wear and time.
You could try conversion to hdmi signal though cheap converters are limited in their method of doing this but might show you if it would work.
Cheap versions are about £10 but have no level controls (contrast, brightness or colour to trim for best picture)
Hope this helps............
Apr 27, 2017 | Televison & Video
Sony bravia kdl-46v2500
TRY A DVD PLAYER TO VERIFY IF IT COULD BE THE SAT.BOX OR MAYBE TV COLOR ADJUSTMENTS.JOE TV
Dec 30, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Akai tv picture problems
i want the cercit digram for akai tv ct-t29sa3a
Nov 16, 2007 | Televison & Video
Samsung adjusting the picture
I started reading the manual with your question in mind, but I found that the instructions for screen controls take up about 40 pages. I'll just put the URL for the owners manual here instead. That way you'll have all the information you should ever need for making adjustments. ;) http://downloadcenter.samsung.com/content/UM/200705/20070515083727984_BN68-01167A-01L02-0331.pdf
Aug 04, 2007 | Samsung LN-T4042H 40 in. LCD HDTV
How to manually adjust the centering of the picture
On newer televisions the centering adjustment is only in the service menu. I wouldn't suggest anyone accessing it unless you understand all of the abbriviated alignments.
Feb 21, 2007 | Samsung TX-R2035 TV
Televison & Video Logo
80 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
