Question about Lexmark X75 All-In-One InkJet Printer
Printer jams I cannot get envelopes to print, it seems that they just don't go through and I get constant printer jam messages, it's so annoying, paper goes through without a problem. How can I solve this please? Di
  • fernie73 Jan 15, 2008
    Hi
    It has always printed envelopes before and is marked for envelopes on the lid.
    Thanks anyway.
    Hi
    At the back where the paper rests against the lid, separate from the scanner, the lid is marked for envelopes and has a slide to keep them in place, and as I said has printed envelopes before, I will try and locate the manual and check.
    Thanks
    Problem Solver:
  • 35 Answers
Page 11 of the manual does not list envelopes. It was not designed for printing envelopes.
Posted on Jan 15, 2008
  • raymw Jan 15, 2008
    The X75 is an all in one printer. The lid is the lid of the scanner part of the machine. The X75 was not designed for printing envelopes.
    Now, it may be that you could get envelopes through the feed rolls, etc., before, but it would be very dependent on the type of envelope used. Also, it is likely, if you have printed a number of envelopes, that the roller system is worn locally, or has picked up grease or glue from the envelopes. It may not effect paper feed for normal paper.
    Obviously, you have checked through the system to remove any bits of chad, dust, dead flies. ;-) etc. It may be possible to clean the rollers without too much dismantling, or get spares.
    Does you manual specifically say that it will print envelopes?
    Best wishes
Why my printer keeps jamming
Does it print then jam and then print a few pages and jam again? If that is the case, you might want to check your paper. It could just be that you have to "fan" the pages before inserting them into the tray. Also, try not to "rush" the printing process if you are doing envelopes...that will sometimes jam the printer and cause everything to go out of sync. Have you turned off the printer and restarted the computer. That resets things also.
Please take care to check for any remnants inside the roller area. If you have jammed the printer and then torn the sheet to get it out, a part of that could be inside. If that is the case, I would suggest that you UNPLUG the unit before trying to look inside and remove anything. Safety first, don't let yourself get frustrated and then do something silly and get hurt.
If those ideas don't help, try re-installing the printer. Just name the installation something else so that you will know which one to delete if you get it working properly.
Apr 08, 2011 | Office Equipment & Supplies
I cannot get the envelope fuction to work correctly. The printer tells me I have a paper jam, when in fact I am trying to print an envelope
The printer will stop printing is there is an error, check for any paper jam before printing. Take note of the error message and locate the exact jam.
Use the manual feeder when printing on envelopes. You may click on the link http://bit.ly/rnHp5b to see instructions on how to go about the procedure using the manual feeder.
For further assistance, please call Lexmark Technical Support.
Mar 08, 2011 | Lexmark C532n Color Laser Printer
HOW DO I PRINT ENVELOPES ON A BROTHER MFC-465CN PRINTER? SCREEN TELLS ME THERE IS A PAPER JAM WHEN THERE'S ONLY ONE ENVELOPE IN THE TRAY.
my brother mfc 7860 tells me i have a jam when i print envelopes only- there is no jam and will print the next 'page' fine- have to turn it on and off 4-5 times to get it to print one- any ideas anyone???
Aug 11, 2010 | Brother MFC-465CN InkJet Printer
How do I print envelopes? It just jams when I
when you load the envelop, you should make sure that you adjusted the tray to lock the envelopes in place, or otherwise, they will move and cause a jam
Sep 22, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Repeated paper jams with envelopes I can't seem to even get one done out of the printer.
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
PREM
May 26, 2009 | HP PSC 1210 All-In-One InkJet Printer
Envelopes jam in my hp 6940; paper sheets feed fine
I have had varying success with envelopes. Can you feed in the other way round? Sometimes different envelopes perform better. The peel N seal can be very difficult
Apr 10, 2009 | HP Deskjet 6940 InkJet Printer
Printing Birthday Card Envelopes approx 4.75 x 5
There should be brackets to hold the paper in place. Most printers suggest that you feed the envelopes in landscape instead of portrait.
Dec 17, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Carriage jam message HP D7360
Try opening the top cover again and look into the printer with the help of flashlight or some light. I think you will find that there is paper stuck on one side of the carriage. Do this aspa since if the pape is really there, t will not let the carriage sit over the rubber gasket and will dry the ink out.
303Electronics eBay Stores
http://www.303electronics.com/
Jun 01, 2017 | HP PhotoSmart C4280 Laser Printer
PRINTING ENVELOPES
Printer does not except all kinds of envelopes. Please read user guide which envelopes are allowed: http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000063/faq000063_003.html?reg=us&c=us&lang=en&prod=dcp110c_us&Cat=4
Aug 27, 2007 | Brother DCP-110C All-In-One InkJet Printer
Lexmark X75 All-In-One InkJet Printer Logo
65 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
