Question about Nakamichi RE-10 Receiver
My receiver will not play in dts - Nakamichi RE-10 Receiver
  • 405 Answers
This is stereo receiver, it does not have DTS decoder.
Posted on Nov 18, 2009
Yamaha RX-V595 Receiver will play Dolby Digital 3/2.1 audio Blu-Ray disc with player set to bitstream but will not play DTS-HD 3/2.1 unless output is set to PCM. Is this an issue with the Yamaha Recei
The optical connection (SPDIF) doesn't have enough bandwidth to transfer DTS-HD audio. To use DTS-HD, you must connect the blue-ray player and receiver via HDMI cable.
Each DTS-HD audio track on blue-ray includes also "normal" DTS audio, which is probably used when you select PCM. Player decodes it and sends decoded (non-HD) audio via optical cable to receiver.
Nov 17, 2014 | Yamaha RX-V595 Receiver
Didn't supporting DTS when playing DTS filims no sound is hearing i would like to make DTS support on my dvd philips any codecs for that or any other way?
Maybe your player,simply does not decode dts streams.
All you need to do is to buy a decent receiver with digital inputs.Connect player to receiver using an optical or coaxial cable[or hdmi 1.3/1.4 cable] and let the receiver do the dts decoding......
Don't forget:sett the audio output in your player to "bitstream".
M
Jan 19, 2011 | Audio Players & Recorders
Different Audio output between DVD and Blu-Ray DVD
m4wolf
The issue is that not all videos use DTS. Look at the videos that you are trying to play do they support DTS if so make sure that you are selecting the DTS track in the audio setup.
In regards to your receiver if it does not support Dolby Digital then you might want to look at upgrading to a receiver that supports Dolby Digital and DTS if you want true surround on all your videos.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
May 12, 2010 | Sony PlayStation® 3 (60 GB) Console
DTS option shows on the display when playing a DTS movie, but unit will only play in Dolby when trying to select listen mode...I can't select DTS mode
That is a typical function of the movie you are watching..changing the sound mode can "usually" only be done by selecting it on the disc, or by using the audio button on your player depending on the model.
Dec 23, 2009 | Kenwood VR-407 Receiver
My dts is not coming on when I attach it to the dvd with optical
DTS will only come on if you are playing a dts dvd,most of these dvd,s need you to pick dts in the setup menu or sound settings.If you have done this make sure dts out is set to on in your dvd player.
Hope this helps.
CABLE GUY.
Apr 20, 2009 | Kenwood VR-505 Receiver
Yamaha HTR -6130 DTS?????
First, the sound source must also be in DTS. DTS is typically not the default audio selection on any DVDs that have that format...you'll have to select it.
Mar 26, 2009 | Yamaha HTR-6130 Receiver
How to play dts/dolby digital on HK AVR5
I believe he avr-5 has 6 channel inputs, what you will need is a dolby digital 5.1 and DTS outboard surround sound processor, say an item as the Technics SH-AC500 decoder, a Harman Kardon Signature 2.1 DTS version outboard processor/preamp, and many others on the market by different manufactors, Run the discrete audio outputs from the Processor into the AVR 5`s 6 channel inputs, select 6 channel input or DVD inputs on the receivers selector and your good to go. Be sure you are playing Dolby Digital 5.1 or DTS encoded material.
Feb 08, 2009 | Harman Kardon AVR 100
I cannot seem to get DTS-HD master to show on the receiver screen
You need to check 3 things:
1) DTS will only work through a digital connection (coaxial, optical, or HDMI) between your receiver and dvd player. DTS and Dolby 5.1 cannot carry a signal over red and white rca connections.
2) After number 1 is solved ensure the reciever is set to the digital channel, your DTS-HD in this case, or in an auto mode.
3) Finally the most important is that the signal is a DTS signal. Start a DTS capable dvd, go to the sound menu and set it for DTS.
Press play and all should be well...
Cheers,
NTIMID8
Dec 13, 2008 | Onkyo Audio Players & Recorders
Dts audio cd
kindly check digital settings on your dvdplayer. The output should be in digital domain. Are u using original dts audiocd or burn dts audiocd.
Oct 01, 2008 | Denon AVR-3806 Receiver
Nakamichi RE-10 Receiver Logo
52 people viewed this question
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
ELECTRICLAW
Level 1 Expert
da surgen
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
