Question about Zyxel P660HW-D1 Router
No internet connection. I bought this embarq 660 on ebay and am trying to use it with another dsl provider. I got the router part to work with laptops just can;t connect to internet. please help
  • 241 Answers
You can't just connect up a new router to some ISP's (internet service provider) and expect it to work. My ISP requires the MAC address of the router before it can access the internet. Call your ISP and tell them what your doing. The MAC address is the physical hardware address of your router (there is no other one the same in the world). The MAC address is on a sticker on the router and consist of 12 numbers and letters.
Posted on Nov 18, 2009
Why is my embarq 660 series DSL modem box's 1st
Telephone your Internet Service Provider, and have them check that you've paid your monthly fees, and that the DSL-modem at "their" end of your telephone-circuit has not failed.
Try a different DSL-modem, to see if your particular modem has "died".
Check the 2-strand or 4-strand wire from the DSL-modem to the wall-outlet, to make sure that it is properly connected.
Try a different 4-strand wire.
Aug 18, 2011 | Computers & Internet
I inherited a D-Link DI614+ Wireless Broadband Router from my son. I have DSL from Embarq. How do I set up the router to work with the DSL modem 660 series?
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Feb 15, 2010 | D-Link AirPlus DI-614+ Wireless Router
Every time i hook up the wireless router to the dsl router it doesnt find the internet ( its is a embarq 660 series dsl router and i have a belkin N1 wireless router)
the problem you are facing is due to the double nat issue(the embarq modem provides the ip address in the range of belkin router, that is 192.168.2.1)...hardwire the pc to the lan port of router.
login to the router setup page(type 192.168.2.1 in IE)
in router setup page, click on lan settings and change your lan ip to 192.168.5.1....the problem ll get resolved...if still the status is not connected, switch off the router and modem and switch on it after a minute....it ll get fixed
Feb 12, 2010 | Belkin (F5D8231-4) Wireless Router...
I`VE GOT ZYXEL P-660HW-T1 WIRELESS MODEM I BOUGHT
You will have to reset the router to factory settings. There is a small hole in the back, depress the microswitch with a paper clip when the power is on. The default password is 1234. Some of these devices are general, while others are hardwired to work with certain providers. So if, say, this 660 is branded with embarq it is unlikely that you can set the parameters to work with other providers.
I should mention that if you care about security you should not use WEP - a cracker can break an internet connected WEP device in minutes with the right toolset. The protocol has many problems that simply can't be fixed, period. Consider using WPA2 with WPA backcompatability, as allowed by the 660.
Dec 11, 2009 | Zyxel P660HW-D1 Router
When trying to install gets message cant find internet trying to hookup to embarq 660
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi there! This are some steps on how to setup your modem/router
New DSL Modem Available
Embarq is now shipping an updated version of the DSL Modem called the "660". It is smaller than the older model (645) and is much easier to setup.
A few years ago, Sprint/Embarq changed the way their servers communicate with the DSL modems. The new method is called DHCP, which is how the 660 modem works. The older 645 Modem used "PPPoE". So it's best to have the new 660 DSL modem.
The older 645 modem also had the same default IP address as the Linksys Router (192.168.1.1) - so you had to change one of the addresses to make them work together.
The new 660 DSL modem uses 192.168.2.1 as the default IP address. This does not conflict with the default IP address of the Linksys Router (192.168.1.1). Note that if you had changed the Linksys Router IP address to 192.168.2.1, then you will first need to reset it back to the default address 192.168.1.1.
If you call Embarq and request the new 660 DSL modem they will sent it to you at no cost. When you install the 660 DSL modem, you need to be sure that you power down the old 645 modem amd leave it off at least 1 hour before you plug in the 660 DSL modem. The Embarq server needs to "forget" the old 645 modem. After an hour, all you should have to do is plug in the new 660 modem and everything should start up properly.
Call Embarq Tech Support 1-877-646-3282 if you have problems setting up the modem. If the Internet Lights does not come on after a few moments - then call Embarq Tech Support.
Aug 15, 2009 | Belkin Wireless Pre-N (F5D8230-4) Router...
I have the same problem with a dlink dir 825
hi,
I believe the firmware of the router is outdated. Plz try to upload the firmware for ur router from d-link router website.
thanx and regards
sukhiii
Jul 19, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Belkin Wireless N router/Embarq 660 modem/No internet
Make sure your physical connection is correct. From the modem, the ethernet cable should plugged in to the Internet/WAN port of the router. And your computer to port 1. Access the setup page of the router again and Enable the MAC Address Clone setting. Clone the MAC Address of your PC there then power cycle the router and modem. You should be all set.
Apr 15, 2009 | Belkin (F5D8231-4) Wireless Router...
2WIRE 2701 router
You must log on to the browser interface of the router (usually for 2wire they use 192.168.1.254) run the set up wizard it will come to a screen which asks for a key code, this key code is provided by your ISP, you can try one of these and see if it works
if you have a PPPOE connection (you have a user name and password to log on to the internet with use this one.
5225-26Q4-2262-22AS-B28F
if it is not PPPOE use this
5225-26P4-6262-22AS-B2E7
to manually configure the router use this
5225-2374-WG62-22AS-BJ7P
If these do not work call your internet provider and ask them for the key code.
after that you should be all set.
Aug 04, 2008 | 2wire 2700HG-B Router (2700HGB)
Belkin wireless G router will not allow connection to internet
check for the physical cables, check if they are connected properly, if yes, try to reset the router and reconfig it
Jan 05, 2008 | Computers & Internet
Zyxel P660HW-D1 Router Logo
343 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
