Question about HP vs15 15"LCD Flat Panel Monitor
My sound is not working. Checked volume control in control panel. Checks out fine. What could it be?
  • 115 Answers
Pls check that the audio cable from monitor port to cpu port is connected properly ,re-connect it and check that you are connecting in output port.aftre that if still sound not come then re-install the sound driver and check it ,it still problem might be problem with speaker.
Posted on Nov 18, 2009
I cant get the sound to come out of my speakers. I have checked all conection, ect
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Aug 01, 2011 | Logitech LS11 2 Speakers
Still no sound in my unit
have u checked master volume control from control panel and check that it is set to the default sound device?
have u tried headphone to see if speakers are ok
have u tried putting a pci sound card
Mar 07, 2011 | ASUS P4S800- MX 661FX SOCKET478 800FSB...
When you try to play music the is no sound,even when it shows that sound drivers are installed
Have you checked your speaker connections? Have you checked the main volume control to make sure it is turned up? How about the volume for the media player you're using? If all these checks out as ok, you may need to completely uninstall your sound card drivers, and then go to the manufacturers website that made your sound card and download and install the latest drivers.
Feb 05, 2010 | Computers & Internet
Sound Not Working
Have you checked the volume control settings either in Control Panel or in the system tray (if it's showing?
Launch Control Panel and double click on the Sounds and Audio Device icon. Make sure "Mute All" isn't checked and that the volume is turned up.
Dec 25, 2009 | IBM ThinkPad T30 2366 Notebook
I have an ABS laptop. I have gone into control
First make sure nothing is muted.
Start>Control Panel > Sounds and Audio Devices
If nothing is muted, and your volumes are up and still no sound, try updating your audio drivers,
Start>Control Panel > System > Hardware > Device Manager > Sound Video and Game Controllers
Right click your audio drive and select Update driver.
Dec 06, 2009 | Ultimate Sound COMPUTER ABS | Ultimate V1...
Computer speakers do not work
Maybe you need to reinstall the driver for your sound card as what ever you installed may have currupted the original sound driver.
I hope this helps.
Have a good day and good luck.
Nov 20, 2009 | IBM ThinkPad T43 Notebook
System has power and cd's spin but no sound coming from the speakers. checked all connections and tried speakers with a different system they work fine. Please advise, Frank
First, check volume levels in mixer, both output volume and cd input volumes...Go to control panel>sound and audio devices>hardware and check to see that your sound card and drivers are working properly. Use troubleshooter if devices are disabled or not working properly. Make sure advanced settings for sound are correct for your speaker type....
Also see this article: http://support.microsoft.com/kb/307918
or search sound problems vista for alternate article.
Apr 20, 2009 | Audio Players & Recorders
There is no sound and volume on my laptop.
check for the sound for the required audio might be muted
Oct 03, 2008 | Audio Players & Recorders
Computer stopped recognizing the speakers
You need to reinstall the latest drivers for your present sound device then restart your pc then check it. It will work surely! you should install the drivers that came with your sound devices! thats it!
Dec 07, 2007 | Polk Audio M3 Speaker
Check the sound card system Can your hear through headphones for example?
Nov 15, 2006 | Logitech X-230 Computer Speakers
HP vs15 15"LCD Flat Panel Monitor Logo
97 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
