Question about Haier HSB03 Compact Refrigerator
It will not get cold
The Model is HSB03-01. The minifridge is not cooling and is iced over in the back. I unplugged it and let is dry and then plugged it in. Never cooled again and just started to freeze on the copper. Help!
  • Anonymous May 24, 2008
    I need to refill the freon, who can do it, or how can I?
  • Anonymous Aug 16, 2008
    i have same problem how can i fix it
  • 236 Answers
You need a qualified technician with your problem, may be the unit have leak and out of freon or system is restricted.
Posted on Jan 14, 2008
Samsung RFG298AAWP refrigerator gets warm. I unplug, plug back in, gets cold. Then few days later, same cycle.
Check for icing of the evaporator (cooling) coil located behind the cover on the back wall inside. There is a cooling coil with a fan to supply the cold air for the refrigerator. Otherwise you might have a control board issue. The iced coil is much more likely. There are repair kits for ice build up and/or defrost problems. To get the proper parts for Samsung you must supply all the ID numbers including full model, full serial number and BOM number (if it has one.)
Nov 01, 2016 | Samsung Refrigerators
Kitchen aid model kfis20xvms4 will not cool and front screen lights up but no words
Bad cold control sounds like. Try unplugging from a while n plugging it back in
Oct 24, 2016 | KitchenAid KFIS20XVMS 20 french door...
I turned off my Lemair fridge freezer to defrost it and when I turned it back on the fridge isn't cooling, but the freezer is fine. What do you think the problem is?
Hello Anne;
My name is Peter. I am a retired field service refrigeration technician.
Unplugging and plugging your unit back in should not have caused any component failure.
You only have one cooling source and that is your freezer. Your fresh food section is cooled by your freezer. You did not provide a model number, so I can not be specific. There is a air vent that goes from your freezer to your fresh food section. I suspect the vent is blocked with ice. Using a hair dryer, melt the ice in the vent until you can feel cold air coming out.
Dec 21, 2014 | Refrigerators
Refrigerator won't cool
seal on door must be letting moisture into compartment, need new door seal
Aug 20, 2012 | Kenmore Top Freezer Refrigerator
The ice maker will not quit dispensing ice and it no longer cools
For now unplug the pin plug at lower freezer door hinge and disable the dispenser control board until we see if the keyboard or the dispenser board is at fault. Sea Breeze
Feb 22, 2010 | GE GSL25JFPBS Side by Side Refrigerator
I have a Jenn-Air side by side frig. The freezer side cools too cold, the frig side not enough. 2 weeks ago I took all the food out of freezer and noticed ice build up on back. I unplugged unit, let it...
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
There is a small duct between the freezer and refrigerator side if this is blocked the frig side won't cool.
Jan 09, 2010 | Jenn-Air JCD2389G Side by Side...
Refrigerator not cool, freezer ok
Either the freezer continues to freeze up (most likely due to low refrigerant, due to a leak), or there is an obstruction between the freezer and the refrigerator (refrigerators get their cooling from the freezer).
Given that it works after you defrost it, I'm going with low gas. Call a professional to see if the leak can be fixed. If the unit is more than 10 years old, just get a new one.
Aug 22, 2009 | Kenmore Refrigerators
No cooling
Call a service person--if this happened rather suddenly, it is likely a refrigerant gas leak. Unplug the unit for now to save the compressor. Buy some dry ice to keep things cold while waiting for repairs.
Aug 14, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Haier HSB03 Compact Refrigerator Logo
298 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
