Question about RCA D52W19 52" Rear Projection Television
RCA D52W17 Rear Projection HDTV......No Sound
We were watching TV one evening and all of a sudden the sound cut-off! Picture is perfect, mute in not on. Tried connecting external speakers but no luck. I am assuming a chip or circuit need to be replaced but wondering also if connecting a stereo receiver and surround sound would work instead? Thanks.
  • SAHDof2 Jan 10, 2008
    I am currently trying different things with the audio options. When the amplifier option is on 'internal' there is a high static sound coming from the TV. Then I connected my computer speakers into the headphones jack in the front of the TV, switched the amplifier to 'external' and now I do get the sound but also with the static sound. I do not have a stereo receiver/surround sound system to use on the TV, but will try to borrow one to see it that will work.
    Does the fact that I did get sound from plugging my computer speakers into the headphone jack give me any hope that this can be resolved without having to repair the internal speakers or chip??
  • duvert01 Apr 29, 2008
    I have exactly the same issue. When the setting is on internal speakers there is a high static sound coming out of the speakers. When I put the setting on external, I still have a high static coming out the audio output that goes to my external amplifier.
    How do I fix that? Can I fix it myself? Thanks!
    Genius:
  • 1,030 Answers
In the sound settings is the amplifer set to external or internal.
if thats not the problem.. the audio amp chip might be out. to repair this a technician usally replaces what is know as the small signal board.
Posted on Jan 10, 2008
Sound loss on my television When watching on Thursday last at 12noon. The mute button on my remote indicates that the sound is on but there is no sound every else works picture and subtitles
Try to turn the tv volume up its possible that even though your tv says its not muted the volume is all the way down, and if thats not the case it is possible that the volume was to high and the speakers blew out, or there is a bad connection to the speakers, like inside the tv the connection to the speakers are burned up, like the wires or the motherboard their attached to
Oct 01, 2016 | Televison & Video
No sound on lcd tv
First check your TV setup menu to see if your TV audio preferences are set to PC audio. That is a setting that sends audio out through your PC cables instead of the TV speakers. It may also have been set to mute through a remote.
May 02, 2016 | Samsung LN40D630M3F
I can't get any sound from my Hitachi 42PD5000 TV
try to connect an external speaker then if you got sound... then problem is on your internal speaker or otherwise in your settings....
Apr 30, 2014 | Televison & Video
I have perfect picture but no sound??
Many Mitsubishi TV have an audio mute button on the back of the set. It is near the audio out RCA connector and is used to disconnect the internal speaker when an external speaker is used. Just press the button and the internal speaker will work.
Sep 16, 2013 | Mitsubishi WD-73638 DLP TV
Model # LT-46249 tv has no sound
Check whether the TV is in Mute Mode.. Also check whether you've connected anything to the Audio output of the TV. like headphone or an external speaker...
Oct 15, 2012 | Mitsubishi LT-46249 46 in. HDTV-Ready TV
Tv pops on and off suddenly after viewing for about 10 to 15 mins. this problem becomes progressively worst after prolonged viewing. as of today there is absolutely no picture and or sound.
Your symptoms exactly match this scenario: a component involved in picture & sound was failing intermittently, then progressed to a hard failure.
My suspect: a power capacitor in the power supply. They sometimes fail this way - when the dielectric breaks down completely, then the power supply fails, causing no pic/sound.
Fix: replace power supply (or the specific capacitor, if you can determine which one died).
Oct 23, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Speakers stopped working
Is it connected to a stereo or are you using hdmi? The reason I ask is that sometimes when there is no sound it could be due to a loose cable particularly when it comes to using optical cables. Have you tried unplugging all your external sound equipment including cable / satellite tv leaving the tv unit free from any external sources? If it then does not work (and the mute button is not on) then it is definately an issue with the tv. More often than not it is due to old cables or a loose cable. If the tv works then add in each extra thing like dvd player one at a time. If the sound goes you know it is the cable for that particular item etc.
May 15, 2010 | Televison & Video
The sound stopped working on rca projection TV
FBT flyback transfomer and hori output transistor
Jan 01, 2010 | RCA P46812BL 46" Rear Projection...
RCA D52W19 52" Rear Projection Television Logo
189 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
