Question about Nokia 5630 XpressMusic Smartphone
Got new message sign is flashing the hole time
Bough't a nokia 5630 XpressMusic today and from the beginning i turned it on is the sign for that i got a new message or mail flashing but when i checked it is both message boxes pluss email box empty. i tried to update the software but it din't help.
Unlock my nokia 5630 lock code
JUST FLASH YOUR PHONE WITH MOBILE REPAIRER
Sep 07, 2012 | Nokia 5630 XpressMusic Smartphone
My phone is always full memory, il alreadt format it using *#7370#. and still having same problem...
Software update/flashing is the only way to escape from this problem.So try to follow this or contact mobile repairing shop
First download and install Pheonix. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 5630 file or Nokia flash file and install it to C / programme files/pheonix..after finished this installation open pheonix clip_image002.gifInside the interface at the> left top <there you see "File" click there and choose "open file" and then select the approprait Product type i.e"which is written in the back banel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there when you click there you'll see three icon just select the "Firmware Update" again you'll see another interface.Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Botton and choose the code which is written in the back side of your phone.e.g CODE:0000000.if the same code does not found just take one.After this you can see "Dead phone USB flashing" click that box.Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead,unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" after this, a message will prompt you "press power botton" press it and wait untill the phone will Restart automaticlly in normal mode 10-15 minutes.If you cannot understand just make a Reply thanks for visiting fixya.Good luck.If you could not do please contact me.
Jul 25, 2011 | Nokia 5630 XpressMusic Smartphone
How to flash nokia 5630 Xpressmusic.
first download the nokia software updater and also the nokia pc suite from the nokia website its free of cost. then install and restart you computer then connect your mobile then accept the terms and conditions.
go to this link to download the nokia software updater:
http://www.nokia.co.in/support/product_support/phone-software-update
Jun 13, 2011 | Nokia 5630 XpressMusic Smartphone
The sign of message is blinking all the time
go to msg -options-sim msges-delete any 1 msg-problem solved.
May 06, 2011 | Nokia 5630 XpressMusic Smartphone
My nokia 5630 messages wont get sent. I have checked the message center number but that is all fine. It just suddenly stopped working two days ago. I don't get why?
just type *#7370# and after your phone resets.it's fixed.i tried it.saves money and time.chieh14@yahoo.com thank me if this works for you.it did for me.
Sep 25, 2010 | Nokia 5630 XpressMusic Smartphone
Message sending problem in nokia 5630
Check the Message Centre Number for your phone operators number are correct, located in Message settings
If you really dont know about for the exact number call to your operator for the exact number
Sep 16, 2010 | Nokia 5630 XpressMusic Smartphone
Msg sign blink
i think iT's beCause of yoUr sim MesSages. Try Opening Your sim mesSages. in the meSsage appLication. ^_^
May 09, 2010 | Nokia 5630 XpressMusic Smartphone
Describe your Nokia 5630 XpressMusic WAP Problem
you are at the wrong place ... FixYa.com doesn't provide this service as far as I am aware.
Apr 28, 2010 | Nokia 5630 XpressMusic Smartphone
My nokia 5630 gets hanged when music is played and some of the basic features like new profile creation does not work
I have seen many problems like those. Sometimes viruses or sometimes the original ROM may be faulty as wel. Go to
http://europe.nokia.com/get-support-and-software/download-software#
Download the Update Managwer software for your computer. Check for updates. There must be one. And just update. Most of the times it solves the problem. Just be careful to take some back up of your conatacts and messages because you'll loose all your phone memory data. The files on the Memory Stick are not affected.
Dec 12, 2009 | Nokia 5630 XpressMusic Smartphone
Unable to send send message
outbox doesn't mean that it's sent if it was sent it would be in "sentbox"
Dec 08, 2009 | Nokia 5630 XpressMusic Smartphone
Nokia 5630 XpressMusic Smartphone Logo
121 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
