Question about Toshiba 36A43 36" TV
One speaker has stopped working
Our right speaker has recently stopped working. Any ideas what might cause this?
  • euast1 Jan 10, 2008
    Is it difficult to gain access to the speakers?
  • 579 Answers
Are you sure the TV is getting a stereo signal into it?
What connections are you using?
Saw a case last month where the right side audio cable had come loose from the input to the video player and it telegraphed all the way through to the TV. We were going nuts trying to figure out why the TV was bad when it was just cabling in the back.
Hope ya fix it!
Posted on Jan 10, 2008
  • 135 Answers
It could be the cable connecting to the speaker, or the speaker itself. Try taking the cable that's connected to the left speaker and connecting it to the right speaker. If it works, the cable connected to your right speaker is defective, if it doesn't work - your speaker is.
  • Yonatan Horan Jan 10, 2008
    Well, you'd need to open the TV, so it depends on whether you're comfortable enough to do that or you need a repair guy to.
Hi...I have an old Sanyo DC6100K 4 Channel Stereo System (circa 1970's). Still works OK except the right rear speaker outlet has developed a loud crackling. Changing speakers does not help. The crackle...
To the original poster I just inherited one of these machines. Afraid I cant be of much help with the speaker issue but mine was missing its turntable belt. Any chance you know of measurements or model or somewhere I could order a new one? Same question for the stylus?
Jul 31, 2013 | Audio Players & Recorders
I recently installed win 7 professional. Then sound stopped working. device manager says that everything is ok. Neither laptop speakers nor headphones work. The mixer shows sound bouncing up and down. ...
You can try running a system restore and restore the system to a point when the sound was working. Probably a software conflict has caused the problem. You can also run a hardware diagnostic that is usually included with the notebook.
May 19, 2011 | Toshiba Satellite U205-S5034 Notebook
I have a microsoft VX-6000. until recently it worked fine (video and microphone) on skype & msn, however now the microphone has stopped working. when I go into skype/tools/options/audio settingsand...
Make sure your webcam mic is set as default
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Configure to Skype
Apr 25, 2010 | Microsoft LifeCam VX-1000 WIN-Blk Webcam
One of my speaker channels has no sound
reinstall the speakers driver or your sound card driver. doing that select what kinda speakers do you have (5.1 , 2.1, 2).
Apr 06, 2010 | Cyber Acoustics A5640 Computer Speakers
My internal DVD-RW has stopped working ? Power Mac G5
Sounds like the DVD has broken. I would suggest either buying an external dvd drive (either USB or Firewire) or you could replace the internal DVD drive see instructions at
Oct 13, 2009 | Computers & Internet
1992 Jeep Cherokee climate controls just stopped working
unplug the blower motor, try that, i have seen a direct short in the blower motor cause that. also check the blower moror resistor--again another fault---hope that was helpful
Aug 05, 2009 | 1992 Jeep Cherokee Briarwood
Right speaker without controls has stopped working.
plese change the wires and try the permutation and combinations.this wil lead to find out if the fault is in wire or in the port. this is purely a hardware fault.
Jul 29, 2009 | Logitech X-230 Computer Speakers
At high volume sound shuts off, subs still work
You most likely have a shorted or damaged speaker, which is causing the internal amp chip to shut down (but does not affect the preamp outputs). A test you can do is to fade to one speaker at a time and turn it up to se if it shuts down. Repeat with each speaker until you find the one that causes the fault. Then replace it.
Dec 08, 2007 | Pioneer DEH-2100 CD Player
Car Audio Cutting Out
stereo is detecting a short , or low load on speaker wire and or speakers .Go behind car stereo , disconnect all speakers and apply a known good speaker to one of four wires and see if volume works normally ..If it works use same speaker on all outputs one by one ..If all are okay then you should figure out what speaker and or wires are causing issue..Also make sure your ground is okay
Dec 01, 2007 | Pyramid 4 X 10 SPEAKERS Car Speaker
Only one comes on
sounds like one of the channels on your amp is playing up.take it to an audio specilist to have this checked. if your rear right speaker isnt working this wouldnt cause the sub to stop working
Mar 14, 2007 | Lanzar MAX12D Car Subwoofer
Toshiba 36A43 36" TV Logo
110 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
