Question about Dishwashers
I have a 10 year old GE dishwasher that does not completely drain all the water. I checked my garbage disposal and it is not clog with food. I'm trying to determine why the dishwasher will not drain properly. Can anyone help? Thanks. Johnny
catriver
  • 878 Answers
SOURCE: GE diswasher GSD4020Z02BB doesn't completely drain
rs, in the back under the screen is a piston nut assy. This is a common problem on these GE's. The seal on the assy. becomes warped or worn and when this happens we get water left in the tub after drain. It's an easy fix. The screen comes off and the pistion nut assy. simply unscrews. The part number is WD24X220. You can look it up on the net, inexpensive. Catriver..post back.
Posted on Mar 05, 2007
  • 1073 Answers
SOURCE: kenmore dishwasher makes grinding noise while draining
disassemble the top of the dishwasher pump, remove the bottom spray arm and remove the screws on the top of the pump housing this will get you started
Posted on May 03, 2008
  • 360 Answers
SOURCE: GE Profile PDW7300, Leaves 2 - 3 inches of dirty water in bottom
check for a clogged discharge hose where it connects to the plumbing under the sink...this is the most common area for a clog. if no restriction is found, the discharge valve will need to be tested
Posted on Feb 20, 2009
heatman101
  • 43501 Answers
SOURCE: GE dishwasher GSD3200G00ww
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
y
Posted on Sep 29, 2010
heatman101
  • 43501 Answers
SOURCE: GE NAUTILUS GSD3200-J00WN DISHWASHER WON'T COMPLETELY DRAIN
heatman101
When dishwasher is emptying it is backing into sink
there is probably nothing wrong with Dishwasher itself.
Your Sink drain is stopped up or your Garbage disposal is clogged.
usually, dishwasher drain is connected to the Garbage Disposal, but if the dishwasher empties the water into the Garbage disposal, if its clogged then water will come out of the sink. Same if sink is clogged between sink and sewer.
If you fill up your sink and then water drains away, then you know your sink itself is not the problem. If its only the Garbage disposal side that does not drain, its the garbage disposal that is clogged.
Dec 22, 2013 | Dishwashers
We bought a new dishwasher because the old one wasn't draining all the way. Same problem with the new one?
The pump is a motor which runs in one direction to spray water in the dishwasher to clean and the opposite direction to drain the water. The problem could be from a clog or kink in the drain hose. Several years ago the drain line would connect to the sink garbage disposal. If the garbage disposal is not draining or the dishwasher connection to the garbage disposal is restricted or clogged the dishwasher will not drain. Under the sink, look at the garbage disposal to see if a rubber hose is connected at the side of the disposal unit. If a hose is connected to the side of the disposal, remove the hose clamp and check for any restrictions from garbage in the inlet or hose. You can use a screwdriver to clean the fitting to the garbage disposal and a wire hanger to free any restrictions in the hose. If the dishwasher does not connect to the garbage disposal it should connect to the sink trap. This is more common with new dishwashers because they have built-in disposals. Disconnect the drain hose from the sink trap and the dishwasher and look for a clog at the sink connection. The dishwasher inlet should have an angled piece of plastic or metal facing downward to prevent the waste from the dishwasher from spraying up into the sink. Do not get to aggressive with the cleaning in order to prevent breaking the angled piece of plastic or metal. Look for any kinks in the hose and try to run water through the hose, but do not use the sink which you removed the drain line from or it could leak under the cabinet. If you see a bad kink replace the hose with a new one. I hope this works and you find the problem without a great deal of time or trouble.
Nov 22, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher overflowed, garbage disposal still works. Ran the dishwasher and noticed food and debris shooting back into sink thru garbage disposal. Water was on floor. Upon completion of full cycle, water...
Before loading into the machine you have to remove food particles. Washer will wash the greasy surface. If particles are left in the dishes, the same will find entry to the drain system. Check the drain filter in your machine. Clean them. Mostly problem will be solved!
Apr 08, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
Cycle finishes but water is not draining
Sounds like too much water leftover.
Give me a make and model number of the dishwasher.
Check that the drain hose isn't kinked, and that where the drain connects at the garbage disposal at the sink isn't partially clogged. And, is the garbage disposal clean/clear of food stuff's.
I had a similar thing happen to me a few weeks ago, and it turned out the kitchen sink drain line was clogged.
Dec 16, 2009 | Cars & Trucks
WATER IN MY DISHWASHER
my dishwasher did the same thing last week and it was the garbage disposal. I had to run the garbage disposal and clear it out and then reach my hand in the dishwasher to check for any items blocking the drain. I had nothing and clearing out the garbage disposal did the trick.
Oct 12, 2009 | Whirlpool 24 in. DU1055XTP Built-in...
Water didn't drain, left in bottom of washer tub
I had similar problem and it ended up being a clog at the point where the drain hose meets the garbage disposal. I had to unhook the hose and clean out the food that had accumulated (horrible smell). You may have to stick a screwdriver into the garbage disposal hole where the hose fits and clean the food out there also. Then put the hose into a bucket and run a few cycles to ensure the hose is free.
Aug 01, 2009 | GE Nautilus 24" Built-in Dishwasher
Garbage disposal spouting water after turned off
Hello, turn on the disposal without water and pour hot water into disposal. Be careful not to let it splash back on you! If this doesn't help you have to remove the drain and drain trap and clean them out. If you need more help let me know. Good luck.
Jan 23, 2009 | GE 24 in. Profile PDW7800 Built-in...
heatman101
Dec 27, 2008 | GE Profile PDW9880NSS Stainless Steel...
My GE dishwasher after complete washed look like water not out drain (water remain in the tub)
Normally, there is a filter that precedes the pump and that's probably clogged with food by products. Look for the filter screen near the bottom of your dishwasher and remove any debris there.
Another consideration is if your dishwasher drains into/ through your garbage disposal... If so.. make sure that is empty and drains properly when you run the water in the sink. Hope that helps....
Aug 07, 2008 | Dishwashers
Dishwashers Logo
19 people viewed this question
Top Dishwashers Experts
