Question about Craftsman Gas Mini - Tiller/Edger
Removing flywheel from chipper-shredder model number 247-775870
  • 169 Answers
REMOVE THE FLYWHEEL NUT, CHECK FOR BURRS ON THE CRANKSHAFT, REINSTALL NUT LEAVING 1 OR 2 THREADS EXPOSED, APPLY UPWARD PRESSURE ON FLYWHEEL WITH SMALL PRYBAR BEIGN CAREFULL NOT TO DAMAGE ENGINE, GENTLY TAP THE END OF THE CRANK WITH A SOFT BRASS MALLET OR BLOCK OF WOOD
Posted on Nov 19, 2009
  • Matthew fallon Oct 18, 2011
    Thanks Jeremy, had the same problem,this worked like a charm. really helped me out !
I need to sharper the blades. How do I remove the fly wheel
The flywheel takes a puller, but you should not have to do that just to sharpen the blades.
Mar 24, 2014 | Central Machinery 5-1/2 Horsepower Chipper...
Chipper was running great then shut down...now there is no spark...what might be the problem?...it was new this past spring
Use a spark tester and make sure there is no spark.If there is not then you need a new ignition coil.Take the side cover off and you will find the coil above the flywheel.remove the two screws and the wires to get it out.when you replace it you will have to set the air gap at .010-.012.most of the time when you buy anew one it comes with a guage with it.if not take a piece of metal or thin piece of cardboard that measures the right size.put new one back on .you should be able too slide it up and snug the screws enough to hold it in place then put your gauge in between the coil and flywheel.turn the flywheel until the magnet is in line with coil.loosen screws and the magnet will pull down the coil on top of gauge.tighten screws and rotate the flywheel to get gauge out.
Dec 19, 2010 | Troy-Bilt Chipper Shredder
I need a parts and owners manuel for a Super Tomahak Wood chipper made by Garden Way Mfg. Co. where do I go to get one?
Hi and welcome to FixYa. I am Kelly.
Go to this site:
http://www.brentchalmers.com/
I note your looking for the Super Tomahawk. If you can come up with a model number I think I can find your parts manual for sure. (or at least an on-line parts list.) Also.... If you can come up with an engine number like OH120 or L90 off of the engine I can find you a manual for the engine also.
This is the list of Manuals available there:
  • 1983 W-W Grinder Inc. Manual and Parts List Super Tomahawk 5-8-2G/C and Tomahawk 5-8-2G/M Chipper/Shredder (40 Pages)
  • 1989 Troy-Bilt Owner/Operator Manual Junior Tomahawk Chipper/Shredder (24 Pages)
  • 1989 Troy-Bilt Technical Manual 4HP, 5HP, & 8HP Models Tomahawk Chipper/Shredder (12 Pages)
  • 1991 Troy-Bilt Owner/Operator Manual Junior Tomahawk Chipper/Shredder (24 Pages)
  • 1991 Troy-Bilt Knife Kit number 1772231 (1 Page)
  • 1992 Troy-Bilt 5HP Model Service Kit (Part Nos. 1901153 and 1901804) For Chipper/Vac (1 Page)
  • 1992 Troy-Bilt Owner/Operator Manual 47260, 47261, 47271, 47272 Chipper/Vac (60 Pages)
  • 1993 Troy-Bilt Sales Brochure Chipper/Vac (4 Pages)
  • 1993 Troy-Bilt Owner/Operator Manual 47265, 47266, 47267, 47276 Tomahawk Chipper/Shredder (44 Pages)
  • 1993 Troy-Bilt Parts Catalog 47265, 47266, 47267, 47276 Tomahawk Chipper/Shredder (16 Pages)
  • 1994 Troy-Bilt PTO Chipper/Shredder Owners Dog Clutch Kit 1902404 (1 Page)
  • Hopefully your model is one of the above.
    Here is link to the Parts manuals:
    http://www.partsandservice.com/html/TroyBilt/cs/
    There are 90 parts manuals there.
    Again with a good model and engine number I can probably come up with your exact manuals.
    Thanks for chosing FixYa,
    Kelly
    Oct 20, 2010 | Troy-Bilt Chipper Shredder
    After turning on it began making a rattling sound coming from yhe blade and then it turned off. the sound was of meyal hitting against the frame or something
    For safety remove the spark plug and disconnect it from the plug wire. Tilt the machine back and rotate the blade by hand and make sure it clears the mower deck all the way around. Check to see if blade is tight. Any movement of the blade on the shaft is unacceptable. Tighten blade, if it won't start with blade tightened it may have sheared the flywheel key.
    Oct 14, 2010 | Yard Machines 24a 021h700 4.5 Horsepower...
    How do you rotate shredder blades on duerr m/n 678?
    Interesting question --
    I just picked up one of these over the weekend, and was able to get the flywheel off with minimal excitement. After removing the center bolt from the flywheel, I used a hammer to "encourage" the flywheel off the keyed shaft from the back-- through branch feed hole in the housing. It took quite some time, and I rotated the flywheel as I did it to keep it from binding up, but it eventually came off.
    As an aside, would you let me know if you've found any source for parts or documentation? I'm going to attempt some repairs on the flywheel and chipper blades, but may end up wanting to replace them.
    Apr 07, 2010 | Heavy Machinery
    I have a Troy-Bilt #47044 Tomahawk Pro Chipper Shredder. How much can I expect to pay for replacement knives, and where can I find them? Mark
    47044 is a good model number for the 12HP Tomahawk Pro Chipper. The knife kit is part number 1772231MA.
    There are a few different vendors selling this knife set on Ebay.
    Mar 12, 2010 | Troy-Bilt Chipper Shredder
    Have Troy Bilt 47279. Need Vacuum Snout.
    i NEED A REPLACEMENT VACUUM SNOUT FOR A 1990 TROY BILT CHIPPER-VAC. THERE IS NO MODEL NUMBER FOR THAT YEAR, ONLY DESIGNATED AS "MODEL 5 HP".
    Nov 06, 2009 | Troy Bilt Walk Behind...
    What engine model does it come with troy bilt
    As there is a model number on the chipper there should be a model number on the engine. You may have to stand on your head to find it but, it's there.
    Oct 11, 2009 | Troy-Bilt Chipper Shredder
    Troy-Bilt Chipper Vac Model 47282: Need a part #
    Get in touch with frederick7153@comcast.net or 651-786-4277 he has parts new and used. Also does bag repairs
    Sep 30, 2009 | Troy-Bilt Chipper Shredder
    Craftsman Gas Mini - Tiller/Edger Logo
    333 people viewed this question
    Top Craftsman Garden Experts
    Wade Mobley
    Wade Mobley
    Jim Parker
    Jim Parker
    Dean Gruber
    Are you a Craftsman Garden Expert? Answer questions, earn points and help others
