Question about Car Audio & Video
I have two kicker cvr 12s and they cut off when I turn the volume
I have two kicker cvr 12s and they cut off when I turn the radio up
  • 1 more comment
  • countryboy06 Nov 18, 2009
    I have two kicker cvr12s and a legacy predator 2400 watt amp. The subs come on at first until I turn up the volume and once the bass hits the amp goes into protection mode it worked fine when I had my kicker 15s installed
    My amp goes into protection mode when the bass hits hard and stays there unless I turn it off and turn it back on the amp has been working fine with my two kicker 15s and I just took those out and put kicker cvr 12s in and it started
    Yeah everything is hooked up right there dual voice coil and all the wires are right and I tried the 15s again and they still work
    Scholar:
  • 159 Answers
Are they hooked up correctly? And do you notice the amp turn off or change colors in lighting?
Posted on Nov 18, 2009
  • 1 more comment
  • Peter Toth Nov 18, 2009
    Have you tried hooking up the 15's again to see if it still stays on?
    It almost sounds like a wiring problem. How do you have them hooked up?
    If the 15's are SVC (Single Voice Coil), you may have the issue there...
    Sounds like they might be bridged for 2 ohms, and your amp isn't 2 ohm stable. The way to fix this is to bridge the speakers at 8 ohms.
    Let me find a diagram to better explain.
    http://www.the12volt.com/caraudio/woofer...
    This website shows the diagrams for DVC speakers. Because your amp may not be 2 ohm stable, try hooking it up at 8 ohms. You should be able to turn the amp all the way up without it cutting out.
  • 3,866 Answers
1. check the amp
2. check and make sure the amp is not being overloaded
This happens when a amp is overloaded and there is not enough power to pump those 12's check the amp make sure you have everything grounded and the current is a steady 12VDC to amp once you got that all down and you still got issues when turning up the volume I would have the amp pulled and looked at.
Thanks I do work hard to help out here please do click the accept button to show that your accept the solution and want ot move forward in repair.
  • Grand Canyon Tech
    Grand Canyon Tech Nov 18, 2009
    If you do not feel its the amp at this point have the kicker looked at try hooking it up to another system have it checked before any other thing is done you may need a limiter on it do it does not take the full wattage from the amp it seems like its faulting right when you turn up the volume so check that.
    please press the accept button
  • 11,896 Answers
Is just the subs cutting out or is the entire stereo going into system protection? If just the subs, double check your ground wire. I like to mount mine on trunk bracket and scrape the paint off. You do not want to use painted surface as a ground. Make sure your altenator is strong enough to power everything in your car. Use a fuse, do not direct wire to battery or you can burn out your altenator. You can also buy one of those caps which sends the battery voltage at a higher rate.
I also suggest turning all settings on amp 3/4-7/8 of the way up and then control the rest from now on from the cd deck.
  • Nate Stansfield
    Nate Stansfield Nov 18, 2009
    If I where you I would not use the bypass. they cause problems and are pretty much made for one speaker. But then you can just put one wire on each channel. Bypass is useless.
  • Nate Stansfield
    If that is the case, sounds like the amp is up to high for these speakers. I have seen this happen before although it is rare.
I have a pair of kicker cvr 124 with a kole 1500 watt amp that is bridged to the woofers. the amp is 385 rms at 2 ohms where should the gain be to get the most power without distortion.
When setting your gain you want to set the gain high usually between 75% to 95%. if the gain is low than turning up the volume on your radio will only amplify the distortion coming from the under powered head unit. By turning up the gain you are maximizing the signal that is amplified coming from your head unit
Mar 20, 2011 | Kicker Car Audio & Video
When the volume is turned up both 12s cut out sometimes
U will need to install peak power capacitors, this will cure the problem, contact a car stereo shop for more info on this fix and the capacitor kits needed.
Jun 27, 2010 | Kicker 06ZX750.1 Car Audio Amplifier
How to wire a 2400w amp to 3 12s subs
if the amp is a 2 channel, u could either bridge them all, or if you wanted to, you could hook 2 speakers to the two seperate channels, and then hook the other one to the negative on one channel and the possitive on the other. if this wasnt what you meant, just, try to tell me more about the amp... thanks
Dec 05, 2009 | Kicker CVR10 Car Subwoofer
Cut out
rewire the subs-each sub you want in series=8 ohms per sub-then at the amp wire the two 8 ohm subs in parallel which brings the ohms back down to 4 ohms which is optimal for the amp and it shouldnt shut down on you any more-try that-good luck
May 30, 2009 | Kicker ZX400.1 Car Audio Amplifier
Subs dont work when base is up high
Sounds like the amps needing more current available to it-You should have 4 gauge power coming off the battery going into a distribution block from there a 4 gauge to a 1 farad capacitor off the block -4 gauge to the ground for the capacitor -and two + leads from the block to your amps-you would do well with 6 gauge there.- That is to ensure that you have plenty of power on tap when needed and not trying to draw it off your charging system on heavy current demands.Make sure that your grounds are well placed and solidly connected. As for putting 600+watts on a pair of 8z......i hope that they are the CVR or the L5 / L7 series to take that much power,I've seen it done and the ones i heard sounded badass(L7 series)-but that was at the stereo shop so they had they stuff on HITTN status up in there. If your running the "cvr" or the "comp" series you might be throwing too much power on them -might want to step up your subs to a set of 12s just to get more air moving in there- good luck
May 28, 2009 | Alpine MRP-M650 Car Audio Amplifier
Kicker CVR 10" "stuck"
sounds like the wiring in the speaker from the factory is shoty. rare but does happen. if you bought this from a retailer and have all of your warranty information id send it back and let em fix it
Mar 03, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Cut out
Do you have ONE pair of 12's? Are they single voice coils? Dual? Bottom line, you are either over driving the amp (bass controll up high on the head unit (stereo), or the "load" on the amo is too low, meaning 2-12'" dual voice coils parreleled would give you a 1ohm load. Need more info, need to know what the bass is set on on your stereo, what size power wire to the amp, and I can wrap up the solution. ok?
Take care,
Larry T
Winona Lake, IN
Jan 28, 2009 | Kicker ZX400.1 Car Audio Amplifier
SUBS
Hi , you need to replace with thick wire , if possible attache fuse or circuit trip overload protection you may ask to thew radio store .
May 07, 2008 | Polk Audio EX12 Car Speaker
Amp cuts out at certain volume
is the output signal distorted? if not one of the subs could be damaged subs are capable of playing even when damage ,try them 1 at a time to see what happens.
May 17, 2007 | Kicker 04KX350.2 Car Audio Amplifier
Car Audio & Video Logo
81 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
