Question about Cell Phones
MY OLDER CELL PHONE VOLUME WAS TURNED DOWN ACCIDENTLY WHEN IT FELL AGAINST MY PURSE. I SAW A BAR GRAPH AND IMMEDIATELY TURNED IT OFF. NOW I DON'T KNOW HOW TO TURN THE VOLUME BACK UP. CAN YOU HELP ME. THANKS
SOURCE: Back light will not come back on.
if your on the back light settings, then press the down arrow three times. if your not, you can tilt it in a certain way so that you can kinda see what your doing
Posted on Mar 01, 2008
  • 4 Answers
SOURCE: my cell phone fell into water bucket for five minutes
DO NOT USE HEAT. You will damage the tiny components of your phone.
The best thing to do is that the moment you get water in your phone, disassemble it. Remove the battery as soon as possible. this is very important. Then, open the casing and seperate whatever you can, like the memory card, the back cover, the keypad etc. Shake out any water that you can from the openings. When you shake it you will most probably get some water out.
Now, use a dry cloth to dry your phone. Dry as much as you can.
Next, take a bowl and fill it with dry, uncooked rice. Yes, rice. :) Put your unassembled cellphone in this bowl. All of its parts should be in the rice. Now leave this overnight atleast. If possible, leave it for 2 days.
Then, assemble your phone again. It should work fine now. Atleast mine did. :)
Hope it works for you too.
Plus, as you have already done the first part and dried it, just leave it open under a fan etc overnight and it will work fine.
Posted on Apr 03, 2009
  • 70 Answers
SOURCE: Need new loud ringing AT&T cell phone recommendation
try a samung phone
Posted on Jun 09, 2009
  • 383 Answers
SOURCE: I cant hear anyone need to turn up volume
usually the up and down or the right and left scroll keys are defined to turn the volume up and down. Make a call to say hotline and then try the keys and see whether it shows the volume up and down graphic
Posted on May 01, 2010
  • 46 Answers
SOURCE: My cell phone turned off and it won't turn back
Plug the phone into the charger. With or without the battery the phone should turn on when you hold the power button for more then 2 seconds. If the phone does not turn on then you should check with the manufacturer about getting a replacement under the Manufacturer's Warranty.
Posted on Feb 28, 2011
I have an older Husqvarna 359 etech saw and its leaking bar oil from below the clutch plate but it is not spraying oil on the bar like it should be? What is the problem here?
Sounds like you have some sawdust under the plate between the body of the saw and the plate that goes against the bar take bar off look at plate that has two rievits on it clean out behind that don't remove the plate just lift it slightly and use air or feeler gauge or something very thin ..
Sometimes little wood chips get stuck in there and don't let the oil go down the bar
Oct 24, 2016 | Husqvarna Garden
Phone turned off itself and i turned it back on, it now says "try again in 538472 minutes"
Do a Full Reset THIS WILL DELETE EVERYTHING!!!!!!!
  1. Press and hold the Volume down and Power buttons at the same time until you feel a vibration (about 10-15 seconds).
  2. When you feel the vibration, immediately press and hold the Volume down button until you see a large exclamation mark.
  3. Once the exclamation mark appears, press the following four buttons in this order: Volume up , Volume down , Power , Volume down . Your phone should now reset and restart itself. (It might take a while for the reset to finish.)
Try again in 134600 minutes
Settings personalization
Jul 10, 2015 | Nokia Lumia 530 DUAL SIM Dark Gray Factory...
I don't want my phone to be in silent mode!!! Help!
To turn off the ringtone:
Press and hold the Power key on the top of the phone, then tap Silent mode.
Press and hold the down the Volume key until the volume bar is empty and the Ringer volume icon has a x next to it.
To set the vibrating alert:
1.From the Home screen, find and tap Settings.
2.Tap Sound & display.
3.Mark the Phone vibrate checkbox.
Tip: When in silent mode, press the Volume key up once to activate the phone vibrate mode.
Do the opposite to turn it back on.
Jul 13, 2011 | Sony Ericsson XPERIA X10 Cell Phone
Phone got wet and is now showing "DEMSBL BOOT Loader for MSM6288"
What you are seeing is the mode used to flash your phone. Why it is showing up IDK. You can get to this screen while holding down the volume down button on your phone while turning your phone on. Quite possible something is replicating this volume down key. Maybe play with your volume button and try to turn your phone on or hold the volume up when you turn your phone on and see if you can get by this.
Jul 16, 2009 | Samsung M8800 Pixon - Unlocked QuadBand...
MY Instinct (SPH-m800)GOT A LITTLE WET
the phone circuit is affected by the moisture in the babywipes.. yu must service yur mobile in a samsung service centre to get it back working.
Jul 05, 2009 | Samsung Instinct SPH-M800 Cell Phone Car...
White screen
defect lcd as long as there is no black lines indicating the lcd popped, your service provider should be able to replace the lcd at a repair location
http://storelocator.sprint.com/SL2/Default.aspx
Apr 09, 2009 | LG RUMOR Cellular Phone
Lines on front screen!
have the same problem...called cust serv...new phone on the way...i think you have to have had your phone less than 1 year though...
May 19, 2008 | LG enV VX9900 Cellular Phone
Freezing
try taking the back cover off then cleaning them out (buttons) they may be stuck try it and write back :)
Apr 12, 2008 | Nokia 5300 Grey Cellular Phone
Motorola E815 cell phone
This exact issue happened to me: I left my phone off for 2 days (unplugged), turned it back on and the internal speaker started working normally again. The phone worked normally for over a month after this. Yesterday, the earpiece speaker stopped working again after the phone fell out of my pocket. I suspect a loose connection or something similar, but I've had my phone off for the last day and will let you know whether or not it starts working again.
Jun 11, 2007 | Motorola Mobility E815
Cell Phones Logo
29 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
