Question about Hyundai Computers & Internet
No power , power switch does not respond. checked power cord, fully connected. Tried 3 different home outlets.
    Problem Solver:
  • 13 Answers
Mine did the same the other day and all I had to do was replace the fuse in the plug. Just a thought if your monitor gets power direct and not through the PC
Good Luck
Posted on Nov 18, 2009
I have plugged in my new laptop correctly but when I tried to switch it on the laptop does not respond. Is my laptop broken or am I missing something?
Thank you using fixya.
Here are the things that you need to do:
1. Use a different power outlet. Maybe the outlet is bad.
2. Check the ac adapter. check if the light is lit. The light is a power indicator. If there's no power on it, then, you have to make sure that it's not broken or it's connected properly to the power outlet.
3. Check for any power indicators in the laptop. Like lights lit or the charge indicator. If there's none, then, the laptop is not receiving any power. It might be caused by a defective battery.
4. Remove the battery. Plug in the laptop to the ac adapter without the battery on it. Check for power indicators. Press the power button.
Let me know if there's any development. Leave me a message in this post.
Apr 02, 2011 | Computers & Internet
I stopped playing a game two days ago(ps3) and left it in the off position with the red light on. When I returned home from work today the red light was off. I tried flipping the switch on it, different...
is it on an extension cord? if so... your pet might have stepped on the switch. then again you might have been careless enough to leave it on to let the light short out. sooo... you have an broken peice of ****
Jun 22, 2010 | Sony Playstation 3 (PS3) Console
I have a SONY PCV-RX660. I had the computer disconnected from all power sources for an extended period of time. Tried to start it up yesterday and the computer will not start....no problems with speakers...
Usually there is a switch on the back of the power supply that turns the supply on or off. Make sure it is turned on. Try using a different 3-prong cord between computer and outlet.
Oct 12, 2009 | Sony VAIO Digital Studio PCV-RX660 PC...
Playstation not receiving power
This could be a problem with your AC power cord, try these fixes. If they do not work you ca contact sony at:
www.us.playstation.com/Support/PS3
or
www.uk.playstation.com/help-support/ps3
  • The console might not be turned on. Turn on the console using the main power switch on the back of the console.
  • Make sure the AC power cord is securely connected.
  • Visually inspect the AC power cord for damage. Do not use if frayed, cut, or damaged in any way.
  • Confirm the wall power outlet is active (receiving power). Try a different power outlet.
  • If possible, test the power cord by connecting it to a different PLAYSTATION 3.
  • If possible, try another AC power cord on your PLAYSTATION 3.
  • If you experienced a power surge, shortage, or a lightning storm in your geographical area recently, this may have affected the PLAYSTATION 3 power supply and the PLAYSTATION 3 may need service.
  • Make sure the vents are not obstructed in anyway.
  • Make sure there is adequate ventilation for the PLAYSTATION 3. There should be at least four (4) inches of clearance between the air vents on the system and any walls, televisions, entertainment centers, etc. Otherwise the unit may not function properly due to what are actually environmental issues.
  • Jun 23, 2009 | Sony Playstation 3 (PS3) Console
    My Canon MP780 will not power on.
    This is what the service manual says;
    (1) Check the power cord
    connection.
    (2) Check the connection between
    the SPCNT board (JPSU1) and
    power supply unit.
    (3) Replace the power supply unit.
    Jan 05, 2009 | Canon PIXMA MP780 All-In-One InkJet...
    Change fr 3 prongs to 4
    They wire in the same except the green wire will go to a ground screw which should be right in the same area with a green color to it. If no ground screw, hook the green together with the white (center) wire. Hope this helps!
    Dec 27, 2008 | Frigidaire GLEQ642A Electric Dryer
    PS3 starts but wont turn on
    you could have a problem with your power cord which is causing your ps3 to short before the system can power on fully. try using a different power cord or check the ports of both the outlet and the ps3 to make sure there is nothing blocking anything. also, try using a different outlet.
    Oct 14, 2008 | Sony Playstation 3 (PS3) Console
    No Power
    This is Kodaks suggestion:
    Verify that the large end of the AC power cord is inserted fully into a power outlet.
    Verify that the small end of the AC power cord is inserted fully into the DC-in port on the back of the printer.
    Turn on any power strip or wall switch that is connected to the printer.
    Here is a page that might be of some help to you:
    http://www.kodak.com/global/en/service/publications/urg00467toc.jhtml?pq-path=7748
    Good luck and let us know how it goes.
    Aug 14, 2008 | Kodak EASYSHARE Plus Series 3 Thermal...
    Printer doesn't turn's on
    Per Canon:
    Solution: Disconnect and Reconnect AC power adapter or power cord to the device and electrical source
    Secure all Power Connections
    • Disconnect the AC Power Adapter or power cord from both the device and the electrical source.
    • Then reconnect it.
    • If you are still unable to obtain power to the device, try another power outlet.
    • If possible, try connecting power directly to a wall outlet (as opposed to using a surge protector or power strip...just as a troubleshooting measure).
    If this does not work, have you tried a different outlet to ensure that the outlet isn't the issue? Also, when you press the POWER button, does the printer respond at all, or is it basically dead?
    Please post back if you need further help, otherwise, thank you for using and rating FixYa!
    May 24, 2008 | Canon PIXMA iP1600 Printer
    Computers & Internet Logo
    181 people viewed this question
    Top Hyundai Computers & Internet Experts
    rhodesworks
     Zackery G
    Zackery G
    Level 1 Expert
    Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
