Question about Sony KV-36XBR450 36" TV
Our Sony TV started to display something that looked like interference, with sharp horizontal white streaks across the screen, accompanied by loud popping noises. It has nothing to do with the cable, because we tried tried attaching it to another television, and it worked perfectly fine, so it isn't interference. Our television started out making the sounds and white streaks occasionally, but it progressively got worse, and occured more often. Now, when we turn on the TV, there is no sound or picture. It goes from blue screen to black screen with many white/color flashes with NO SIGNAL in the corner. The cable IS plugged in.
  • Sony Master
  • 586 Answers
According to the symptom the FBT Which is called "Fly Back" is popped, and it needs replacement. Details like Part No. and Description is given below:
145334611 FBT ASSY (NX-6000//J1J4)
Replace the FBT and your tv work fine again.
Posted on Nov 18, 2009
White line across screen
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
Apr 05, 2014 | Sony 46 KDL46EX523 LCD TV
Television is a Tosiba DLP 72HM195
your tv needs a y-load board its like a grafix card as computers have due to overheating the board components are affected this is a manufacturing fault it tends to happen with samsung aswell
Feb 22, 2012 | Toshiba 72HM195 72" HDTV
Dark shadow-like vertical streaks thru LCD screen (Sharp)
Hi, I have a Sony Grand Wega LCD Projection TV that has a blotted gray streak across the front of the screen. I only use a damp cloth to clean the window and that doesn't seem to help. It really shows up on light pictures and is unnoticed when the picture is a little darker. What can I do to fix this problem???
Aug 19, 2009 | Philips 32PF5531D 32 in. LCD Television
Fine interference lines running diagonally across picture.
Hi There,
Sounds like your Horizontal Output Circuit is leaking current causing diagonal lines across the screen. I hope this will help and thank you for using FixYa!
Mar 29, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
I have a KV27FS210 sony wega trinitron tv. It turns on and has a single horizontal line across the center of the screen then buzzes shows a continuous zigzag line from the top to bottom of the screen with...
The single horizontal line is a problem with the vertical circuit. Look for a small flat id attached to a heatsink that should be marked LA7837 or something similar. Try resoldering the pins of this IC first. If that does not resolve it, replace the IC.
Keep us posted.
Dan
Feb 20, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
My Siny Trinitron G21M1 is producing horizontal lines across the screen
I hope your TV model is Sony KV-G21M1 and you see color bars as horizontal lines across the screen.
Let me now are you tech guy or know how to repair TV to guide you further.
Oct 26, 2008 | Sony Televison & Video
Blue streak appears across the tv
i have the same thing with mine same brand and all the problems. i was stupied and opened it and under the the circle retrackable scope is another piece u can unscrew but dont. there is liqiud in there and it will spell all over the best thing is to take it in and spent 40.00 to look at it and 160.00 for a new tube yes a tube runs about 70.00 to 160.oo for one tube. good luck
Aug 06, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Monitor
If your LCD monitor has damage it could be in three forrmats:
1) Damage LCD ribbon. The screen will power up bright white and you will see random strings of color in diaganol or horizontal streaking slowly across your screen.
2) Damaged Liquid Crystal Container. The thin glass/plastic may have ruptured due to an impact on the screen. You will see sharp jagged lines and maybe a partial post screen, but where the sharp "jaggies" are, are now permantly broken
3) Nothing on screen. This indicates that your internal CCFL (oh I love LED technology) tubes have now lived their life and will not ignite. To test this method, hold a very bright light to the screen and see if you can see any logos (Compaq/HP/Win Xp loading screen...etc)
If you can see something, your screen is fine, but there is no light behind it for you to see.
Hope this helps.
Jun 05, 2008 | Compaq tc1000 Tablet PC
Sharp 2002
If you are using an analogue signal then check things like DECT phones, Wifi / DSL modems, power cables, power convertors / UPS, washing machines, dryers, microwaves etc are kept as far away from the cables as possible.
Have you bought anything new recently, when it happens think what things are turned on... is it the garage door being opened etc.
If you are using a digital signal (and ideally something like a DVD player or a games console rather than a cable TV box) then check the HDMI cable.  If all appears well then it could well be a fault with the television, especially if you get interference from multiple source (i.e. cable TV, DVD player, console etc)
Oct 17, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sony KV-36XBR450 36" TV Logo
111 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
